Northwest AK, ID, OR, WA
Old 01-08-2014, 01:09 AM   #15
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Well, that's what I'm trying to figure out. I've never done something like this before. Do I install everything and then get an alignment done? I think I might YOLO (sorry) and go for the Ohlins and Perrin 19mm front with either the 19mm rear or 22mm rear sway bars. Also going to try to get the camber plates refinished in red....
Probably use the Perrin endlinks? the ones that come with the Ohlins? I'm not sure. @DarrenDriven I'd love help installing these from someone who's done it before, I don't care his age.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 01-08-2014, 01:28 AM   #16
evan
Drives: fr-s
Yes.. install everything and then get the alignment last. I recommend that you get an alignment at a tuner shop. Avoid the cookie cutter alignment shops..
evan is offline   Reply With Quote
Old 01-08-2014, 01:40 AM   #17
PoWn3d_0704
Anywhere Specifically?
Probably doing install at Darrens, so somewhere close would be good.
Build Album:
Old 01-08-2014, 01:45 AM   #18
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
PRE Racing is about 7.5 mi from his house
Old 01-08-2014, 01:49 AM   #19
PoWn3d_0704
Perfect. I'll start buying shit then. Anyone using the Perrin Sway's? I know @Chen is, but he said the 19mm/22mm makes his car really tail happy.
Build Album:
Old 01-08-2014, 03:31 AM   #20
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I like the perrins cause you can pick which setting you want with how stiff they are. I also have Perrin end links. Works great. But I'm not really sure what they do.
Chen is offline   Reply With Quote
Old 01-08-2014, 11:17 AM   #21
PoWn3d_0704
Do you have the machined ones or the adjustable ones?
Build Album:
Old 01-08-2014, 04:23 PM   #22
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=34814
This is what I will be getting with my ST coils if I go that route. Caster and camber adjustment, and it looks badass. They will custom make it for any coils for no additional cost.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-08-2014, 04:48 PM   #23
dvsidboy
Drives: 2013 Subaru BRZ
I am rocking AMR Engineering Coilovers, local in Vancouver WA. Love them.
Also rocking the Perrin F/R Sway and F/R End Links with the 1 Piece Machined front end link. Car is very stable and planted. If the rear is going to come out its very predictable and controllable.
dvsidboy is offline   Reply With Quote
Old 01-08-2014, 05:45 PM   #24
evan
Drives: fr-s
What's the cost on the AMR's? What are the spring rates? Are they fully adjustable?
Old 01-08-2014, 07:26 PM   #25
Chen
Regional Moderator
Chen's Avatar
Adjustable.
Old 01-08-2014, 10:16 PM   #26
Thatruth2001
Drives: Raven FR-S
Check out the MSI top hats at rallysport direct. The company makes both front and rear adjustable top hats. I installed the front ones and will eventually install the rears.
http://www.rallysportdirect.com/MSI-...t-Upper-Mounts
http://www.rallysportdirect.com/MSI-...r-Upper-Mounts
Thatruth2001 is offline   Reply With Quote
Old 03-11-2014, 03:11 PM   #27
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thought this is the proper place to put this question...
I'm having a tough time deciding between the ST coils and KW V1 coils, basically is the mucho extra bucks worth the SS on the KW? or does the PNW (specifically Seattle) not get enough snow --> then salt for the need of stainless steel?
Old 03-27-2014, 09:27 PM   #28
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Originally Posted by DarrenDriven View Post
My assistant, Tyler @hefeweisen, installs springs for $40 and coilovers for $60. It takes about 1.5-2.5 hours depending on which components you are installing. He's 16 and saving towards his first car... and has installed suspension on a dozen 86s, so you are in good hands and the money is going to a worthwhile cause.
Is this deal still going on? I would like to instal some STI springs.
How should i lower :( Obja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 06-15-2014 12:39 PM
Want to lower my FR-S where can I go? laley81 Southern California 16 08-22-2013 07:05 PM
I want it lower !! Ndgreely Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-12-2013 11:10 PM
How can I go lower? nab335 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-08-2013 03:15 PM
Lower the seats? MrMista Scion FR-S / Toyota 86 GT86 General Forum 11 04-19-2013 07:41 PM
