| Software Tuning Discuss all software tuning topics. |
#29 | |
Drives: Lightening Red BRZ Ltd.
#30 | |
I've hit over 140km/h (smaller track) with it properly disabled by the button (no pedal dance) and slid around without it coming back on. The only difference between fully disabling it (~5 seconds of holding the button) and the pedal dance is that EBFD is still on if you use the button. ABS is on in both cases, normal TC and VSC are off.
| The Following User Says Thank You to wparsons For This Useful Post: | himbo (01-09-2014) |
#31 |
Señor Member
The pedal dance also turns off the virtual lsd (where a spinning wheel is braked to keep traction) whereas the 3 sec hold doesn't disable that. Not sure if that's good or bad in the snow.
1974 TA22 Celica
2013 86 GT |
#32 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
just tried it out today and it works!! woohooo.. now all i need are my summer tires back on my car so I can slide this mo fo around in circles
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#33 | |
Drives: Sc10n
So, as has been mentioned before you are holding it wrong. Hold it down longer. You should see both lights go active when you have completely turned it off - the TRAC off light, and the Car slip light below it will both be active. If you only briefly press the Trac off button only the TRAC off light will be on and the system will start up again @31 MPH. |
| The Following User Says Thank You to Seattle944t For This Useful Post: | himbo (01-09-2014) |
#34 |
That's what I have been doing but I guess it was the EBFD that was kicking in. Strange, there were time line it seemed like it was still on...
#35 |
If you hold the button long enough, the lights come on while the button is still pressed. If you have to let go of the button for the light to come on you didn't hold long enough.
Not sure if it varies from car to car, but mine is definitely longer than 3 seconds.
#36 | |
Drives: SSM LT MT BRZ
You are stating that all Nannies are disabled, yet explaining that they in-fact aren't all disengaged, there is alot going on behind the scenes with a traction control as advanced as this. so based on steering angle and throttle position different amounts of the system will step in to save your ass. I have been tracking the car for over a year and have ample time driving it in all of it's various modes as do many members on this forum, if you ask @csg_mike I'm sure he can enlighten you even further |
#37 | |
Drives: 2014 Zenki 37J
http://www.autofactory.jp/product/to...&cate=4&seq=11 |
| The Following User Says Thank You to turbos86 For This Useful Post: | himbo (01-09-2014) |
#38 | |
I still believe there's something lurking when the system is"off". A lot of track guys have talked about this. I will find the links |
#39 | |
Holding the TC button turns off everything except EBFD and ABS, doing the pedal dance turns off everything except ABS. As for what you've said, how does EBFD stop you from spinning???
#40 | |
Drives: 2013 GBS BRZ Limited
Did the engineer design the car to have less rear braking than the front in this situation (as they should have)? I dont know. Older cars have a proportioning valve that cuts off the rear brakes at a certain pressure and allows the front pressure to continue to climb. This reduces the chance of the rears locking before the fronts (which causes a spin) Without EBFD enabled, who knows wht the rear brake bias is. |
#41 |
You're kidding right? I already said that EBFD doesn't come into play except under braking and you still said that it would prevent a spin.
Unless you're messing with pad compounds or trail braking hard you have no worries about EBFD doing anything while on a track. In addition, if you're driving like that with EBFD on then it's very likely it'll fall into ice mode and fully lock up the rear brakes.
#42 |
"and you still said that it would prevent a spin"
"I" didnt say anything of the sort. I was merely commenting on the statement "how does EBFD stop you from spinning???". My answer was that EBFD is now the replacement for a rear brake proportioning valve. The car does not have a proportioning valve, so with EBFD disabled, the rear brake bias is unknown. If it is wrong (more bias to the rear than the front), then you could spin under braking conditions. Sorry if I was commenting on a statement without considering the context of the discussion with SkullWorks. |
| How to disable the 120 kph warning - UAE | captaindubai | ASIA | 25 | 05-21-2023 03:54 PM |
| How to disable DRL in FRS | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-13-2016 02:11 PM |
| Dealer won't disable Ecu features? | DBacon1052 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-09-2014 08:30 AM |
| Dealer refusing to disable DRL's? | zaptorque | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 09-17-2013 04:20 PM |
| Is there a way to disable the immobilizer? | schtebie | Issues | Warranty | Recalls / TSB | 5 | 09-22-2012 06:09 PM |
