Old 01-07-2014, 11:04 PM   #15
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
How do you like the Tomei 2 way? I'm almost done with my diff and final drive change up and went with the Tomei as well.
Dustin is offline   Reply With Quote
Old 01-08-2014, 01:18 PM   #16
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Originally Posted by MrMarinakos View Post
How's the fitment on the VS kit? I heard it wasn't all that great ;/
Actually, the front lip fits extremely well. Fitment was very snug, which required additional hands to put on, so that we didn't scratch up the bumper. It's so snug that we're only using 4 bolts to hold it up.
Side skirts is what hurts the fitment rating.
Not sure if the Japanese version is different in some way, but the liner that runs down the wheel well makes the fitment of the side skirt very tight.
We had to use a heat gun to massage the side skirt over the liner. If you pull the liner, it fits very snug, which is why we wonder if the Japanese version's liner goes on differently.
Touge Factory is offline   Reply With Quote
Old 01-08-2014, 01:43 PM   #17
Touge Factory
Drives: ZN6
I've become accustomed to drving cars with 1.5 and 2-way LSD's, and the Torsen diff was a whole new learning curve for me, especially for drifting.
We're a big fan of the Tomei 2-way. It's affordable and very good quality. We have multiple cars here with them and some have over 4 years of use with no signs of needing a rebuild.
Due to this diff being a clutch-type, you will here some clunking making small tight turns while in gear.
Old 01-08-2014, 02:04 PM   #18
MrMarinakos
Drives: Asphalt Monogram Fr-s
Well i really want a TRD kit but i don't know if i want to risk buying the replica if theres going to be problems with the fitment:/
MrMarinakos is offline   Reply With Quote
Old 01-08-2014, 02:15 PM   #19
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
17x9 +40 wrapped in 245/40/17 ZII star specs.
Do you have ANY pictures of these on the car? I never pulled the trigger on these because I was unsure if they would look undersized on the car.
raul is offline   Reply With Quote
Old 01-08-2014, 03:31 PM   #20
Touge Factory
Drives: ZN6
This is the only picture I could find quickly... Also this is the exact same sizing as the RPF1's and RS3's on our car.
The Following User Says Thank You to Touge Factory For This Useful Post:
raul (01-08-2014)
Old 01-08-2014, 04:07 PM   #21
Touge Factory
Drives: ZN6
Well well well... what do we have here.
Old 01-08-2014, 11:27 PM   #22
whiskerbox
Drives: Scion FRS
I love how these sit . Can you tell me a little bit more about your suspension setups? coilover, camber, toe, etc....
whiskerbox is offline   Reply With Quote
Old 01-08-2014, 11:32 PM   #23
whiskerbox
Drives: Scion FRS
Old 01-09-2014, 07:10 PM   #24
Touge Factory
Drives: ZN6
Thanks.
On the Black car:
STANCE ProComp2 Coilovers: 8k front / 9k rear
Front camber is -2.5 / 0 Toe
Rear camber is: -2 / 1/16 Toe in (We're going to put the rear camber down to -1.7
Whiteline 22mm adjustable front sway bar
whiskerbox (01-09-2014)
Old 01-09-2014, 07:14 PM   #25
Touge Factory
Drives: ZN6
Installed one Jackson Racing kit on a customer's BRZ.
Very straight forward install. Everything went on smoothly and fitment is great.
customer has an aftermarket bumper, so Greddy and HKS oil cooler wouldn't fit.
We decided to make our own. You can see the custom aluminum brackets we fabbed up to mount between the front mount and the AC condensor...right next to the Compressor oil cooler.
Old 01-09-2014, 09:12 PM   #26
pche
Guy on internet
Drives: Slowly
Found your website and had been debating on whether or not to use your tail light service. After seeing this thread I'm sold, they look great. Now I just gotta go rob a 7-11 or two, not that you're expensive, I'm just kinda tight right now lol.
pche is offline   Reply With Quote
Old 01-13-2014, 03:40 PM   #27
Touge Factory
Drives: ZN6
Gotta love this picture of Chicago's Polar Vortex.
"DAY AFTER TOMORROW"
We hit -48 degrees last tuesday.
Goya (01-17-2014)
Old 01-13-2014, 05:32 PM   #28
Touge Factory
Drives: ZN6
Two budget friendly front pipes we installed. Both fit right on without any issues to our Motiv Overpipe.
both were 2.5" outer diameter. Most front pipes we've installed are all measured outer diameters, and the I.D was approximately 2.37."
You can see that the DCsports lacks the bends.
Another angle
One more to show the bends
Flange:
Other Flange
Hanger for the front pipe:
INSTALLED PICS OF DCSPORTS
Without the additional bend by the transmission mount, the piping sits about 8mm away from the transmission mount. Length wise, fitment was better then the Tanabe, where we did not have to pull the catback forward at all to put in the bolts.
INSTALLED PICS OF TANABE
Tanabe allowed for much more room between pipe and the transmission mount due to additional bends. At least 1" gap between the two.
Hyper-BRZ Build Journal hypermax Member's Car Journals 62 06-10-2016 11:39 PM
Gopherboy's WRB BRZ Limited - Build Journal Gopherboy6956 Member's Car Journals 41 03-22-2015 01:28 AM
The Ongoing FR SPORT BRZ Build Journal FRSport.com Member's Car Journals 13 01-27-2014 07:32 PM
1 SIK FRS Raven FRS Build Journal 1SIKFRS Member's Car Journals 20 01-19-2014 02:58 AM
Build Journal for Koigataki (6MT Argento FR-S) Koigataki Member's Car Journals 25 10-10-2013 02:09 AM
