Old 01-08-2014, 12:32 PM   #505
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by brianL. View Post
I spoke with a SCCA Solo Technical Manager and he said I could go up 1" in wheel size bringing me to 18" in this class.You are saying 17" though.I want to know what I can use before I buy wheels and tires.
Originally Posted by G_Ride View Post
You can use 16x7, 17x7, or 18x7 with offset between +42 to +54. At that point it comes down to tire size availability.
What @G_Ride said.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 01-08-2014, 12:36 PM   #506
brianL.
brianL.'s Avatar
Drives: BRZ/1J Supra
I couldn't find that in the rule book where did you find it. I thin I will take the SCCA Solo Technical Manager and your word for it since he is a reliable source.
By the way what is the best front sway bars that you guys are running? I want adjustable since this is a street car but I want to hear everybody's input
brianL. is offline   Reply With Quote
Old 01-08-2014, 12:50 PM   #507
dsgerbc
Drives: BRZ(sold), STI
Ask SCCA Solo Technical Manager then?
Old 01-08-2014, 01:06 PM   #508
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
The wheel allowance was discussed in fastrack earlier in 2013, and it's also in the draft version of the 2014 rules book.
As for sway bars, I installed the Sam Strano bar.
G_Ride is offline   Reply With Quote
Old 01-08-2014, 01:21 PM   #509
Kido1986
Dodging cones
Kido1986's Avatar
Strano bar here as well. Most aftermarket bars for this car are too stiff. Strano's the weakest increase over stock on the market, as it needed some front bar but not crazy amount.
Old 01-08-2014, 01:39 PM   #510
des
des's Avatar
Think the Cusco 20mm is actually closest to stock. It needs more.
I run a lot of toe to keep it in line, and it's still too loose.
des is offline   Reply With Quote
Old 01-08-2014, 01:51 PM   #511
Kido1986
Dodging cones
Kido1986's Avatar
Oh really? I know it's smaller than Strano's but is the stiffness lower? What is the percentage? Strano's is 85% over stock.
Old 01-08-2014, 01:55 PM   #512
Kido1986
Dodging cones
Kido1986's Avatar
Edit2: Googling it showed 74% so I guess it is softer than Sam's 85%. I stand corrected.
Old 01-08-2014, 02:06 PM   #513
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Des is driving the FR-S, which will likely need more bar than the BRZ due to the spring rates. I plan to start the year on the stock bar and hope to leave it that way. I've already got the catback, Koni's, camber bolts, RPF-1's, and 235 Z2's. Can't wait to get started learning to push it
John
Autocross nut
AustinTX is offline   Reply With Quote
Old 01-08-2014, 02:20 PM   #514
Biggins
Drives: Yes
Perrin 19mm *should* be softer than Strano as well, depending on the setting. I had the massive Hotchkis last year, still deciding what I want this year.
Biggins is offline   Reply With Quote
Old 01-08-2014, 02:24 PM   #515
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I am running the 20mm Whiteline on the softest setting on an FR-S and I wish it a bit softer. I wanted to reduce rotation and it reduced it a bit more than I would have liked.
DylanFRS is offline   Reply With Quote
Old 01-08-2014, 04:04 PM   #516
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
You want to run in STX against me, that's what you want!
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 01-08-2014, 04:19 PM   #517
brianL.
brianL.'s Avatar
Thanks guys
Old 01-08-2014, 04:31 PM   #518
Rexpelagi
Drives: 2013 Subaru BRZ
Keep in mind that the tire you choose may require a completely different setup (bar, alignment, shock settings) than that of someone running a different tire. When jdrxb9 and I tested ZII's vs. RS-3's on his car without changing setup the balance was significantly different. Obviously BRZ vs. FR-S is also a factor.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
