Old 01-13-2014, 10:54 AM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Small dent in exhaust leading to muffler
Don't hate me too much but while backing up my car at a parking lot with quite a bit of snow, I backed into a parking curb. Luckily it didn't touch any of the bumper at all (as far as I can tell) but the bottom of the muffler got a few shiny scratches (no biggie) but it seems to have slid under the muffler and put a slight dent into the curvy part of the mid pipe.
I'd estimate at max depth, ~1/3 of a cm dimple. Anyone with experience in bottoming out and denting the exhaust / share on any issues resulting from it?
I realize that yes, diameter is effectively reduced but can't be by much...will try and get some photos.
It was stock (thankfully) and I'll likely be replacing with a 2.5 perrin by summer.
Thanks
1Cor10:23 is offline   Reply With Quote
Old 01-13-2014, 11:08 AM   #2
Thorpedo
The SquadWhisperer
I would get it fixed personally. 1/3 of a cm is WAY beyond acceptable tolerances and will likely lead to premature muffler bearing failure....
Thorpedo is offline   Reply With Quote
The Following 4 Users Say Thank You to Thorpedo For This Useful Post:
ciro (01-23-2014), DAN_BRZ (01-13-2014), DocWalt (01-14-2014), wparsons (01-13-2014)
Old 01-13-2014, 11:08 AM   #3
Originally Posted by 1Cor10:23 View Post
Don't hate me too much but while backing up my car at a parking lot with quite a bit of snow, I backed into a parking curb. ....
Thanks
I wouldn't worry about it.
I've put a few dents in my mid-pipe by creeping over my retarded driveway/sidewalk apex. It seems the mid-pipe is rather strong.
As far as restricting exhaust flow, I figure there are squashed parts of the OEM exhaust system, further upstream, that are more restrictive.
I'd suggest that you pull into those parking places forward ..... so that you can tell where the parking stop is .... by the sickening, screeching sound coming from the front clip as it gets torn up ....
Old 01-13-2014, 11:10 AM   #4
1Cor10:23
1Cor10:23's Avatar
As far as restricting exhaust flow, I figure there are squashed parts of the OEM exhaust system, further up stream, that are more restrictive.
I'd suggest that you pull into those parking places forward ..... so that you can tell where the parking stop is .... by the sickening, screaching sound coming from the front clip as it gets torn up ....
I do pull in haha, it's just that the one on the way back out of the spot was ridiculously close...(was the curb to a restaurant, not another parking spot). Whoever designed it really didn't give much clearance for people backing out.
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
humfrz (01-13-2014)
Old 01-13-2014, 11:11 AM   #5
1Cor10:23
1Cor10:23's Avatar
1/3 of a CM would do that? As @humfrz stated below, just by feeling around the pipe I can see that OEM moulding has more restrictive spots than that to give ot clearance from the underbody at certain points that jut out.
EDIT: Looks like I should've read that more carefully. I see what you did there.. @Thorpedo
Old 01-13-2014, 12:21 PM   #6
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
man i hate replacing muffler bearings ahha
DAN_BRZ is offline   Reply With Quote
Old 01-13-2014, 02:09 PM   #7
TwinturboCamry
Drives: 4 wheels
My outer bearings got spun and cost me $300 EACH.
TwinturboCamry is offline   Reply With Quote
Old 01-13-2014, 09:19 PM   #8
zooki
Drives: waiting on a 2021...
$300 apiece? That's why I get mine here:
http://kalecoauto.com/index.php?main...products_id=48
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following 2 Users Say Thank You to zooki For This Useful Post:
canon_spec (02-28-2015), Thorpedo (01-14-2014)
Old 01-14-2014, 06:43 PM   #9
1Cor10:23
1Cor10:23's Avatar
Ok, so here's a photo - I'd probably escalate the damage to slightly above ~1/3 cm in max depth.
Old 01-14-2014, 07:01 PM   #10
Foobar
SLO NO MO
Foobar's Avatar
Thats nothing. Don't worry about it - your stock overpipe has worse pinches than that.
The Following User Says Thank You to Foobar For This Useful Post:
1Cor10:23 (01-14-2014)
Old 01-14-2014, 10:54 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
They always seem to go when you run out of blinker fluid too. That is the real PITA to refill to the proper amount
DAN_BRZ (01-16-2014)
My Perrin Catback Exhaust came with a Dent goshem Engine, Exhaust, Transmission 15 11-14-2013 11:13 PM
Dent :( Will paintless dent removal be able to get this out? Greg_Di CANADA 22 08-31-2013 11:22 PM
Keep stock muffler with other exhaust mods? jordanrw260 Engine, Exhaust, Transmission 51 03-23-2013 10:38 AM
Made a small ding/dent ... any tips on how to get it out? shawn Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-23-2012 01:08 PM
