#99 | |
Drives: 2013 GBS BRZ Limited
No. As I stated before: IF the rotating mass is balanced at the factory, then changing the pulley will throw off this balance. If you want to shed a couple of pounds from your car, why dont you just remove the wheel balance weights. That is even un-sprung weight! |
#100 |
Just a dude
Drives: Scion FR-S 2013
There has now been two official statements by manufacturer themselves saying the LWPs are perfectly fine with our engine So..... Why are some still even trying to discredit?... Seems senseless is all?
#101 |
Drives: Argento Scion FR-S
I can't confirm, but didn't someone say the pulley was self balanced, like why wheel weights are used? Not balanced to the engine itself? It's a cheap part... Is it perfectly balanced right out of the mold?
#102 | |
Señor Member
What you should be more concerned about are crankshaft harmonics which are completely different to its balance. The stock pulley may be a harmonic damper or it may just have that layer of rubber just for NVH reasons. I personally have driven an NA 70s inline 4cyl Toyota engine with nearly double the stock power for over 60,000kms with a solid crank pulley without any issues to date. So I am not too concerned about the effects of replacing the front pulley on my FA20. If you are then great, don't buy one.
1974 TA22 Celica
2013 86 GT |
#103 |
I build 4-cyl Boxer engines for racing. I have the rotating assembly balanced by a pro.
My engine has a "pulley" on the front. When the machinist balanced the rotating assembly he had to drill holes in the front pulley as well as the flywheel. If I change the flywheel or the front pulley I have to rebalance. I see no reason to believe that this engine is any different. Do what you want. On the other thread I posted above, My "rant" explained how changing the pulley to reduce the rotating mass of the engine was almost negligible when compared to all of the other rotating mass. My guess is that the belt has a greater effect on rotating mass then shedding a pound or two from a piece that is as close to the rotational axis as possible. How much would notice if you removed two pounds from the crank by drilling right down the middle of it? - NONE Now if these pulleys are a smaller diameter than stock and you underdrive the AC, Alt, & water pump, then you would definitely feel a difference. |
#104 | |
Would you like to buy some? Why not, It cant hurt. |
#105 |
Just a dude
That has nothing to do with discussion. As said two statements from Subaru themselves those who continue to discount just look more silly by the post just sayin'.....
#106 | |
Spend your money how you want. Maybe some fuzzy dice will make your car faster. |
#107 |
Just a dude
You're now trying to be an ass to someone who doesent even give a shit ether way pal. Maybe you need to go back re educate yourself to see who has even been making waves here then go slap yourself.
#108 |
All the Bullshit about phones in microwaves and you are GIVING ME SHIT? Go fuck yourself!
How many of the other poster on this thread have built a racing boxer engine and had it balanced? I am guessing ZERO |
#109 |
Señor Member
Woe, relax dude. No one hear is attacking you personally (that i have read anyway) the phone is just a joke about how intense the debate is over such a small inconsiquential part.
1974 TA22 Celica
2013 86 GT |
#110 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] |
#111 |
So you dont consider being told" you are an ass, need to reeducate myself and "making waves", to not be a personal attack?
Ok I know I thought it was funny too. and I agree with "inconsiquential" |
#112 | |
Nice lightened flywheel. I assume that engine was running on carbs. The "Pulley" on those engines is a fan that also doubles as the alternator drive pulley and goes on the top. |
| Tags |
| monorail |
| FS: AgencyPower Lightweight Crank Pulley | Firestorm_86 | Engine, Exhaust, Bolt-Ons | 0 | 11-22-2013 04:13 PM |
| Lightweight crank pulley on an AUTOMATIC | Gani21 | Engine, Exhaust, Transmission | 17 | 09-30-2013 10:27 AM |
| FS: Perrin lightweight crank pulley | tmccoy33 | Engine, Exhaust, Bolt-Ons | 1 | 09-12-2013 04:52 PM |
| My lightweight crank pulley experience | WolfsFang | Engine, Exhaust, Transmission | 22 | 11-29-2012 02:15 AM |
| Ralco RZ Lightweight Crank Pulley HELP! | JERZgrl88 | Engine, Exhaust, Transmission | 11 | 10-10-2012 12:41 PM |
