Old 01-20-2014, 09:10 AM   #43
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Car has switched from Hankook RS3 tire to Dunlop Direzza ZIIs. This was my first event on them and Deland is never good for testing changes, way too dirty and slick.
Deland was more slick than ever today. So dirty that there were huge dust clouds in 4th heat still, even after the rain in heat 3. With learning the new tires and the lack of grip, I drifted all day. Kept lowering rear pressure until I had a semblance of traction on throttle. I knew the car had a 46.x in it but I only managed 47.9 clean and 47.1+1 times. Time was enough for first versus an E36 M3 with a few *questionable* modifications but his times were the only ones in CS close to mine and I wanted a battle so I let it ride.
Can't wait for Brooksville to really test the tires.
[ame="http://www.youtube.com/watch?v=w8czZa5rfxc"]BRZ at Deland Autocross 1-19-13 CS #199 - YouTube[/ame]
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
Ocala FR-S (01-20-2014)
Old 01-20-2014, 09:38 AM   #44
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Obviously sounds like this wasn't a fair comparison, but what was your opinion about the audible feedback between the hankook and the ZII? I am so used to Hoosiers I feel like my best transition tire back to 200tw will be one that has similar audible feedback, which from others opinions, sounds like the Hankooks are the best place to start. with that said, if hankook is really phasing out the RS-3, I don't want to start setting up the car for them if they aren't available long term.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 01-20-2014, 09:39 AM   #45
Rexpelagi
Drives: 2013 Subaru BRZ
That was my experience at Nationals also - even on a clean lot the ZII rotates a lot more than the RS-3. You can't really run the same setup with both tires.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 01-20-2014, 09:59 AM   #46
Kido1986
Dodging cones
Kido1986's Avatar
This lot is so incredibly dusty and slick, there is little tire noise from any tires unless you're too far gone to save. With that being my only time I've had on these, I can't speak for their feedback. And Hankook is showing every sign of phasing the R-S3 out so switching to it now isn't the best idea. I loved them but I need need stiffer sidewall with the lack of camber we have.
I'm running the same shock settings but I had to stagger 8 psi difference F to R to drive this (38/30), and could have done more. But everyone in CFRegion knows that you don't make setup changes based on any data from Deland. It's more slick than good some sites in the rain.
Old 01-20-2014, 10:50 AM   #47
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Fair enough, based on your comments I assumed there wouldn't be much useful feedback. We have a similar lot here, heck of a lot of fun but useless to learn anything substantial on. When's your next event on a worthwhile surface?
Old 01-20-2014, 11:05 AM   #48
Kido1986
Dodging cones
Kido1986's Avatar
This weekend. CFRegion's best concrete venue, Brooksville, on Sunday. Can't wait.
Old 01-20-2014, 11:28 AM   #49
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Nice, thanks for reminding me how much northern winter sucks! If you think about it, still interested in your feedback after this event!
Old 01-20-2014, 11:36 AM   #50
Rexpelagi
Ugh. Agreed.
On a better lot I'm sure the traction will improve but relative to the RS-3 I'd expect the same oversteer tendency you observed this time. It really was night-and-day even on Lincoln's concrete.
-John L.
2011 BMW M3 - 57 FS
Old 01-20-2014, 12:19 PM   #51
Kido1986
Dodging cones
Kido1986's Avatar
I know Z2s are a bit peakier and will tend to slide but tire pressure can help with that.
Old 01-20-2014, 01:06 PM   #52
Rexpelagi
Yep, and the ZII's were definitely faster. I actually think the car itself responded well to the added slip. My goal this year is to make the RS-3's behave the way the ZII's do in terms of US/OS balance (because I still have RS-3's on my wheels with life left). I forget our pressures with the ZII's but we did have lower rear pressures than front. It wasn't as much as you needed on the slippery lot though.
-John L.
2011 BMW M3 - 57 FS
Old 01-20-2014, 01:16 PM   #53
Kido1986
Dodging cones
Kido1986's Avatar
I believe the goal will be 38/32 on decent surface.
I ran 215 RS3s for 1.5 years, found the best performance at 35psi all around on an ideal day/surface.
Old 01-20-2014, 03:57 PM   #54
ViperASR
Drives: 2006 Honda s2000
We can also try pulling rebound out of the front depending what the car is doing on corner entry vs exit. I think the car will be pretty spot on at Brooksville.
ViperASR is offline   Reply With Quote
Old 01-20-2014, 04:09 PM   #55
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
I like my new ZIIs--they seem to like mid-size AWD cars in return lol
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 01-20-2014, 04:23 PM   #56
ViperASR
After seeing how smoking fast the car/driver combo was at Tavares
I'm going to run the RS3s on the s2k a few more times and see if they come back to life as it warms up, if not I'm probably going to a Z2, or the rumored RS4 in the spring.
Or I will keep flogging Henry's car until he drags me out of the drivers seat.
The Following User Says Thank You to ViperASR For This Useful Post:
GTB/ZR-1 (01-20-2014)
DC's Progression Thread. DC@RoadRace Member's Car Journals 8 11-10-2014 09:22 PM
Newbie set-up for Sebring, Help! maj75 Tracking / Autocross / HPDE / Drifting 40 04-16-2013 10:44 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Newbie KiRiMa Scion FR-S / Toyota 86 GT86 General Forum 10 01-07-2010 05:39 AM
