Old 01-11-2014, 09:37 PM   #71
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Originally Posted by Ny Brz View Post
Just got the car back
Nice! How many threads left?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 01-11-2014, 09:41 PM   #72
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
3 in the front and 5 in back if I remember correctly.
Ny Brz is offline   Reply With Quote
The Following User Says Thank You to Ny Brz For This Useful Post:
*LongFella (01-11-2014)
Old 01-16-2014, 01:33 AM   #73
*LongFella
*LongFella's Avatar
Just installed mine tonight. I did 5 in the front and 7 in the rear... Weird... My a@@ is tucking tire, but my front still has gap?????? Thoughts?
Old 01-16-2014, 04:46 AM   #74
Subaru CBRZ 600RR
Drives: CBS BRZ MT, CBR 600RR
I'm at 16 in the rear and have at most a 1/4 inch gap, mine would be tucking too at 7.
Subaru CBRZ 600RR is offline   Reply With Quote
Old 01-16-2014, 10:00 AM   #75
*LongFella
*LongFella's Avatar
ST Coilover Pics
Makes sense now. I was looking at another members setup and how many threads they had left. Did a little more, but I need to bring up the rear and drop the front more...
Surprisingly, no issue driving to work this morning. No rubbing at all!
Old 01-17-2014, 12:22 AM   #76
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Here is the out-of-box height with shots taken at wheel level on stock wheels. There is a slight shadow cast by the fenders onto the tires but the wheels are not tucking into the fenders.
The Following 5 Users Say Thank You to switchlanez For This Useful Post:
chanomatik (01-29-2014), Chee-Hu (01-20-2014), jflogerzi (02-11-2014), JoeHK (07-28-2014), TeamZleep (01-18-2014)
Old 01-17-2014, 08:38 AM   #77
*LongFella
*LongFella's Avatar
Looks nice! My Coilovers in the box were all mess and not really set to any position :-/
Guess I need to keep adjusting them to find the sweet spot!
The Following User Says Thank You to *LongFella For This Useful Post:
switchlanez (01-17-2014)
Old 01-18-2014, 07:53 PM   #78
*LongFella
*LongFella's Avatar
Finally re-adjusted mine. 0 threads left in the front (maybe a half turn more I could go) and 13 left in the rear... Loving it now!
Size:  256.6 KBName:  ImageUploadedByTapatalk1390089184.752502.jpg
Old 01-22-2014, 11:20 PM   #79
jdmblood
jdmblood's Avatar
Drives: white subaru brz
anyone have pics of the st coilovers maxed out and dropped as much as possible?
jdmblood is offline   Reply With Quote
Old 01-22-2014, 11:27 PM   #80
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Does anyone have issues with the tire rubbing on the plastic fender liner under the fender?
Mine isn't an issue per say, but under certain cornering(sharp right hand turn transitioning from downhill to uphill) under full compression it rubs. I'm also running 245/40/18 tires, which are taller than stock
Old 01-23-2014, 12:02 AM   #81
*LongFella
*LongFella's Avatar
ST Coilover Pics
Mine have about a 3/4 turn left in the front. The rears, when I first installed them, had 7 threads left and it was low. I was tucking most of the tire. If I went max in the rear, I'd be scrapping my Perrin exhaust on everything (the pipe that extends down and into the muffler)...
jdmblood (02-22-2014)
Old 01-23-2014, 12:03 AM   #82
*LongFella
*LongFella's Avatar
I haven't rubbed at all, but I'm only running 225/40-18 all around. Full turn left and right... no issues...
Old 01-29-2014, 05:57 PM   #83
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
So out of the box are these preset to about a 1.5" drop? That's kinda what it looks like to me, since the Eibach Sportline lowering springs are 1.4" and these look to be about the same drop. Also, general n00b question: How do you adjust the height of these?
Old 01-29-2014, 06:10 PM   #84
*LongFella
*LongFella's Avatar
I don't think they "pre-set" height, so I wouldn't be comfortable saying what height it was at out of the box. Plus, mine were all lose and packed bad (enough to where I had replacement springs sent to me because of chipping)...
There's a little screw in the lower collar you loosen and just turn it to adjust height. Lower the collar, the lower the ride height. Higher the collar, the higher the ride higher. Tighten the little alan screw once set at about 1.5 ft/lbs (per instructions)...
I adjusted mine several times to find the look I was going for. I didn't even take the rim off when doing the adjustments... just jacked up the car and followed the above steps...
The Following 3 Users Say Thank You to *LongFella For This Useful Post:
akahenry (05-23-2015), chanomatik (01-29-2014), D5teph (05-25-2016)
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 04:38 PM
Pics of you!? Pics of your life?! seven Off-Topic Lounge [WARNING: NO POLITICS] 66 12-25-2012 05:49 AM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
