#15 | |
Tape string/yarn at the back of the hood where it is raised, and you'll see that the air is going into the engine bay, instead of exiting out. This happens because there is a high pressure zone where the hood meets the windshield, and the net effect is that LESS air is being conducted through the radiator. You can log engine and oil temps through the OBD2 port -Mike |
| The Following User Says Thank You to CSG Mike For This Useful Post: | AceHeader-MT (11-26-2013) |
#16 | |
Drives: 2012 FR-S
Also I am looking for ""How to data log?" Do you have kit to sell? Ace |
#17 |
#18 |
You still have plenty of vents underneath the car, so the flow through the radiator may not necessarily be reduced, but in order to increase the flow through the radiator you would need vents on the hood and they should be closer to the bumper than to the windshield.
![]() (the red areas/lines show low pressure regions.) This should work: http://www.carbon-fiber-hoods.com/co...by_Seibon.html |
| The Following User Says Thank You to rx3 For This Useful Post: | CSG Mike (11-27-2013) |
#19 |
If you want a more permanent gauge than your phone (to see your temperatures) you could install this: http://www.ultra-gauge.com/ultragauge/
(I have done opposite on my daily driver, I installed a grill block to reduce my fuel consumption and accelerate engine heating in the winter and use it to watch my temperatures and even though I blocked almost the entire grill I can barely get the cooling fan to turn on in a traffic jam.) |
#20 |
How effective would cutting out the fender trim pieces so they vented air?
I've read people saying they can feel a lot of hot air escaping, but what about at speed? I'm planning on trying this before going for a vented hood. |
#21 |
I actually wanted to post this in this thread.
http://www.ft86club.com/forums/showp...23&postcount=2 If you added a lip just before the panel underneath the engine you would provoke low pressure region behind that lip, which would suck air out of the engine compartment (if you removed the panel). (Just as this spoiler/lip on the trunk provoke as low pressure region behind it: )This wouldn't be aerodynamically efficient but as long as you don't care about top speed or fuel economy it wouldn't matter. |
| The Following User Says Thank You to rx3 For This Useful Post: | WillRacer1jz (11-30-2013) |
#22 |
Drives: Moped
I would love to see someone try out some options with the fender vents being functional as well...I think Prova's fender vents are actually wire mesh, but you still need to cut out and enlarge the open area behind them...
#23 |
Boosted Member
Drives: 2013 SWP BRZ Limited
I'm also curious with fender vent cut out. if anyone has photos of where they cut out, that'll be super helpful!
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#24 |
I'm confused... you claim the IAT's dropped 10* on your other thread, how do you know that if you're not logging them??
#25 |
Drives: 2012 FR-S
| Product To Reduce Dash Glare? | Captain Snooze | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 08-20-2015 06:55 PM |
| Reduce wheel gap without lowering the car? | retrosmiths | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-29-2014 04:34 PM |
| Reduce interior sound | KillionsFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-28-2013 05:23 PM |
| what's your solution to reduce the wheel well gap? | chenshuo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 01-14-2013 09:25 AM |
| Petition to Reduce Grey Market Imports from 25 to 15 years! | chulooz | Other Vehicles & General Automotive Discussions | 3 | 12-05-2011 11:59 PM |
