Old 12-26-2013, 05:03 PM   #85
Dezoris
Dezoris's Avatar
AP Racing Sprint is going to be the best bet for track sessions under 2 hours at a time.
If you are running over 6 hours track time per day endurance maybe better.
Most all of the track guys on here run the Sprint version and don't require any changes to rear brakes besides pads.
Dezoris is offline
Old 12-27-2013, 10:21 PM   #86
diss7
Drives: AE86, 2x GT86, TE27
One thing I'll add about the Wilwood kit that I've experienced on the track, they increase rear bias quite a bit. I thought it was my stock suspension I ran on the first track day I used the wilwoods on; but I've since tried used rsr coilovers, and more agressive front pads (poly d's then poly h's) and still too much rear bias.
And I only have the shitty non US spec rear brakes, with TRD pads (that are only marginally more agressive than stock.)
So the only thing I'm left with doing is installing a proportioning valve to reduce rear bias.
Bit disappoint TBH. When they say they work with stock rears, I expected they meant it maintained similar bias.
diss7 is offline
Old 01-09-2014, 12:15 AM   #87
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Has anyone ran the sprint kit in the winter with snow? Did I read that it was not recommended?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline
Old 01-09-2014, 12:18 AM   #88
diss7
I've sold my Wilwood kit, and am planning on getting one of the AP kits. Hope to have a review up of the differences in the next month or two.
diss7 is offline
Old 01-09-2014, 12:23 AM   #89
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Clean them and they'll be fine, but since they aren't painted, etc they aren't as ideal as the OEM stuff in the winter in terms of corrosion resistance.
You could swap them between seasons, kind of a pain in the arse but that's what I would do if I had to deal with salt/etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 01-09-2014, 12:42 AM   #90
feldy
feldy's Avatar
What about the pad it self?
feldy is offline
Old 01-09-2014, 01:23 AM   #91
CSG Mike
CSG Mike's Avatar
@feldy: the pad itself will be fine; get something appropriate for your application.
The caliper itself is not painted, and will corrode with salt, etc...
CSG Mike is offline
Old 01-09-2014, 09:39 AM   #92
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
We don't typically recommend running our kits in snow and ice, but some people do it anyway without issues.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline
The Following User Says Thank You to JRitt For This Useful Post:
WillRacer1jz (01-09-2014)
Old 02-11-2014, 07:45 AM   #93
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Does anybody know if the dba rotors are a possible replacements for the sprint kits?
Sent from my GT-N7105 using Tapatalk
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline
Old 02-11-2014, 10:02 AM   #94
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No. They aren't the right size, don't have the right number of mounting ears (based on pics). They aren't cheaper either (at least based on the set of WRX replacement rings I saw on eBay based on US pricing).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following User Says Thank You to Dave-ROR For This Useful Post:
liquidsky44 (02-11-2014)
Old 02-11-2014, 11:31 AM   #95
liquidsky44
Then there are basically no other options? I just feel that I would like to try other rotors just to test it out.
Old 02-11-2014, 11:49 AM   #96
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
If you mean other rotor options that bolt to the Essex hat, there probably is. I haven't searched but it's a production AP Racing rotor ring so the measurements are available you just have to find something that matches.
Here's the manufacturing drawing for the rotor ring included with the Sprint kit: http://www.essexparts.com/media/down...62-104~5ga.pdf
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 02-12-2014, 06:15 PM   #97
jwbrocloud
Drives: Raven MT
Originally Posted by FT-86 SpeedFactory View Post
The rotors will not touch the spoke at any time with the AP kit. We have had plenty of hard lapping days with this setup and there are no issues.
35-45 offset are just right for a 17x9 wheel on our cars, IMO.
I have a question. I have this exact Wilwood kit I bought off a guy locally but I want to upgrade the 12.88" rotors to the larger 14" ones because the 12.88" ones look to small behind a 19" wheel. Can I use the same caliper and bracket and upgrade rotor size?
jwbrocloud is offline
Old 02-24-2014, 12:24 PM   #98
liquidsky44
I have a question. When do you guys change out the ap sprint kit rotors? Currently I'm left with 28mm and still contemplating on should I change it soon.
Stillen Brakes jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-16-2013 12:57 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 07:23 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
