Old 01-05-2014, 02:49 PM   #421
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Originally Posted by VenomRush View Post
Stock WRX Wheels and Tires. 17x8 +53 235/45
I thought the meaty fitment was 255+?
Those wheels do look a lot better than factory BRZ wheels though.
Travisty75 is offline   Reply With Quote
Old 01-05-2014, 02:56 PM   #422
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
lol im such a noob, i took the word at face value, just thought it meant the tires look meaty
VenomRush is offline   Reply With Quote
Old 01-07-2014, 12:37 AM   #423
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
not meaty per say but it does look the part! i bet it handles much better now too!
Jive Turkey is offline   Reply With Quote
Old 01-07-2014, 08:42 AM   #424
dmarkey
Those of you running meaty tire setups have probably run into this... Has anyone had issues with the cables running to the parking brake? I'm running 18x10 et37 out back and both sides have significant wear on the outer edge closest to the wheel. From what I can see there is clearance between the wheel/tire and the metal strap that is there to protect the cable, so I'm not sure what is causing it.
Is there supposed to be a rubber bushing to hold the cable in place, or is it just the cable and the metal piece for protection? Thanks for any help on this. I have searched and haven't found any topics related to this concern.
Edit: FYI, the tires that came on these wheels are 235/40, so they're stretched slightly. Planning on running 265/35 when they're toast, but I am concerned about clearance now. Also worth noting it's tucking a little tire on BC coilovers.
dmarkey is offline   Reply With Quote
Old 01-07-2014, 11:57 AM   #425
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
You have to remove the ebrake guards and bend them so that they do not rub ... i actually bent mine while under the car using some brute man strength ... I'm sure patience is a bit better idea and removing the and doing it with a bit more precision ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following 2 Users Say Thank You to TrogDor the Burninator For This Useful Post:
6-Shift (02-11-2014), dmarkey (01-08-2014)
Old 01-07-2014, 01:32 PM   #426
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The Burninator nailed it. They are easy to bend inwards and you can probably get another half inch of clearance and they will still function to keep the parking brake cable in place.
Old 01-08-2014, 02:46 PM   #427
harkbrz
Drives: Subaru BRZ 2013
Hey Guys,
Was wondering if someone could tell me the meatiest square set-up I could go with on stock suspension without any rubbing issues. Just read this entire thread, seems like the questions been asked but never answered lol. Set-up would be for 18 inch wheels (TBD).
Would like to go squared, or if staggered maybe go with something like a (f) 235/40/18 & (r)255/35/18 setup.
I know some tires run wider than others, but just looking for a bit of guidance.
Thanks!
harkbrz is offline   Reply With Quote
Old 01-08-2014, 10:13 PM   #428
whataboutbob
AutoX-10/10ths every run
275/40R17 R Comps on 17x9ET45 RPF1s mounted for test fitting this weekend before I buy a fresh set if they fit.
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
Jive Turkey (01-13-2014), suaveflooder (02-20-2014), TouchMyHonda (01-13-2014)
Old 01-13-2014, 10:56 PM   #429
Jive Turkey
the tuna, no crust.
^any updates on those?!?!
The Following User Says Thank You to Jive Turkey For This Useful Post:
whataboutbob (01-14-2014)
Old 01-13-2014, 10:57 PM   #430
Jive Turkey
the tuna, no crust.
Originally Posted by harkbrz View Post
Hey Guys,
Thanks!
it also depends on the wheel width and offset! if you read king tut's thread he had this issue!
Old 01-14-2014, 01:03 AM   #431
whataboutbob
On my setup, 17x9et45 RPF1s, with about a 1 inch drop all around, they really don't fit. There is contact with the fender lip and the plastic piece in the rear under compression, and in the front the tire is hitting the firewall at the rear of the wheelwell under full lock.
This setup is for AutoXing, and I need to be sure that I won't have contact AT ALL. They might fit if you are willing to do some fender rolling/pulling, but I am not willing.
YMMV
Build thread:Here
Old 01-14-2014, 02:09 AM   #432
mfbmike
Drives: 2013 FRS, 2008 R32
265/35's
mfbmike is offline   Reply With Quote
The Following 5 Users Say Thank You to mfbmike For This Useful Post:
Ammonia (01-16-2014), evo4g63 (02-20-2014), MightyMeeple (01-14-2014), PRORICAN (01-18-2014), suaveflooder (02-20-2014)
Old 01-14-2014, 02:08 PM   #433
Jive Turkey
the tuna, no crust.
YMMV
i rub under full lock with my setup too, but only going left call me derrick zoolander. and only going forwards.
the rear will rub itself out, its most likely that bumper tab area.
whataboutbob (01-15-2014)
Old 01-16-2014, 05:07 PM   #434
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
Some meat all around 255/35/18 on enkei rs05rr's.
Size:  129.5 KBName:  uploadfromtaptalk1389909763524.jpg
Size:  121.6 KBName:  uploadfromtaptalk1389909789168.jpg
Size:  84.9 KBName:  uploadfromtaptalk1389909807266.jpg
Size:  103.3 KBName:  uploadfromtaptalk1389909823780.jpg
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
The Following 8 Users Say Thank You to UltraMarine86 For This Useful Post:
argonaddict (02-20-2014), Freshfrs86 (01-18-2014), Goya (01-17-2014), Jmonty (01-16-2014), LtS720 (01-20-2014), RehabJeff86 (01-18-2014), sprintertrueno86 (01-16-2014), switchlanez (01-16-2014)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
