Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 01-10-2014, 06:34 PM   #1
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
**PHASTEK** Winjet Complete Fog Light Kit - $109.95 Shipped
[ame]http://youtu.be/8A-s4zayNzw[/ame]
Remember that FT86Club members qualify for 5% off. Please see signature for code.
Order here:
http://www.PhastekSPORT.com/Scion-FR...#ixzz2q2XPkERq
Complete Fog Light Kit by Winjet for 2013, 2014 Scion FR-S
Winjet has produced a complete solution for USDM Scion FR-S'. Now you can add a full fog light kit without breaking the bank. This is a clean install and utilizes the blank slot next to the interior dimmer switch to control on/off functions.
Includes:
Gloss Black Bezels
12V relay with Fuse
OEM style Switch
Fog light casings with glass lenses and halogen bulbs (upgradeable)
Quick install video for the switch:
[ame]http://youtu.be/JykXGNfsVi8[/ame]
Phastek Sport Coverage of Winjet at SEMA 2013
PhastekSport is offline   Reply With Quote
The Following User Says Thank You to PhastekSport For This Useful Post:
nbafandan (01-11-2014)
Old 01-10-2014, 07:31 PM   #2
vincent201089
vincent201089's Avatar
Drives: frs
Do you know if this will work with nokya h11 yellow bulb?
vincent201089 is offline   Reply With Quote
Old 01-10-2014, 07:42 PM   #3
PhastekSport
Yes. It is an H11 bulb. For those of you who purchased Winjet headlights and have spare H11 HIDs from the OEM headlights, here is your chance to use them again!
Sent from my SAMSUNG-SM-N900A using Tapatalk
vincent201089 (01-10-2014)
Old 01-11-2014, 12:03 PM   #4
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can you contact Winjet and see if you can get just the switch? I'd love to order one.
post_break is offline   Reply With Quote
Old 01-11-2014, 01:40 PM   #5
nbafandan
Phantom
Drives: Whiteout MT
Agreed, I would be interested aswell
Does anyone know the size of the oem button?
nbafandan is offline   Reply With Quote
Old 01-11-2014, 02:39 PM   #6
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Can these be used if you have the BRZ stalk, I have a premium and am looking into adding fogs
Ny Brz is offline   Reply With Quote
Old 01-13-2014, 12:25 PM   #7
PhastekSport
You have the auto leveling button already next to the dimmer right? Does your stalk have the fog light setting? You'd probably be better off in just buying the housings and wiring them up to a different switch. I'm pretty sure you're button is going to be occupied already, and you need different bezels...
Winjet does not plan to sell the switch alone. Contact me though, and I'll give you some additional information.
Old 01-13-2014, 12:50 PM   #8
Ny Brz
Hella Flush
Ny Brz's Avatar
Thanks Chris, sorry i should have been more clear. I have a BRZ premium, the stalk does not have the fog light feature on it. Its basically like the FRS, i think i would be able to use that manual switch that's inclued. I just want to know if the fogs would fit in the location where the BRZ Bezel would be.
Old 01-13-2014, 01:59 PM   #9
PhastekSport
I understood :-). I just wasn't sure if the premium stalk had something there despite the fact (figured it wouldn't, but I've seen crazier stuff).
The area that it fills is:
Don't you have the HID leveling switch here?
The fog lamps would fit though.
Old 01-14-2014, 08:44 AM   #10
JohnnyP
Drives: 2013 Whiteout Scion Fr-S
So is the trunk release button the "blank slot next to the dimmer switch" where the fog light switch installs? You have to remove the trunk switch to install fog light switch, right?
JohnnyP is offline   Reply With Quote
Old 01-14-2014, 12:43 PM   #11
PhastekSport
No no no.
See where the FR is written? That is the dimmer switch for the gauges and such. The blank right next to it doesn't have a switch occupying that slot currently. This is in the FR-S.
The BRZ most likely has the auto leveling for the HID right here (pictured below). Found that picture on Google Images. I believe it is from a member here.
Old 01-14-2014, 02:24 PM   #12
xdudefromheaven
I'm a noob
xdudefromheaven's Avatar
Drives: Black Raven Scion FRS
I would like to get one soon but do you guys have it on HID?
xdudefromheaven is offline   Reply With Quote
Old 01-14-2014, 03:16 PM   #13
PhastekSport
We do have h11 kits in stock...
http://www.phasteksport.com/2013-Sci...id-kit-h11.htm
Link is for the headlights, but they are the same bulb. I've run 35w kits in the same style housing before with no issues.
Old 01-14-2014, 03:34 PM   #14
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Does it come with the bezel for the dash to add the switch? Or just the switch? The OEM bezel doesnt have a removable blank spot there its a flat space there.
Fett4Real is offline   Reply With Quote
fog light, fog light kit, frs
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
**PHASTEK** Winjet JDM Replica Headlight and Tail Light Thread PhastekSport Exterior Parts - Lighting 62 04-22-2015 04:15 AM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
*Phastek* Winjet Coverage @ SEMA 2013 - JDM Replica Headlights, Fogs, Tails PhastekSport Cosmetic Modification (Interior/Exterior/Lighting) 82 03-09-2014 12:32 AM
Winjet JDM Style Headlights Groupbuy --> Round 2 Now Open!! 86_ZN6 Groupbuys 206 02-13-2014 05:45 PM
