Old 01-10-2014, 01:51 PM   #2591
swift996
swift996's Avatar
So let's do some math:
Diameter is -5mm
It makes contact with let's say 50% of the circumference
3.14*(5)*.5= 7.85mm smaller belt is needed
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
whataboutbob (01-10-2014)
Old 01-10-2014, 04:17 PM   #2592
OrbitalEllipses
Drives: Attitude
Do sum wat thar now, boy?
hyuck hyuck
King Tut (01-13-2014)
Old 01-10-2014, 09:34 PM   #2593
wrxgoose
WUB WUB
Drives: 2013 Firestorm
question about a boost gauge. one user said that they drilled/tapped the map sensor plate on top of the blower. is there no other way to connect one? I've been searching the forums as well as online, and haven't seen anything else yet.
wrxgoose is offline   Reply With Quote
Old 01-10-2014, 09:37 PM   #2594
Calum
That Guy
Drives: 2013 asphalt FRS MT
Nameless showed pics of a plate to allow you to install a boost gauge, I don't know if it's on their site, but you could give them a call. Or, you could call FA20club as about a week later they started making a similar product.
Old 01-10-2014, 09:42 PM   #2595
wrxgoose
WUB WUB
nope, not on their site. only thing i could find about it was that thread that someone posted a pic off their facebook page.
still searching.
Old 01-10-2014, 10:08 PM   #2596
xxscaxx
Drives: 2013 SWP BRZ
@wrxgoose - theres a fitting on the back of the supercharger thats meant for a vacuum hookup. its an odd size though IIRC but i'm sure its no problem ordering it online. Look a few pages back, pretty sure @Ryan86 pointed this out.
Well IC install is going to have to wait until monday...god damn UPS decided to "delay" my package because of the 2 inches of snow we got...WTF. I hate UPS so much. They need to start delivering saturday like every other goddamn shipping company.
xxscaxx is offline   Reply With Quote
Old 01-10-2014, 10:16 PM   #2597
wrxgoose
WUB WUB
i think my friend and i may try to do it this weekend. and since i work at pep boys, i doubt i'll have any trouble finding a piece that'll work
edit: also, if i remember correctly, there's more than one fitting back there.
Old 01-10-2014, 10:25 PM   #2598
xxscaxx
Here we go, found Ryan's post.
http://www.ft86club.com/forums/showp...&postcount=173
Its a 5mm plug.
The Following User Says Thank You to xxscaxx For This Useful Post:
wrxgoose (01-10-2014)
Old 01-10-2014, 10:29 PM   #2599
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
The small silver screw at the back of the charger is where you can hook up boost pipe. I fitted a ProSport mechanical gauge as Delicoius Tuning use the Stock MAP sensor and can't read boost off the ECU.
Here is a pic.
We had to taper the hole bigger to get the fitting we have locally in.
Ryan86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
whataboutbob (01-10-2014), wrxgoose (01-10-2014)
Old 01-10-2014, 10:53 PM   #2600
wrxgoose
WUB WUB
thank you both very much. you've made my work to install the gauge much much easier.
Old 01-11-2014, 07:53 AM   #2601
Ryan86
Road Warrior
Ryan86's Avatar
I must have a dud kit, put the car on the dyno and did a load test to find boost pressure forcing coolant out the cooler bottle.
Back home taken kit off again, took the cooler in for pressure test to find the actual cooler is leaking under pressure.
Stripped the cooler, there 8 o rings on cylinders, 2 o rings were of poor quality, added new o rings sealed, pressure tested at 0.7 bar no leak and then took it up to 1.5 bar, held for 5 minutes no leak.
I have a lot of coolant go into the manifold, had to do some cleaning in the ports.
Mechanics had a look say car is good no damage.
So if any of you notice small amount of coolant leaking or coolant bottle draining either from boost or vacuum, be Alert. The car will also feel very jerky from 2000 to 3000 under normal driving. Unfortunately all the logs I took, did not pick anything up.
Another recommendation is have your cooler pressure tested prior to install, just as a precaution if you can, as it is extremely frustrating taking the kit off. Especially after 4 times. I'm now a qualified SC installer, takes me 1 hour
Thought I'd share...
EAGLE5 (01-11-2014), whataboutbob (01-12-2014)
Old 01-11-2014, 08:35 AM   #2602
swift996
swift996's Avatar
I'd contact Sprintex or whoever sold the kit. Sounds like a bad unit you got.
Ryan86 (01-11-2014)
Old 01-11-2014, 10:38 AM   #2603
Calum
That Guy
Good idea, Yoda.
Old 01-11-2014, 10:39 AM   #2604
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Ryan, you have the worst luck on this kit.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ryan86 (01-11-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
