Old 01-09-2014, 11:26 AM   #1
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
AT Fluid Suggestions
Need some suggestions, I'm planning to change the ATF again. It seems the Toyota WS ATF doesn't like being tracked. I notice after a few track days that the AT does not shift as crisp as when the fluid is new. I don't know if I'm making sense or not, but that's how it feels to me. It seems like the clutch packs slip a little more than when the ATF is new.
The question is, what is the equivalent viscosity of the stock ATF? Or should I try some performance oriented brands? Any AT owners changed to other ATFs than the stock one?
Tye300 is offline   Reply With Quote
Old 01-09-2014, 11:59 AM   #2
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
Here are the choices we have for fluids if you want to switch from OEM - Redline D6 ATF, Eneos ECO-ATF, Amsoil Signature Series Fuel Efficient ATF, & Amsoil OE Fuel Efficient ATF. All of these fluids are equivalents for Toyota WS ATF. I switched to Redline D6. Shifting is now much smoother.
Terrapin77 is offline   Reply With Quote
Old 01-09-2014, 12:03 PM   #3
Tye300
Tye300's Avatar
Thank you very much @Terrapin77! Will look into the fluids you mentioned.
Old 01-10-2014, 01:28 PM   #4
Blood
Drives: 2018 STI
Keep in mind that the AT has a capacity of 7.5 liters of transmission fluid, and a lot of it will not come out if you only do a drain and fill. I'm not sure exactly how much comes out during a normal drain, but you're still going to have a decent amount of OEM transmission fluid mixing together with whichever new transmission fluid you choose. At least until you've done a few drain and fills, or have the transmission completely flushed.
Blood is offline   Reply With Quote
The Following User Says Thank You to Blood For This Useful Post:
Tye300 (01-10-2014)
Old 01-22-2014, 04:51 PM   #5
Terrapin77
Terrapin77's Avatar
When I put Redline D6 in mine, I had the trans completely flushed. An AT actually takes 7.9 liters, which is basically 2 gallons. I had to bring 4 gallons of Redline D6 to my mechanic to do a proper flush.
The Following User Says Thank You to Terrapin77 For This Useful Post:
Tye300 (01-27-2014)
Old 04-03-2014, 01:59 AM   #6
FastWhite
Drives: Subaru BRZ Limited M/T
I know the mechanics of an AT flush but where am I going to get one done. I went to Savannah tire and inquired about a flush. They were leery of changing it as there machine had non compatible fluid in it. I could provide my fluid but they would not guarantee that there would not be any contamination when drained there machine.
So I am open to suggestions
on where to go?
And I get told THAT every day so forget it. Just looking for answers thank you very much. Lol
I will give our one race shop a call and see what they got. $$$$$$$$
FastWhite is offline   Reply With Quote
Old 04-04-2014, 02:46 AM   #7
Poodles
Drives: 2015 Series.Blue
Have you installed a good transmission cooler? #1 enemy of an auto tranny is heat and would probably alleviate the issue.
Old 04-04-2014, 03:33 AM   #8
FastWhite
Not yet. I autocross the car and any cooler bumps me up to the next class.
Until the SEB changes the rule set I would actually go to Street Prepared. Miata territory. If they change it then it would be in Street Touring.
I found a place to do my AT flush. And yes $$$$$.
Need about 4 gallons of Redline D6 ATF @ ~$20/qt = 16 x 20 = $320 plus the labour.
But I have convinced myself that I "NEED IT"!!!! But as I do auotx it, better safe the sorry.
Does anyone have any feedback on BG ATF fully synthetic fluid?
Old 04-04-2014, 08:33 AM   #9
frslee
Just drive it
Drives: 13' FR-S
Isn't torque converter sensitive on trans fluid? Last time I had auto with torque converter, it started to act weird when I used third party fluid. It was in the same specification.
If I were you, I would stick with factory fluid.
frslee is offline   Reply With Quote
Old 04-04-2014, 10:12 AM   #10
FastWhite
I am aware of that. When I started my research on the different brands, I found all kinds of stuff on the different forums.
The main thing is do a full flush, measure what comes out and put the exact amount back in. This if you do it manually.
In other words "pay to play". Get a shop to so it.
Old 04-06-2014, 01:30 PM   #11
FastWhite
I was on Amazon the other day, trolling ATF fluids. The site listed Redline D6 as NOT compatible with the BRZ. ???????
At this point the only definitive results are Motul, BG, stock,
Old 04-06-2014, 01:36 PM   #12
FastWhite
I need to add that this seems to be on paper only. Our trany comes with Dextron VI from the factory. Listed in the manual as ATF WS.
SSP uses rMotul gear 300 V 75w90.
Rainy Sunday ramblings.
Old 04-06-2014, 01:38 PM   #13
Terrapin77
Terrapin77's Avatar
I wouldn't put much faith in what Amazon says is compatible. http://www.redlineoil.com/application.aspx
Sent from my XT912 using Tapatalk
Old 04-06-2014, 02:05 PM   #14
FastWhite
Agreed. I am still putting in the Redline D6. The cost of the Motul is a bit much on the budget at this time.
Taxes.
Ask a question I must. (Yes I been watching Star Wars reruns).
Have you any feed back on BG full synthetic trany fluids.
Can't find much on line. Some good some bad. Same as am soil, some good some bad.
So I ask.
Any suggestions for my FRS? kaikeng Cosmetic Modification (Interior/Exterior/Lighting) 16 08-04-2013 05:03 PM
Rim suggestions? Perihelion Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-15-2013 02:47 PM
Suggestions for a new car? DIM Other Vehicles & General Automotive Discussions 20 04-26-2013 01:49 PM
Suggestions? Cameronghanson Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-18-2013 10:19 PM
HELP! Need Suggestions Please!!! Bfly BRZ First-Gen (2012+) — General Topics 30 09-05-2012 03:46 PM
