Old 12-13-2013, 03:54 PM   #15
GreenPants
Drives: Burnt Orange GT86
Originally Posted by Trap63 View Post
The only issue is that Torque Pro (now with CAFI logo on bottom left) shows only USB port to choose in 1st option of "settings menu". Thus you cannot choose wifi or BT connection.
Workaround for v4 not allowing BT/WiFi OBD2 ports in Torque Pro
Note: this does not appear to be an issue for Torque Lite
Delete: /etc/carit_version2
Step-by-step guide
  • Click the 'Home' button
  • Open Applications
  • Select 'ES File Manager'
  • Click the 'Menu' button
  • Select Root Explorer
  • When prompted, grant root privileges to ES Explorer (not permanent)
  • Select 'Mount R/W'
  • Click on the 'R/W' radio button on the '/system' row
  • Click 'OK'
  • Click on the 'Up' icon ('^', top left) util the folder no longer changes (go to the root folder)
  • Click on the 'etc' folder
  • Click-and-hold on 'carit_version2' - a tick should appear on the file
  • Click on 'Delete' (middle icon on right)
  • Click 'OK'
  • Click the 'Menu' buttton
  • Select 'Root Explorer'
  • Select 'RO' again for '/system'
  • Click on 'OK'
  • Click 'Home'
Start Torque Pro
GreenPants is offline   Reply With Quote
Old 12-13-2013, 03:58 PM   #16
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Step-by-step guide
  • Open Applications
  • Click 'OK'
  • Click 'OK'
  • Click on 'OK'
  • Click 'Home'
Start Torque Pro
That's great! So I will try tmw morning !!!! and about car Kit? how to solve? or how to uninstall it?
Trap63 is offline   Reply With Quote
Old 12-13-2013, 04:02 PM   #17
sciallo
Drives: 4 wheels and a steering wheel
Will this not cause other issues to come back (with market if I recall)?
sciallo is offline   Reply With Quote
The Following User Says Thank You to sciallo For This Useful Post:
Trap63 (12-13-2013)
Old 12-13-2013, 04:11 PM   #18
GreenPants
It's a file I specifically created/added in to provide support for USB Serial OBD2 adapters, based off information at various places on the internet, for example, the Treehouse Blog. The file is used to make Torque think it is running on a CaFi unit.
I didn't have Torque Pro at the time, so could not test. As @Trap63 pointed out, it had the side-effect of not allowing the usual selection of BT/Wi-Fi/USB.
Removing the file will make the firmware/Torque behaviour the same as v3 - that never had the file in the first place.
Old 12-13-2013, 04:20 PM   #19
GreenPants
The Google Car Kit was added in simply to play around with. It normally can't be installed on our version of Android, so I thought it was worth baking in for folks that may be interested in using it - and unfortunately this may include some functionality that doesn't work correctly, such as the phone.
It was included v3 as well. At the end of the day, it is just another installed app. Nothing says that you have to use it, so I'm a little bit puzzled about why you want to uninstall it.
Or are you saying that you played with it a bit and can't get it to shutdown now/are stuck with its UI?
Old 12-13-2013, 04:29 PM   #20
Trap63
Trap63's Avatar
Oh ! GreenPants it's only a my drama! ahahahaha, I open phone with shortcut and no trouble, but it's nice to see this apk on home desktop.
Old 12-16-2013, 02:21 PM   #21
Trap63
Trap63's Avatar
V4 tested with suggestion to delete above dir to avoid Torque Pro noise about interface connection. All IT'S OK!
Old 12-30-2013, 10:44 PM   #22
jakejm79
Drives: Saab
SW Controls
@GreenPants Not sure if your Subarus/Scions/Toyotas have steering wheel controls and if they function with this unit, but if they do I have got steering wheel controls working in all android apps not just the included ones with the unit.
Details are here: http://forum.xda-developers.com/show...postcount=2240
jakejm79 is offline   Reply With Quote
The Following User Says Thank You to jakejm79 For This Useful Post:
Trap63 (06-15-2014)
Old 01-05-2014, 09:07 PM   #23
GreenPants
Our cars don't have steering wheel controls, but I believe that some folks are putting in after market versions.
I will absorb your fix into the next release - it shouldn't hurt in any case.
Thanks.
Old 01-06-2014, 07:02 AM   #24
kharn83
Drives: S15 Silvia
Hiya GreenPants, and all others reading the thread,
I tried the workaround for v4 for Torque, i.e. deleting carit_version2 - it seems now for some reason I can select BT, but when torque tries to connect to the adapter, once it connects to the BT OBD adapter, the BT dongle turns off, then turns on again. Not sure why Torque is doing it now, but it didnt seem to happen with the old firmware.
I tried flashing back to the v3 firmware and still had the same issue, anyone have any ideas on why this might be? I checked to see if carit_version2 had been restored but it was still missing - If someone could send me the file again that might fix the issue potentially?
Please pm if you still have this file - Thanks in advance!
Rob
kharn83 is offline   Reply With Quote
Old 01-06-2014, 07:10 AM   #25
Trap63
Trap63's Avatar
Rob
verify in general, settings of torque. Now BT can be open or close on startup and/or exit from torque.
Old 01-06-2014, 07:43 AM   #26
GreenPants
Rob
V3 will not restore the carit_version2 file - it was only added in v4 to allow USB cables that appear as serial ports to the operating system to be used. If you are not using a USB Serial OBD2 cable, you don't want a carit_version2 at all!
I have always found the BT to be a bit unstable - I'm not sure if it is because of interference, lack of USB power, quality of the BT dongle, being inside a metal car etc...
Make sure that the BT USB dongle has enough power. Don't use it off a hub (if you use a hub, make sure that it is a powered one).
Make sure that you installed Quick Bluetooth, and used that to set up the BT pairing with the OBD2 dongle. Make sure you pair the device before attempting to use torque.
The Following User Says Thank You to GreenPants For This Useful Post:
kharn83 (01-06-2014)
Old 01-06-2014, 08:48 PM   #27
kharn83
Drives: S15 Silvia
Thanks for the info and reply GreenPants - yeah.. I'm guessing it might be something to do with the quality of the BT dongle I'm using and the facts in a car.
I tried using a different OBD2 adapter following the steps you mentioned and it worked, but my original OBD2 adapter wouldnt work, even though the original OBD2 adapter was able to connect to torque with my phone - I suspect its probably something to do with the USB BT adapter I'm using. For the moment Im happy enough using the OBD2 adapter that does work!
Which USB BT Adapter are you using at the moment and which OBD2 adapter are you using if you dont mind me asking?
Cheers
Old 01-06-2014, 09:52 PM   #28
GreenPants
I've just got a cheap BT USB Dongle and one of those generic small blue ELM327 adapters from dx.com. They seem to work (for the most part), but I don't use Torque on a regular basis so can't really say how good/bad they perform.
I also acquired a cheap USB Serial OBD2 cable before Xmas, but still haven't plugged it in to try.
Android Head Unit CA-FI Knock off already rooted. ph0en1xtk Audio/Visual, Electronics, Infotainment, NAV 7 10-29-2013 01:40 PM
Who's interested in a full Android head unit? 2forme Electronics | Audio | NAV | Infotainment 307 10-05-2013 10:56 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
How do Android phones work with the stock head unit? FastLap Electronics | Audio | NAV | Infotainment 14 10-09-2012 11:34 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
