Old 01-16-2014, 08:45 PM   #1
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
Spal Fan Shroud & Koyo Radiator
We're still waiting on the turbo for our kit build but in the meantime we've been working on supporting mods.
For our race car we wanted to go ahead and put a Koyo radiator in along with a proper fan shroud with Spal fans. We also want to make sure our turbo kit will comfortably fit the largest radiator and fan setup anyone would need to run.
This fan setup will also fit the stock radiator for those interested.
Finished... Not much room to spare.
Temporarily installed for pictures, we are waiting on some seals for the back of the shroud that should arrive tomorrow. We also have some wiring left to do, we are hoping to make it plug and play if we can find the proper connectors. For our car we will be using DTM connectors.
Tacking it up on our Bluco table
OEM Height.
New height.
Carolina Dyno is offline   Reply With Quote
Old 01-16-2014, 09:47 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Very jealous of all the tools in that shot with the blanco table
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-16-2014, 11:20 PM   #3
mike the snake
MAN I wish I could run a shroud like that, but there's just not enough clearance on my car with the turbo kit and thicker radiator.
Old 01-17-2014, 02:43 AM   #4
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Aren't you running the Full Blown Kit?
He's coming out with the Fan Shroud.
carlossanchez89 is offline   Reply With Quote
Old 01-17-2014, 03:37 AM   #5
mike the snake
Thanks, it looks like I may be trying that FB shroud out with some thinner fans.
Old 01-17-2014, 10:05 AM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think that might work with the Full Blown kit. I would buy it in a heartbeat if I still had my car. With the shroud and higher flowing SPAL fans, I bet it would fix any idling/traffic temp increases.
Old 01-17-2014, 10:16 AM   #7
Carolina Dyno
Drives: 2013
I don't know if you could make it any thinner. This is only 2.65" deep at its very deepest point (measured from the back face of the radiator core). We used the thinnest fans Spal makes and only have a shroud depth of .65"
Any thinner than that and you either have a nonfunctional shroud (honestly this one could be deeper) or you have a crazy thin fan that isn't going to flow much.
Old 01-17-2014, 10:57 AM   #8
mike the snake
I meant the thinner Spal fans.
My tuner checked the specs, and the Spal fans are slightly thinner than the FB fans, but flow a little less CFM's. They may be more efficient with the shroud though.
Old 01-17-2014, 11:16 AM   #9
mrk1
Those fans are nice, I just got some SPAL's and I must have ordered the wrong ones, mine are thicker then yours.
The Build Thread
Old 01-17-2014, 11:29 AM   #10
Carolina Dyno
Drives: 2013
These are the thinnest Spal makes as far as I know. If you find different let me know. The part number I'm using is 30100375
Old 01-17-2014, 12:35 PM   #11
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
noob question, but are these fans more efficient than the OEM thicker fans? Or efficiency on the fans do not matter?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-17-2014, 01:50 PM   #12
carlossanchez89
2Supras1FR-S
they blow less CFMs
Old 01-17-2014, 02:54 PM   #13
Carolina Dyno
Drives: 2013
they blow less CFMs
Lower CFM but lower amperage draw as well. They are definitely a less efficient blade design because of the shallow fitment. Spal makes hands down the best aftermarket fans out there and they are very efficient for their size. These will provide adequate cooling for any conditions with a Koyo radiator. I probably wouldn't recommend going on track with a stock radiator and these fans but then again I wouldn't go on the track with the stock radiator in the first place.
Old 01-20-2014, 01:26 PM   #14
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Once people take a look at the stock radiator and realize it's the same size as the ac condenser more will hop on the aftermarket radiator.
SubaSteve is offline   Reply With Quote
new koyo radiator autobrz Engine, Exhaust, Bolt-Ons 1 12-25-2013 08:42 AM
Frs/brz koyo radiator F-T Engine, Exhaust, Bolt-Ons 16 12-02-2013 02:48 PM
Koyo Radiator SALE!!! Powerhouse Racing Engine, Exhaust, Bolt-Ons 1 10-07-2013 10:22 AM
KOYO Radiator In-Stock!!! Free Shipping!!! Titanmotorsports Engine, Exhaust, Bolt-Ons 24 07-09-2013 05:55 PM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-21-2013 11:18 PM
