Old 01-08-2014, 10:53 PM   #57
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
ST Coilover Pics
Looks like I'm joining the ST club! Unfortunately, one of my rear coils and helper spring was damaged during shipment (nice chunks taken out of the yellow powder coat)... but a quick call to ST and they overnighted new coils for me!!! Their customer service is top notch!!!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following User Says Thank You to *LongFella For This Useful Post:
Bad Habits (01-09-2014)
Old 01-09-2014, 12:37 AM   #58
Bad Habits
Bad Habits's Avatar
Drives: br zed
Originally Posted by lgunnz View Post
Have you considered asking some of the guys on the site that professionally track their cars? Lots of them post regularly in the suspension and wheel sections. Shooting them a PM usually gets a response. Not to mention doing quick google searches can help a lot with installs, setups, and troubleshooting. I haven't installed anything on this car without first looking for help. It all turned out to be easy but having a refrence helped make me more confident. Of course after having 15 imports in various states of tune over the last 10 years helped too.
There are so many threads of "what tire and wheel combo works with stock brakes, which works with bbk's, which coil overs ride the best, the worst, which do this that and the other. I've been reading up on lots of info here and elsewhere and emailing lots of vendors direct to get the most correct info for what I am looking for. I'm sure I could install these over a weekend but I am fresh out of laser alignment machines at my house lol. Just would be nice to have a shop around that knew their ass from a hole in the ground.
Originally Posted by switchlanez View Post
If ST coilovers are indeed galvanized steel...
Got this reply from ST via email -
Galvanized Steel
Coming from the makers of KW suspension systems the only main difference between the ST Variant 1 and KW Variant 1 is the steel they use. While KW uses Stainless Steel for their shock housing, ST uses Galvanized Steel. However, this does not mean a drop in quality, durability, or appearance. Although coilovers that use galvanized steel are more prone to corrosion due to environmental influences (i.e. mixture of salt water); those in the lower states: California, Texas, Florida, Nevada, etc. don't have to worry about corrosion. Those in the mid to upper States that snow still don't have much to worry about as long as they do not drive in heavy snow conditions upon where salt is used on roads. to further ensure those with doubt about Galvanized Steel, ST has corrosion resistant zinc plating on all of their threaded strut housings for further protection.
Every year I head to spring training in Florida to see the Red Sox so that is a pricey trip but as soon as that is over and paid for there is a short list of a few mod's including the ST's I want to get started on. From what I can find these seem like the best bang for the buck for a decent ride and looks on a budget.
Bad Habits is offline   Reply With Quote
The Following User Says Thank You to Bad Habits For This Useful Post:
switchlanez (01-10-2014)
Old 01-09-2014, 05:26 PM   #59
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
after you order teh ST Coilover, what else do you need before the installation... camper bolts? camper plate?
Old 01-09-2014, 05:35 PM   #60
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
I opted camber bolts. You have to reuse oem top hats if you don't want aftermarket camber plates.
hanabie is offline   Reply With Quote
Old 01-09-2014, 05:39 PM   #61
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
what kind of camber bolts you got?
Old 01-09-2014, 05:43 PM   #62
hanabie
hanabie's Avatar
SPC 16mm camber bolts part number 81280
The Following User Says Thank You to hanabie For This Useful Post:
Lverasky (01-09-2014)
Old 01-10-2014, 09:38 AM   #63
*LongFella
*LongFella's Avatar
Originally Posted by Calavera View Post
Attachment 60049Attachment 60050
ST out of the box.
What are your ST's set at? Turns from bottom up?
I'm putting mine on this weekend and like how your stance is. I'm also running 18x8.5 +33 sq gram lights. Thanks for the help!
Old 01-10-2014, 06:57 PM   #64
mnecco
Drives: frs
I think he meant stock when he said "out of the box."
mnecco is offline   Reply With Quote
Old 01-11-2014, 05:06 AM   #65
Subaru CBRZ 600RR
Drives: CBS BRZ MT, CBR 600RR
at the height they come at right out of the box
Subaru CBRZ 600RR is offline   Reply With Quote
Old 01-11-2014, 10:03 AM   #66
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
so how more lower are you able to go before you max out?
Enraged21 is offline   Reply With Quote
Old 01-11-2014, 02:44 PM   #67
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Just got the car back
Ny Brz is offline   Reply With Quote
The Following User Says Thank You to Ny Brz For This Useful Post:
chanomatik (01-29-2014)
Old 01-11-2014, 02:55 PM   #68
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
You're not worried at all about driving those ST's through the salty snow?
Anomie is offline   Reply With Quote
Old 01-11-2014, 03:15 PM   #69
Ny Brz
Hella Flush
Ny Brz's Avatar
Supposedly because of the zinc plating it should be no problem. I dont drive her when or around when it snows, i drive my wife car.
Old 01-11-2014, 03:32 PM   #70
Subaru CBRZ 600RR
The front is maxed out and the rear is about midway. I think you could technically take out the helper spring in the front to go lower though. I'm no expert, but it seems to me the helper springs aren't doing much of anything because they are fully compressed.
I did not adjust the perches from this before installing.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 04:38 PM
Pics of you!? Pics of your life?! seven Off-Topic Lounge [WARNING: NO POLITICS] 66 12-25-2012 05:49 AM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
