Old 01-16-2014, 08:16 PM   #2703
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by phloozy View Post
boo, should do a before and after! Also I forget are you running on e85?
I have a before run (well, on stock header. i'm on borla uel now until my unicorn header arrives from nameless.)
I run both e85 and 93, just depends.
here's a before / after of my car before supercharger w/ nameless overpipe/downpipe/highflow cat, nameless axleback, E85 tune vs Innovate non-intercooled 75mm, same mods, E85) dyno had an issue causing us to bail on the supercharged run early, but you get the idea.
Old 01-16-2014, 08:24 PM   #2704
phloozy
phloozy's Avatar
Drives: Scion FR-S
Awesome thanks! Well I look forward to seeing your post IC and pulley dyno.
phloozy is offline   Reply With Quote
Old 01-16-2014, 09:48 PM   #2705
Calum
That Guy
Drives: 2013 asphalt FRS MT
Please, please, run that setup with the nameless header and 93.
Old 01-16-2014, 09:50 PM   #2706
xjohnx
Grip>Slip
xjohnx's Avatar
IC/93/Nameless, no problem. 70 or 75?
Old 01-17-2014, 04:54 AM   #2707
Calum
That Guy
If the 70 is making a boost level that would be safe for 91, then that.
Sent from my GT-S7560M using Tapatalk
Old 01-18-2014, 02:02 AM   #2708
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Real quick, someone had asked about mileage, I made it from Charlotte to Wilmington (bit over 200 miles), and used a little over half a tank.
Sent from my VS840 4G using Tapatalk
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
Calum (01-18-2014)
Old 01-18-2014, 09:52 AM   #2709
rgt
Drives:
I am interested in the Innovate Stage 1 kit. I want to keep the installation as simple as possible and the car as stock as possible (ie no aftermarket headers, intakes etc.). My question has to do with the ECU flash. I want confirm that between the Stage 1 "tuner" option from innovate and the Delicious Tuning "Stage 1 Complete" Ecutek reflash I will have all I need to get this SC up and running. Thanks all - this thread has been a great read (took me a few days to get through it...
rgt is offline   Reply With Quote
Old 01-18-2014, 10:11 AM   #2710
wrxgoose
WUB WUB
Yeah, basically all you need to run it is the blower and a tune. Should give her 210-230whp IIRC from earlier posts.
Old 01-18-2014, 11:05 AM   #2711
rgt
Drives:
Excellent. From what i can gather it seems that Innovates Stage 1 Complete kit comes with some sort of a base tune that the car can run on but it sounds like the Delicious Tuning maps are a marked improvement. I just didn't want to end up buying two Ecutek's and cables accidently.
For anyone that is running the Stage 1 kit without any additional mods to the car how many miles do you have on the Innovate Kit at this point and have you experienced any significant issues?
Old 01-18-2014, 11:27 AM   #2712
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I may get a lot of abuse for saying this, however lets see the reaction.
Based on the fact you don't want to do any mods and stick to Stage 1 NIC kit. You would better off saving the cash and getting a Delicious Stage 1 NA tune with a DIF or intake. If you have E85 or even 93Oct available, Bill is getting 180 to 200 whp.
That's my opinion, let's see who me down
Ryan86 is offline   Reply With Quote
Old 01-18-2014, 12:09 PM   #2713
wrxgoose
WUB WUB
I have an updated dyno chart for my car on a dynojet with sae correction. Have to post when I get home
Calum (01-18-2014)
Old 01-18-2014, 01:45 PM   #2714
Calum
That Guy
I'm guessing from the deadpan that it was good...?
Old 01-18-2014, 01:48 PM   #2715
wrxgoose
WUB WUB
Meh. 250 sae corrected, 261 uncorrected. But we may toss her back on the dyno to check the afrs. I'll post the vid too, big ole poof of black smoke.
Old 01-18-2014, 04:21 PM   #2716
rgt
Drives:
Nah I think that is fair. That's actually some pretty good gains without FI. I didn't think that was possible. What is a DIF?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
