#421 |
Drives: 2015 Scion FR-S
#422 |
Thee O-ri-gi-na-tor
#423 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
not meaty per say but it does look the part! i bet it handles much better now too!
#424 |
Those of you running meaty tire setups have probably run into this... Has anyone had issues with the cables running to the parking brake? I'm running 18x10 et37 out back and both sides have significant wear on the outer edge closest to the wheel. From what I can see there is clearance between the wheel/tire and the metal strap that is there to protect the cable, so I'm not sure what is causing it.
Is there supposed to be a rubber bushing to hold the cable in place, or is it just the cable and the metal piece for protection? Thanks for any help on this. I have searched and haven't found any topics related to this concern. Edit: FYI, the tires that came on these wheels are 235/40, so they're stretched slightly. Planning on running 265/35 when they're toast, but I am concerned about clearance now. Also worth noting it's tucking a little tire on BC coilovers.
#425 |
Drives: 2013 Hot Lava FR-S 6 MT
You have to remove the ebrake guards and bend them so that they do not rub ... i actually bent mine while under the car using some brute man strength ... I'm sure patience is a bit better idea and removing the and doing it with a bit more precision ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#426 | ||
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#427 |
Drives: Subaru BRZ 2013
Hey Guys,
Was wondering if someone could tell me the meatiest square set-up I could go with on stock suspension without any rubbing issues. Just read this entire thread, seems like the questions been asked but never answered lol. Set-up would be for 18 inch wheels (TBD). Would like to go squared, or if staggered maybe go with something like a (f) 235/40/18 & (r)255/35/18 setup. I know some tires run wider than others, but just looking for a bit of guidance. Thanks! |
#428 |
AutoX-10/10ths every run
275/40R17 R Comps on 17x9ET45 RPF1s mounted for test fitting this weekend before I buy a fresh set if they fit.
| The Following 3 Users Say Thank You to whataboutbob For This Useful Post: |
#429 |
the tuna, no crust.
^any updates on those?!?!
| The Following User Says Thank You to Jive Turkey For This Useful Post: | whataboutbob (01-14-2014) |
#430 | |
the tuna, no crust.
#431 |
On my setup, 17x9et45 RPF1s, with about a 1 inch drop all around, they really don't fit. There is contact with the fender lip and the plastic piece in the rear under compression, and in the front the tire is hitting the firewall at the rear of the wheelwell under full lock.
![]() This setup is for AutoXing, and I need to be sure that I won't have contact AT ALL. They might fit if you are willing to do some fender rolling/pulling, but I am not willing. YMMV
#432 |
Drives: 2013 FRS, 2008 R32
![]() ![]() ![]() 265/35's |
| The Following 5 Users Say Thank You to mfbmike For This Useful Post: | Ammonia (01-16-2014), evo4g63 (02-20-2014), MightyMeeple (01-14-2014), PRORICAN (01-18-2014), suaveflooder (02-20-2014) |
#433 | |
the tuna, no crust.
call me derrick zoolander. and only going forwards. the rear will rub itself out, its most likely that bumper tab area. |
| The Following User Says Thank You to Jive Turkey For This Useful Post: | whataboutbob (01-15-2014) |
#434 |
Drives: Ultramarine '13 FR-S
Some meat all around 255/35/18 on enkei rs05rr's.
Sent from my SCH-I605 using Tapatalk |
| The Following 8 Users Say Thank You to UltraMarine86 For This Useful Post: | argonaddict (02-20-2014), Freshfrs86 (01-18-2014), Goya (01-17-2014), Jmonty (01-16-2014), LtS720 (01-20-2014), RehabJeff86 (01-18-2014), sprintertrueno86 (01-16-2014), switchlanez (01-16-2014) |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
