Old 01-19-2014, 02:40 PM   #71
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Order placed
Are there specific instructions for removing the Ecutek Rom(Tune) and returning to Stock Rom(Tune)?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-19-2014, 10:09 PM   #72
steve99
Drives: FT86
Hi Shiv,
Just got OFT
Saved stock ROM
Downloaded OFM 1.06 connected OFT seemed to update ok
But every menu selection in Open flash manager causes exception error.
Tried reboot of computer attach/detach tablet but same result
attached a couple of error files arrh forum does not like files will email them instead
any ideas??
thanks
Old 01-19-2014, 10:36 PM   #73
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi Shiv,
Just got OFT
Saved stock ROM
any ideas??
thanks
Are you running Windows 8? If so, run the Windows 8 patch. If that doesn't work, try loading the user software on another laptop and see if the problem persists. The User Software is pretty robust and stable. Usually when there is an issue, it's often an issue with the laptop OS or comms, not the software itself.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 01-19-2014, 10:38 PM   #74
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by tonystewart View Post
Order placed
Yes, you will need to contact your previous tuner and ask him to send you a stock ROM. Make sure you tell him that you need to revert your ECU back to stock. Then just flash your ECU with the stock ROM. At that point, the OFT should install just fine
Old 01-19-2014, 10:56 PM   #75
steve99
Drives: FT86
Shiv
Hi Shiv,
I am running Windows XP on laptop.
Comms seems ok as device will talk to car for diagnostics and the OFT connects to laptop when connected and runs through upgrade diagnostic checks ect all ok. just nothing works
will try another PC (desktop)
Old 01-19-2014, 11:07 PM   #76
Shiv@Openflash
Drives: 2013 FRS
Hi Shiv,
Yes, please try another computer. Also make sure you use a USB 2.0 port and not a USB 3.0 port.
Old 01-19-2014, 11:14 PM   #77
steve99
Drives: FT86
Tried Desktop computer (same XP operating system) and all ok. something weird with laptop
Laptop is a few years old so its only USB 2 ports not 3. now OFT is working on desktop will investigate why laptop is a problem. thanks
Shiv@Openflash (01-19-2014)
Old 01-19-2014, 11:33 PM   #78
Shiv@Openflash
Drives: 2013 FRS
Glad to hear!
Old 01-20-2014, 12:31 AM   #79
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
We start shipping out OFTs with preloaded tunes on Monday so it is safe to say that you unit doesn't have any files preloaded on to it. So you will need to manually load tune files on to your device as everyone else has done from up to this point. Instructions are on the website. But I'm sure Jeff@topgersolution can also help you
When I enquired with Top Gear Solutions they also said that the OFT's (purchased from them) come "...loaded and ready to go". But as you said, these preloaded OFT's only start shipping out on Monday so I think he may have not known about it.
I'm sure he's not trying to deceive anyone but perhaps just miscommunication?
Fizz is offline   Reply With Quote
Old 01-20-2014, 12:39 AM   #80
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hi Shiv,
Just got OFT
Saved stock ROM
any ideas??
thanks
Glad you got yours sorted out in the end, but I think I'd just have a nervous breakdown if using the OFT the "old" way and encountered similar issues (I'm a retard when it comes to most things IT related).
That's why I need the 3-touch preloaded OFT because it's retard proof
Old 01-20-2014, 03:35 AM   #81
steve99
Drives: FT86
Got Stage 1 tune loaded and did a short log
My car is stock except for HKS Axleback exhaust and perrin intake tube
Stock ROM
http://datazap.me/u/steve99/brz-g-se...log=0&data=1-8
Stage 1 ROM
http://datazap.me/u/steve99/brz-hks-...log=0&data=1-8
Both Stock and Stage 1 ROM's appear to have a bit of knock around 2 to 4 thousand RPM low load but the sage 1 ROM appears to have less to my untrained eye
Happy to hear comments
Thanks
Old 01-22-2014, 04:03 AM   #82
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Got my OFT today, it didn't come preloaded with maps so im doing it manually.
Your step 3 video shows how install the maps, but now how or where to get them? I dont see "base line maps" anywhere.
Am i supposed to get maps from Off-The-Shelf Maps v1.42?
Upload Data section isnt reading any of those files.
Someone help a noob out
*edit- So I got the maps off v1.42, but they come out as VLC media file (.bin)
What am I doing wrong here??
Carlitoz3 is offline   Reply With Quote
Old 01-22-2014, 11:06 AM   #83
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
once the maps are extracted from the zip they are supposed to be .bin files. Shouldn't matter that VLC player wants them for itself just use the OpenFlashManager software to load them to your tablet.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Carlitoz3 (01-22-2014)
Old 01-22-2014, 04:32 PM   #84
taiquach
Drives: 2013 scion fr-s
thank for reply shiv. you're right,my unit does not come with preloaded maps. anyway with the help of my brother, I was able sorted through. flashed with stage 1,car run so good and smooth and it really come alive when hit 4k rpm and up. after the test drive I hook up the oft to check out real time data feature, I found that the iam and kc learn remain 0 all the time. what should I do to make it work ? THANKS
taiquach is offline   Reply With Quote
Key FOB programming milkesfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 10-21-2015 03:56 PM
Anybody have any experience programming MiniDSP? mid_life_crisis Electronics | Audio | NAV | Infotainment 2 12-02-2013 09:07 AM
