Old 01-16-2014, 12:33 PM   #15
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
I think the brakes are pretty good. I think they are wrx brakes from the 2003-2003ish wrx?
Aren't our front brakes 4-piston anyway?
dave77 is offline   Reply With Quote
Old 01-16-2014, 12:39 PM   #16
s2d4
s2d4's Avatar
Originally Posted by ndsleep612 View Post
I drive conservatively, but once in a while I'll gun in on a freeway entrance to match the speed of traffic. When I step on the brake pedal, it feels that there just isn't enough bite to the stock brakes when you're trying to slow down when traveling 85 or doing emergency braking.
Is this you trying to merge?
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
chas3wba0 (04-10-2014), Evil Jesus (01-26-2014)
Old 01-16-2014, 12:41 PM   #17
DR 86
DR 86's Avatar
Front brakes are two piston. Rear brakes are one.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 01-16-2014, 12:42 PM   #18
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Oh my bad.
Old 01-26-2014, 07:43 PM   #19
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Beyond the obvious lack of power, I didn't like how underwhelming the stopping power was. I have xp8 front a rear and its absolutely amazing even with oem Prius tries.
TouchMyHonda is offline   Reply With Quote
Old 01-27-2014, 02:16 AM   #20
RCL
Drives: subaru BRZ
get better tires, and better pads.
RCL is offline   Reply With Quote
Old 01-29-2014, 03:12 AM   #21
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
re: Stock brakes too small for stock wheels
like others said. you need more grip. 1st thing, get better tires.
i switched out the stock rims for 17x8 rims and put grippy tires on them.
then you can also get some of this stuff like the grimmspeed master cylinder brace, performance rotors, pads, ss brake lines. thats about all you can do with the stock setup besides maybe a brake air duct. i might make my own if i feel it needs it. i dont think it will need it. that should make a big difference in stopping power. oh maybe light weight lug nuts will make you stop faster lol. the tow hook and oil drain plug in the pic dont count. dont mind those.
i havent installed
the lines
or the rotors
or pads
or mc brace
not yet... but when it warms up outside i will be dropping it all in.
NYCsubaruBRZ is offline   Reply With Quote
Old 01-29-2014, 07:31 AM   #22
wparsons
wparsons's Avatar
IMO, stay away from drilled rotors. If you're actually heating up rotors a lot they'll crack easier than a blank rotor.
The only upgrade most owners will need for track driving is better pads and fluid.
With my summer tires I could overheat the stock pads in a couple corners, but with better pads and fluid I haven't overheated them yet.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
SirBrass (04-11-2014), suaveflooder (02-01-2014), Trac Toy (01-29-2014)
Old 01-31-2014, 02:52 AM   #23
NYCsubaruBRZ
the whole idea with drilled/slotted rotors is that they release the heat better and they dont allow the gasses that are being released from the pads to stay between the pad and rotor. so they actually make the car stop harder. and cooler brake temps. ive had drilled slotted rotors on every car or truck ive owned. never had them crack or split. i run my cars hard. but i guess if they were to crack they would crack easier than stock solid rotors. the drilled/slotted rotors will perform much better then the solid stock ones. no doubt it will shorten up the stopping distance.
your right about the fluid. that is a key part.
i think a mc brace is also essential. for obvious reasons, especially if you are going to track the car.
stopping power is everything unless you are doing a 1/4mi.
also it didnt cost an arm and a leg for these parts.
under $500 for the mc brace, rotors, pads, ss lines, and brake fluid.
this is a full up grade. theres nothing better than that for the price.
unless you have 5g's or so to afford the 6pot calipers. which i dont think you really need unless you are making 300whp or more
i cant wait to install these goodies!
its going to be amusing when i jam on the brakes and all the shit on my rear seat comes flying at my windshield and cracks it because i forgot there was shit back there. i already had a soda can whip into my dashboard and explode HAHAHHA lol i wasnt laughing at the time.
i will have to call "close calls" "not so close calls" (actually that guy is like f***ing 3 blocks away. wtf am i saying? im no where near him. wow these breaks r good but F*** you guy in the minivan 3 blocks down for cutting me off anyway. what if i had stock brakes? it would be a horrific site for sure. or maybe i would stop 2&1/2 blocks away lol)
Old 01-31-2014, 07:25 AM   #24
atledreier
Drives: GT86 DGM
What tires was this? I have tracked mine many times on Toyo R888 and haven't had a single issue with brakes except wearing them out. No fade whatsoever, and the track I drive is pretty mean to brakes.
atledreier is offline   Reply With Quote
Old 01-31-2014, 07:28 AM   #25
wparsons
wparsons's Avatar
^^ There's a very good reason no race cars run drilled rotors... slotted ones aren't bad, but they also aren't needed and just increase pad wear. Drilled and/or slotted rotors aren't going to increase stopping power at all.
http://automotivethinker.com/brakes-...d-and-warping/
http://www.autos.com/aftermarket-par...slotted-rotors
If you're running R888's and not getting pad fade on the OEM pads you're not braking anywhere near hard enough. I'm running Dunlop ZII's and was getting some fade after a single hot lap and if I pushed too hard beyond that they faded HARD, like an old mountain bike (before disc brakes) after riding through a puddle.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
Captain Snooze (01-31-2014), suaveflooder (02-01-2014), SubieNate (02-02-2014), whataboutbob (02-01-2014)
Old 01-31-2014, 11:07 PM   #26
NYCsubaruBRZ
i have personally tested on 6 different cars/trucks solid vs drilled/slotted rotors and the stopping distance is night and day. try them for your self, you will see what im talking about
Old 01-31-2014, 11:26 PM   #27
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
At most, upgrade your brake pads and change your brake fluid to RBF600.
^GT5 Replay Photo Mode^
Old 01-31-2014, 11:44 PM   #28
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Drilled- looks good on the street but highest NVH, not recommended for track use due to a propensity to crack.
http://www.essexpartsblog.com/news/d...s-and-pad-wear
Disadvantages.
Discs can be prone to cracking unless care taken when bedding in.
The use of hard race pads (high friction level) can cause cracking giving the disc a limited life.
You will find today that most forms of car motor sport will use grooved discs.
http://www.apracing.com/products/rac...ake_discs.aspx
Disadvantages
Cracks tend to form around drilled holes under hard braking or track racing
http://www.racingbrake.com/v/main/tw...finish=Drilled
The reason why rotors were drilled in the first place was to relieve the gas that was created when the pad material started to breakdown (burn). Since modern pads don’t gas off any significant amount, this is simply not a concern.
http://automotivethinker.com/brakes-...d-and-warping/ (Thanks wparsons)
In today's cars, if you use cross-drilled rotors under heavy load, such as on the race track, you're losing structural integrity even more than with a slotted rotor, which makes your rotors much more prone to cracking. Cross-drilled rotors are considered visually appealing in many situations.
How do you feel about stock brakes? SillySaxon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 09-16-2013 09:26 AM
Stock brakes too weak? Alabang BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 111 09-13-2013 04:41 PM
What's everyone doing on stock brakes, for pads? Nourdmrolnmt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 05-15-2013 05:08 PM
FS: Stock front FRS Brakes(complete w/ lines) whiteout13FRS Brakes, Suspension, Chassis 0 04-12-2013 04:13 AM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
