#2591 |
So let's do some math:
Diameter is -5mm It makes contact with let's say 50% of the circumference 3.14*(5)*.5= 7.85mm smaller belt is needed
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#2592 |
Drives: Attitude
#2593 |
WUB WUB
Drives: 2013 Firestorm
question about a boost gauge. one user said that they drilled/tapped the map sensor plate on top of the blower. is there no other way to connect one? I've been searching the forums as well as online, and haven't seen anything else yet.
#2594 |
That Guy
Drives: 2013 asphalt FRS MT
Nameless showed pics of a plate to allow you to install a boost gauge, I don't know if it's on their site, but you could give them a call. Or, you could call FA20club as about a week later they started making a similar product.
#2595 | |
WUB WUB
nope, not on their site. only thing i could find about it was that thread that someone posted a pic off their facebook page. still searching.
#2596 |
Drives: 2013 SWP BRZ
@wrxgoose - theres a fitting on the back of the supercharger thats meant for a vacuum hookup. its an odd size though IIRC but i'm sure its no problem ordering it online. Look a few pages back, pretty sure @Ryan86 pointed this out.
Well IC install is going to have to wait until monday...god damn UPS decided to "delay" my package because of the 2 inches of snow we got...WTF. I hate UPS so much. They need to start delivering saturday like every other goddamn shipping company. |
#2597 | |
WUB WUB
edit: also, if i remember correctly, there's more than one fitting back there.
#2598 | |
http://www.ft86club.com/forums/showp...&postcount=173 Its a 5mm plug. |
#2599 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Here is a pic. We had to taper the hole bigger to get the fitting we have locally in. |
#2600 |
WUB WUB
thank you both very much. you've made my work to install the gauge much much easier.
#2601 |
Road Warrior
I must have a dud kit, put the car on the dyno and did a load test to find boost pressure forcing coolant out the cooler bottle.
Back home taken kit off again, took the cooler in for pressure test to find the actual cooler is leaking under pressure. Stripped the cooler, there 8 o rings on cylinders, 2 o rings were of poor quality, added new o rings sealed, pressure tested at 0.7 bar no leak and then took it up to 1.5 bar, held for 5 minutes no leak. I have a lot of coolant go into the manifold, had to do some cleaning in the ports. Mechanics had a look say car is good no damage. So if any of you notice small amount of coolant leaking or coolant bottle draining either from boost or vacuum, be Alert. The car will also feel very jerky from 2000 to 3000 under normal driving. Unfortunately all the logs I took, did not pick anything up. Another recommendation is have your cooler pressure tested prior to install, just as a precaution if you can, as it is extremely frustrating taking the kit off. Especially after 4 times. I'm now a qualified SC installer, takes me 1 hour ![]() Thought I'd share... |
#2602 | |
#2603 |
That Guy
#2604 |
Dismember
Drives: 2013 Red Scion FR-S
Ryan, you have the worst luck on this kit.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
