Old 01-09-2014, 11:18 PM   #617
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Hello, thanks for the Post.
I live in Peru and the roads here suck. I drive my gt86 daily and also track and autocross once or twice per month, sometimes drift . I want to uograde suspension(coiovers) I ride 18x8.5 / 18x9.5 Work wheels.
i looking forwand something comfort for the city and performance for track and autocross. What do you recomend me? Wich brands and models ? So I need camber plates or coilover w/camber included?
Thanks
Toyota GT 86 is offline   Reply With Quote
Old 01-10-2014, 12:11 AM   #618
Turdinator
Señor Member
Turdinator's Avatar
Thanks
I think you might want to give an indication of your budget also.
1974 TA22 Celica
2013 86 GT
Old 01-10-2014, 09:32 AM   #619
Toyota GT 86
i think something around 2000 -2500 $usdollars. What do you think? I could spend a bit more if you tell me that the best for me is something more expensive.
Old 01-10-2014, 09:38 AM   #620
Malt
Drives: 2015 WRX
RCE T2's ride better than stock and I can already tell a massive difference in handling. How much of that is the alignment I don't know, but I'm very happy with my purchase. The T2's have a slotted to mounting hole on the struts and I think the alignment shop got around -2 degrees of camber without even touching my camber plates with a one inch drop in ride height.
Malt is offline   Reply With Quote
The Following 5 Users Say Thank You to Malt For This Useful Post:
normancw (01-10-2014), OjiGeorge (01-13-2014), Racecomp Engineering (01-20-2014), Toyota GT 86 (01-12-2014), whataboutbob (01-10-2014)
Old 01-10-2014, 10:07 PM   #621
Malt
Drives: 2015 WRX
Originally Posted by normancw View Post
Any more details of the ride and handling difference? I wasn't expecting the T2s to ride better, with the 400/400 lbs/in spring rate (vs 131/211 stock).
I think a large part of it comes from the superior dampening from the springs and struts. The really big bumps might be a little jarring, but for the most part when set really soft, the ride is pretty cush. Turned up to the settings that Myles suggested and posted on RCE's facebook page the harshness is acceptable and handling is noticeably better. I still have to install my rear upper bushings and get another alignment since I failed to do so before the first alignment but I am completely satisfied and recommend them without hesitation! Myles and the RCE team are always there to answer any questions you may have about them so shoot them a PM or give them a call. I'm sure they can answer any questions better than I can.
The Following 2 Users Say Thank You to Malt For This Useful Post:
normancw (01-10-2014), Racecomp Engineering (01-11-2014)
Old 01-11-2014, 04:12 PM   #622
brillo
Drives: 2013 Firestorm FR-S
Can the steering bushings be installed with the steering wheel locked so you don't mess with your steering alignment? Is there enough play in the rack to unbolt it and remove the stock bushings?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 01-11-2014, 04:15 PM   #623
Stevo22
Stevo22's Avatar
Drives: GR86
I read in another thread that people have done that and it worked. The did not have to get alignment afterward.
Stevo22 is offline   Reply With Quote
Old 01-11-2014, 04:19 PM   #624
brillo
I have the tic bushings but also some whitelines and I thought about installing the whitelines to see if I feel a difference. The tic bushings were installed when I did an alignment so I didn't do it myself. I imagine the tic bushings are a lot easier to remove than the stock ones
Old 01-11-2014, 05:03 PM   #625
Calum
That Guy
Drives: 2013 asphalt FRS MT
You don't need to take the rack out of the car, from what I've read. I did take mine out when I did mine, of course even after marking and rack the column it didn't go back in right. But either way it wont effect the alignment, only the angle of the steering wheel.
Old 01-12-2014, 10:38 AM   #626
brillo
Are the solid aluminum bushings easy to remove? I would think they would pop right out .
Old 01-12-2014, 01:13 PM   #627
CSG Mike
CSG Mike's Avatar
Ride quality is mostly determined by damper quality, not spring rates. If the suspension is doing it's job and isolating the road from the chassis, while maximizing contact patch/time, then the car will ride shockingly well.
normancw (01-12-2014)
Old 01-12-2014, 03:52 PM   #628
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I'm getting AP Sprint brakes and RS3s on RPF1 rims. However if it rains, I'd like to use the Pilot Super Sports on my stock rims. I know that the stock rims will fit with 10mm spacers. Is it OK to track with 10mm spacers?
I'd get extended studs. With that you should be golden.
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Old 01-12-2014, 07:16 PM   #629
johnnie
Drives: GT86
Hi guys,
My goal is to have a bit faster cornering but to maintain the fun factor by still being hable to kick the tail at sane speeds, keep in mind my baseline is a eurospec gt86.
Im going with 17x9 ET42 rims, not ideal i know, but its my cosmetic tradeoff. I already have camber bolts for the front too.
Everything else im undecided and needed your advice.
Im thinking of getting eibach prokit springs and either slightly stretched 225/45/17 or 235/40/17 tires. Nothing too sticky, probably falkens or hankooks.
Is thiis a good setup for my goals? Roughly what should be my alignment specs? Should i get stiffer front or rear swaybars?
Cheers guys, awesome thread!
johnnie is offline   Reply With Quote
Old 01-12-2014, 08:09 PM   #630
Malt
Drives: 2015 WRX
Originally Posted by johnnie View Post
Hi guys,
Correct me if I'm wrong, but both of those tire sizes seem way too narrow for a 9" wide rim.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
