Sam Strano
Old 01-09-2014, 10:19 AM   #519
piknockout
Drives: 2014 BRZ
Originally Posted by AustinTX View Post
Des is driving the FR-S, which will likely need more bar than the BRZ due to the spring rates. I plan to start the year on the stock bar and hope to leave it that way. I've already got the catback, Koni's, camber bolts, RPF-1's, and 235 Z2's. Can't wait to get started learning to push it
John
This is cute and all, but can't wait to play against you in STX soon. :p
piknockout is offline   Reply With Quote
Old 01-09-2014, 11:24 AM   #520
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I believe I am done with owning full prep cars for a while. If anything, I will codrive with someone else This car will stay in Street (or be a DD if not competitive).
Autocross nut
AustinTX is offline   Reply With Quote
Old 01-09-2014, 01:12 PM   #521
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Originally Posted by DylanFRS View Post
I am running the 20mm Whiteline on the softest setting on an FR-S and I wish it a bit softer. I wanted to reduce rotation and it reduced it a bit more than I would have liked.
Per Whitelines chart the 20mm FSB is only 52% stiffer than the factory 18mm bar on the soft setting and 85% stiffer on the hard setting.
2superblus is offline   Reply With Quote
Old 01-09-2014, 02:04 PM   #522
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Which is why I am surprised that it took out too much rotation. Hard to get something much softer... I am going to see how it is on the ZIIs vs the RS3s I used to have.
DylanFRS is offline   Reply With Quote
Old 01-09-2014, 02:47 PM   #523
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
John
I'll be interested to see if you can make this work. It may be because I may be too abrupt with my turn-in input (too many years of driving wide hoosiers on the front wheels), but I couldn't keep the back end under the car in slaloms with my setup last year (BRZ w/ OE front bar OE dampers, and crash bolts). I had the issue even with the OE tires. Grogan also had the issue when he drove my car at Toledo on Rivals after I had installed the Konis.
Not that this is a very good datapoint, but just my experience. I already have Konis on the car now and have a plan for how I will be attempting to fix it in the spring, we'll see how it goes.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 01-09-2014, 05:48 PM   #524
xwd
I don't really trust the WL generic charts, I think it's a little stiffer than that.
I felt Sam's bar was somewhere in the middle of the WL bar's two settings and his is supposed to be "85%" stiffer than stock.
Old 01-09-2014, 08:55 PM   #525
Rexpelagi
Drives: 2013 Subaru BRZ
Go home STU, you're drunk.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 01-09-2014, 11:12 PM   #526
Biggins
Drives: Yes
Well, since I have not heard of anyone trying the Yokohamas yet, I'll be the guinea pig. I just ordered a set in 225/45/17 since they're on sale right now. I ran the Z2s all last year, so we'll see if the Yokohamas are worth the extra coin.
Biggins is offline   Reply With Quote
Old 01-10-2014, 05:54 AM   #527
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Definitely keep us updated about the Yokohamas. I'm interested to hear how they do, even though they'll only be legal for this year. Assuming Yokohama doesn't just change the treadwear rating like Hankook did for the RS3s.
G_Ride is offline   Reply With Quote
Old 01-10-2014, 12:30 PM   #528
piknockout
Drives: 2014 BRZ
Nope, I was drunk when I was actually considering running CS.
Old 01-10-2014, 04:13 PM   #529
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Old 01-13-2014, 04:07 PM   #530
Biggins
Drives: Yes
Has anyone found any additional eligible and relevant wheels for next season? It sucks we still have so few (one) good options.
Old 01-13-2014, 05:01 PM   #531
DylanFRS
Lost in Kansas
DylanFRS's Avatar
I think I am going to pick up a set of Kosei K4Rs and run spacers. 14lbs for $200 a piece.
Old 01-14-2014, 04:12 PM   #532
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so skimming over all the other threads, it seems the Ferodo DS2500 brake pads are the way to go for for a balanced performance/street use?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
