Old 12-31-2013, 05:32 PM   #197
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Big fan. Good stuff.
TouchMyHonda is offline   Reply With Quote
The Following User Says Thank You to TouchMyHonda For This Useful Post:
whataboutbob (12-31-2013)
Old 01-05-2014, 09:57 PM   #198
whataboutbob
AutoX-10/10ths every run
Ok, so I've been busy the last few weeks. A stack of new stuff for the car.
1) RaceCompEngineering T2s
2) Raceseng CASCAM and Shock Tops
3) Whiteline trailing arm bushings and bump steer correction kit
4) Innovate Motorsports Intercooler
5) Painless wiring harness to provide dedicated circuits for the Hellas and the IC water pump.
6) Grillcraft grill
7) Another set of Enkei RPF1s, this time in 17x9ET45 (so hopefully I can get 275/40R17 R Comps on)
8) Used set of free 235/40R17 R1Rs with more than 50% left in them
9) Crowe 5 point harness (only using lap belt ATM) and some nice brackets that mount to the factory points.
10) CARB sticker for the Innovate kit
Enjoy. Lots of before, middle, and after shots of the work/parts.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
Scooby South (01-05-2014), suaveflooder (01-05-2014)
Old 01-06-2014, 12:29 PM   #199
JS + BRZ
Drives: 2010 MS3
Big fan. Keep up the great work, sir!
The Following User Says Thank You to JS + BRZ For This Useful Post:
whataboutbob (01-06-2014)
Old 01-06-2014, 12:31 PM   #200
whataboutbob
Thanks!
Build thread:Here
Old 01-06-2014, 01:21 PM   #201
xxscaxx
Drives: 2013 SWP BRZ
Looking good bob. My IC kit is coming in on friday, will be starting my install friday night.
xxscaxx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
CounterSpace Garage (01-06-2014), whataboutbob (01-07-2014)
Old 01-06-2014, 05:09 PM   #202
swift996
swift996's Avatar
Can you elaborate on this set up? I'm about to order my intercooler and am interested to understand how you ran it. Also any install notes or things to look out for? Thanks!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Old 01-07-2014, 01:10 AM   #203
whataboutbob
I bought the Painless http://www.summitracing.com/parts/PRF-70207 .
The water pump comes with a PnP harness to tap its power from one of the injectors. I wanted to give it a dedicated circuit. Also, I initially had the Hellas wired to the factory harness, but someone pointed out that they weren't as loud as the should be so I am going to use the factory output to control a relay and will use one of the circuits from the Painless harness to provide the power to the Hellas.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
swift996 (01-07-2014)
Old 01-07-2014, 01:22 AM   #204
u/Josh
Drives: GBS Limited 6MT
How do the tarmac 2 compare to the yellows in terms of both ride and handling?
u/Josh is offline   Reply With Quote
Old 01-07-2014, 01:28 AM   #205
whataboutbob
Can't say yet. Car is still on jackstands in the garage waiting for some more parts. Will comment more once I get it back together and running.
Build thread:Here
Old 01-07-2014, 02:27 AM   #206
whataboutbob
Nice shot my friend Brian R took of me at FT86Nation a while back.
Build thread:Here
The Following 4 Users Say Thank You to whataboutbob For This Useful Post:
Bad Habits (01-08-2014), Carticular (01-20-2014), dattran86 (10-13-2016), suaveflooder (01-08-2014)
Old 01-07-2014, 01:39 PM   #207
xxscaxx
You can also purchase this harness for the hella horn kit:
http://www.subimods.com/subimods-hel...rness-kit.html
Used that when I had my STi. Still on the fence about picking up supertones, but yes, they need to be ran on their own relay to utilize their loudness.
You don't even really need to buy a harness, you just need the relay. one is power, one is ground, then the other two go to the horns. Super simple if you have the wiring.
I'm still on the fence on what to do with the water pump, if I want to just run it as is. (the harness tapping off the injector)
The Following User Says Thank You to xxscaxx For This Useful Post:
whataboutbob (01-08-2014)
Old 01-08-2014, 12:18 AM   #208
whataboutbob
Yeah, I could have done that but I wanted to have a clean wiring setup and allow for any future upgrades.
Build thread:Here
xxscaxx (01-08-2014)
Old 01-08-2014, 01:18 PM   #209
xxscaxx
just throwing it out there in case anyone else asks
Old 01-08-2014, 11:01 PM   #210
whataboutbob
Fair enough.
Build thread:Here
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
Showstoppers Firestorm FR-S Build ShowstoppersUSA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 10-09-2014 06:26 PM
Firestorm/black project build deedz Member's Car Journals 47 11-19-2012 05:06 PM
Firestorm FR-S Available mattyboy311 Mid-Atlantic 1 09-26-2012 11:36 AM
Firestorm Frs DAFRS88 Southern California 0 08-03-2012 05:11 AM
