Northwest AK, ID, OR, WA
Old 01-12-2014, 04:01 PM   #1
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Roof spoiler issues
I applied my roof spoiler, fitment was great. I made sure that 3m tape was on stuck on there. Used a heat gun to make sure it cured. Made sure the surface was clean. Regardless of all the work. This morning i found more than half of the spoiler hanging in the air. Anybody know how to get the 3m tape reapplied so i can reinstall my spoiler.
Chen is offline   Reply With Quote
Old 01-12-2014, 04:04 PM   #2
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Get industrial 3m tape
DrDuquette is offline   Reply With Quote
Old 01-12-2014, 04:07 PM   #3
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
even you think the surface is clean, probably it still has wax on it. you will have to use wax and grease remover to clean it, then apply adhesive promoter on it before peeling off 3M tape and put your spoiler on.
#944_10_Series_FRS is offline   Reply With Quote
Old 01-12-2014, 04:10 PM   #4
Chen
Regional Moderator
Chen's Avatar
I have no problem getting new tape, i just dont know how to reapply it to the tape to the spoiler.
Gaw, wish this crap just worked.
Old 01-12-2014, 05:31 PM   #5
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
Most tape applications need to be done during warm days because the "curing" is not instant. If you apply it and heat it but then a couple hours later you go out to the wet and relatively cold of our area it's probably not going to stay together. I think it needs to be installed in a 60 degrees or higher.
BTW, the word is "fit" not "fitment". - Language Police LOL
Rio is offline   Reply With Quote
Old 01-12-2014, 05:44 PM   #6
ramiram1984
Drives: 2016 STi DGM
^^ but I wanna cruise around and show off my spoilerrrrrr already :/
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 01-12-2014, 05:56 PM   #7
Chen
Regional Moderator
Chen's Avatar
Youre uninvited to wednesday.
Jk.
Im just gonna buy more 3m tape than.
Old 01-12-2014, 06:03 PM   #8
Rio
Rio's Avatar
ROFL
Jk.
Wait... I'm actually trying to find out the tape that my friend uses on his line of work.
Old 01-12-2014, 06:16 PM   #9
Rio
Rio's Avatar
Good News and Bad News
Good news is that I found out what kind of tape you need: 3M™ Acrylic Plus Tape Series EX4000
Bad news is that you still have to warm up the surfaces then apply in a kinda warm environment (garage) for a couple hours. He said the trick is that both surfaces need to be warm, but "for the love of pete don't use a heat gun on the paint job". I laughed when he said that. He recommends using a couple heat packs. I thought that was a very ingenious solution.
Old 01-12-2014, 06:33 PM   #10
Chen
Regional Moderator
Chen's Avatar
Thanks for the update rio. I want my spoiler on there now! Would I have to hear up the garage or wha?
Old 01-12-2014, 06:45 PM   #11
Rio
Rio's Avatar
Yep. Heat it up to about 55 degrees. And but make sure you heat to the surfaces. That's the most important part.
Sent from my SGH-T999 using Tapatalk
Old 01-12-2014, 07:03 PM   #12
Chen
Regional Moderator
Chen's Avatar
How long does the car hsve to sit afterwards?
Old 01-12-2014, 07:37 PM   #13
NickFRS
Drives: 2013 Asphalt FRS
If you can find a white board remover cleaner use that. It will rough up the wax. Mine stuck on and wont even budge My 5ax spoiler on the other hand.... quite sure i'll need to take it off and re apply that...
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-12-2014, 07:39 PM   #14
Rio
Rio's Avatar
Overnight in your garage. Let's summarize and give you more details:
1. Clean well with goo gone.
2. Use some hand warmers or heat pad and warm of the surfaces.
3. After the surface feels like it's over 70 degrees then install.
4. Use hand warmers and place them on top of spoiler using a soft rag so they do not make direct contact with any paint or finish.
5. Cover with a blanket.
6. It is your turn to crawl under a blanket.
I really liked the hand warmer touch because they last up to eight hours.
The Following User Says Thank You to Rio For This Useful Post:
humfrz (01-13-2014)
Roof Spoiler Compilation NemeGuero Cosmetic Modification (Interior/Exterior/Lighting) 26 12-27-2015 04:25 PM
Will someone please make a more aggresive roof spoiler? FTEIGHTSIX Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2013 05:32 AM
Color Matched Roof Spoiler? DNAPoPo Cosmetic Modification (Interior/Exterior/Lighting) 4 03-19-2013 02:00 PM
FS: Stillen roof spoiler. [MELB] blags Australia Classifieds 0 02-26-2013 02:28 AM
