Old 01-10-2014, 12:49 AM   #3039
MidnightRunner
MidnightRunner's Avatar
Originally Posted by silent runner View Post
Your absolutely right of course about, doing the same stuff as a full time supercharger. The real fun is definetly in the gains to be found for the investment (which I believe is a pretty honest number so far), and the fact that you can probably do this without having a finicky, breaky car. Had a talk with the TRD, and enthusiast Sales guys at my local Toyota dealer today.... right now the are "fixing" a local guys FRS. He figured he could adapt a Suby turbo system to the car (with 16lbs of boost). Now he is nursing the car through a $12,000, engine replacement. I walked out and looked, and it was messy!
Makes this option look quite reasonable for the fun quotient.
-Country Hills Toyota, Calgary Alberta, was where I talked to the guys fixing this poor little busted FRS, by the way.
Ouch. That must really really suck for that poor fella. I'm positive that he could've ran his car at 8 to 10 pounds and not have any problems with his engine kicking the bucket.
FI isn't for everyone I guess, and for me it's a matter of risk vs. reward.
This ESC with the Nameless header might be an amazing combo, or you could shell out the dough and go full time FI. I'm still undecided.
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 01-10-2014, 08:41 PM   #3040
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
I'm a little surprised myself, that a guy with some portion of the knowledge to mount this system, didn't have the additional sense to take it easy in developing it. You don't just go and weld on a big turbocharger to any engine, let alone a 12:1 compression ratio engine that is already doing 200hp at the fly-wheel! Even "Scotty", never offered up 200% of the warp engines capabilities to Captan Kirk.
The FRS/BRZ cars are not "super-cars", but for a pretty reasonable amount of money, owners can overcome their principle weakness and make them a lot more fun to drive. This is the guiding principle behind the best and most successful car-anything upgrades.
I'll just add a little bit here to plug the ESC/Phantom idea.... I like that it is a huge upgrade in performance, but with some limits. Experience has shown me (personally), that boost is an addicting experience. My old '89 Mazda 626 was one of the fastest family sedans on the road in the early 90's. It was actually faster than alot of performanced classed cars at it's 7.3psi stock boost. At a modded 12psi of boost, it was knocking off the best Mustangs, and toying with some of the very best of the stock imports. At 16psi, it started jumping out of gear at 70mph, while having problems with the clutch (any clutch I could find actually) hooking up.
The ESC/Phantom idea, gives you a huge upgrade, and some reasonable limitations for the cost. Enough to make the car alot more fun, but not so much potential that it will burn holes in your brain about what 5 more psi could do, and make you finally wreck the car.
silent runner is offline   Reply With Quote
Old 01-11-2014, 04:03 PM   #3041
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I had a few questions cross my mind, as I haven't managed to make it all the way through the 140 pages, they may have already been covered. Some of them may be niche and only interest me, but here they go.
1. Can an hour/minute meter be added to the system to keep track of how much it is used? say inline with the pedal switch, so when it's pressed the meter will tick along and keep track?
2. Is there any maintenance? I don't think the electronics will need any, but the system does have a turbo style compressor housing/wheel, is there any bearings that need to be lubed, or oil that can/needs to be changed?
3. the battery voltage meter, can you turn this screen off so that it doesn't flash at you all the time, or when driving in the dark?
thanks.
Target70 is offline   Reply With Quote
Old 01-11-2014, 04:05 PM   #3042
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Urmyson View Post
Has anyone done any testing with headers yet?
We will soon
Shiv@Openflash is offline   Reply With Quote
Old 01-11-2014, 04:47 PM   #3043
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
You can wire any type of timer you like. I don't see why you couldn't use the ESC trigger as a momentary switch.
Nothing special. While not maintenance, you'll want to make sure that you keep your dump batteries in a state where they can quickly deliver the maximum current. Having the batteries warm and cycled often it best.
The screen can't be turned off or dimmed. You can place the arm switch anywhere you want; in view or out of view. If you like, you can keep it in the glove box.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 01-11-2014, 05:07 PM   #3044
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by shiv@vishnu View Post
We will soon
Shiv you getting one?
Installed Mods:
Old 01-11-2014, 07:28 PM   #3045
mid_life_crisis
Drives: FR-S 10 #103 AT
So you're saying the best way to maintain the system is to use it often?
There's a chore...
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-12-2014, 12:28 AM   #3046
Shiv@Openflash
Drives: 2013 FRS
I believe one is on the way to me as I type this. Looking forward to finalizing the OTS mapping
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (01-12-2014), fenton (01-12-2014), Sojhinn (01-12-2014)
Old 01-12-2014, 12:30 AM   #3047
fenton
Can't wait to see that! Exciting stuff. I can't wait tell spring I know that Rob always has new stuff planned with Phantom
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 01-12-2014, 08:18 AM   #3048
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
So you are saying I need a header. What's my turn around time?
Installed Mods:
Old 01-12-2014, 11:44 PM   #3049
Sojhinn
Sojhinn's Avatar
Haven't touched my car in 18 days due to vacation. Will be trying out how the battery works with such a long stay. I'll let everyone know soon.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (01-13-2014), zc06_kisstherain (01-13-2014)
Old 01-13-2014, 04:34 PM   #3050
Robftss
Drives: VW
No.
Brgs are sealed ceramic.
Robftss is offline   Reply With Quote
The Following 3 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (01-13-2014), Gums (01-14-2014), Target70 (01-13-2014)
Old 01-13-2014, 04:50 PM   #3051
Sojhinn
Sojhinn's Avatar
Forgot to start it last night. I was dead tired. Fired on first try this morning.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Robftss (01-13-2014)
Old 01-16-2014, 08:21 AM   #3052
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Originally Posted by fenton View Post
I believe Rob is still targeting late January for first release. I can't speak to the group buy....I know that in this industry they can be dangerous.
We're coming up pretty quick on late January - how's it looking?
VR46 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
