| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
Drives: 2013 rfs
#30 |
Bringing Hachiroku Back
Drives: 2013 Firestorm FR-S
Duuuude! Thanks! I wanted to make sure of where to tuck the wire once its run behind the A-pillar didnt know about the hole/gap in the end of the dash. This is exactly what I needed to see to confirm before I popped the A-pillar cover and ventured to plug my new dashcam in the lighter socket. Thanks again! This also saved me the $$ for the add-a-fuse since was planing on plugging it into the fuse box...
#31 |
Drives: FR-S 10 series
Where the heck are you all finding this rj11 phone jack adapter to cigarette lighter plug? Trying to hardwire my escort and I couldn't find thus a adapter at any local store or online.
#32 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
#33 |
Drives: Toyota GT86
Just finished my install. This made perfect sense when I opened the pillar and exposed the side curtain airbag.
To clarify for anyone doing this in future, just make sure the wire runs behind the curtain airbag on the side of the glass, as to not interfere with the airbag, should it ever have to deploy. My finished install looks factory. I am so happy with the results. It is as if Toyota intended for this. Last edited by Chad86; 07-02-2014 at 01:46 AM. |
#34 | |
Drives: 2013 FR-S Whiteout MT
How well does the suction cups stay on the dot matrix? Mine keeps falling off after driving. Right above the rear view mirror is perfect, but those dots don't work well for the suction cups. Any solutions anyone?
When in doubt, throttle out!
#35 |
Drives: Toyota GT86
I have this problem occasionally too. I am thinking double sided sticky tape will solve this.
#36 |
I was thinking small Velcro bits on the suction cup and windshield. I tried last night but it was cold and moist so it didn't stick. Think I'll put a piece of masking tape then the Velcro to make it stick more. Hopefully it works
#37 |
So I used some gorilla tape to stick the velcro on, but the tape is sliding off from heat. Velcro doesnt hold on the suction cups either.
Anyone have a way to get the suction cups mounted on the dot matrix better? I'm going to try some 3m double sided tape today or tomorrow and hopefully that works.. but any pointers are helpful!
#38 | |
Drives: FRS-RS1, Triumph Speed Triple, Lola
#39 |
I sort of wanted it above the mirror so no one can see it. I found a forum online that did a diy of one without suction cups. I'll try it tomorrow. Hopefully it works! Discovered 3M dual fasteners. or scotch outdoor fasteners. It holds 5 lbs!! It's basically velcro on steroids.
#40 |
Drives: Satin Pearl BRZ
#41 | |
Drives: 2013 BRZ Limited M/T
#42 | |
The instructions come with the mirror tap. Just pull out your dome light and gently feel around inside the headliner on the pass. side. Mine was 6"-8" away from the opening. I would recomend fishing the wires from the front of the headiner. If you try to feed them forward you'll have a hard time getting the detector connector thru. Also I would wrap the connection on the mirror plug with electrical tape to prevent the tap from backing out or shorting. Good luck. |
| Radar | L3P47 | Electronics | Audio | NAV | Infotainment | 31 | 05-15-2013 12:53 PM |
| radar detectors | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 02-24-2013 02:27 PM |
| Radar Detectors | swag | BRZ First-Gen (2012+) — General Topics | 28 | 01-31-2013 04:58 PM |
| Next mod: Radar dector | jwbrocloud | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 01-27-2013 01:04 PM |
| Has anyone done a good concealed Valentine One install? | sikest | Electronics | Audio | NAV | Infotainment | 3 | 01-22-2013 06:37 PM |
