Old 01-04-2014, 01:01 PM   #19853
nelsmar
Sounds like something is unplugged to me but I havent looked at the wiring for this car to see how it worked. I figured the unlock button would be the same wiring as the RF system but maybe it isn't. There is a thread somewhere with a PDF of the full wiring of the car, that might be of use.
My flickr - Canibeat
Local magazine scout
Old 01-04-2014, 01:03 PM   #19854
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
A bin of sexy parts for sale.
The Following 3 Users Say Thank You to BugeyedWagon For This Useful Post:
jeffsides (01-04-2014), Jouki (01-04-2014), Reverted (01-04-2014)
Old 01-04-2014, 02:08 PM   #19855
Yruyur
Yruyur's Avatar
Updated. Some are pending but money talks
Ok folks selling it all.
Selling locally then posting in the classifieds. Want things gone by Monday morning. Text me 623-252-3567
Pending - $1100 - OEM Audio Reference Series stereo, amp, sub
Pending - Flex Fuel kit and tune by ECUtek, Pending - ECUtek Cable, ECUTek Dongle, No Cut ECU Adapter ,has been Dyno Tuned.
Pending $500 Sparco Arsetto 18X8 Wheels with tpms sensors and we'll worn BFG SportComp
$140 - Airaid Intake
$200 - Magnaflow custom catback exhaust with DC black tips welded comes with Magnaflow glasspack on the midpipe to remove any rasp
$50 - J2 engineering catless front pipe.
$360 - Morimoto HID reteofit with black out chrome headlights
$360 - Red out spyder/sonar taillights
$100 - V3 Triton DRL switchbacks
$300 - FineVu CR500 HD Dashcam
$280 - Kartboy short shifter with whiteline and positive shift bushing
$60 - Smoked side markers
$200 - Tien sport lowering springs 1.5 inch
$80 - Perrin lightweight pulley
Sent from my SCH-I545 using Tapatalk 2
Old 01-04-2014, 02:33 PM   #19856
captain_jack
captain_jack's Avatar
Originally Posted by nelsmar View Post
Thats quite odd if the physical button works on the car, but not the keyless RF unlock on the drivers side... I would have to check techstream to see if there is anything to adjust in there. As I am not sure... typically most cars it is all or none. It seems like there was a setting for not unlocking the passenger door but i forget if that was this car or not.
Not really, the button on the handle operates the lock internally but the keyless control box is inside the car. So there could be a wire or 2 that were severed in the door boot from the accident. would check the lock switch inside the car and verify it controls the drivers lock. If it does then this is a weird problem.
sent from your mom
Old 01-04-2014, 02:36 PM   #19857
Jouki
Drives: FR-S 10 Series #805
The thing is that the accident was minor damage but enough to cause the door and fender to be replaced. It worked before I took the car in to get fixed even with the damage. I'm primarily looking to figure it out so I don't have to go all the way back there come Monday.
Jouki is offline   Reply With Quote
Old 01-04-2014, 02:41 PM   #19858
captain_jack
Does it work from the lock switch inside the door. Not the external button on the door handle but the lock/unlock buttons.
sent from your mom
Old 01-04-2014, 02:43 PM   #19859
Gusha0426
Gusha0426's Avatar
Drives: 2013 Pearl white FRS
Pavs anybody? Probably will be there around 7 or so..
Sent from my HTC6500LVW using Tapatalk
Gusha0426 is offline   Reply With Quote
Old 01-04-2014, 02:53 PM   #19860
Jouki
I just went outside to double-check. The key fob buttons will unlock or lock the car like normal when pressed. The door handle on the outside when touched does not unlock the door like its supposed with keyless entry. The thumb "touch button or lines" on the outside handle also do not lock or unlock the door. When inside the car, the unlock and lock buttons next to the window up/down and side rear views does work either locking or unlocking the car.
When attempting the same thing on the passenger door it works as usual. Unlocked when outside handle is grabbed or touched and locked when using the thumb section on the outside handle.
The Following User Says Thank You to Jouki For This Useful Post:
captain_jack (01-04-2014)
Old 01-04-2014, 02:58 PM   #19861
Yruyur
Yruyur's Avatar
Anyone need moving boxes... i have a stack for free. Need them gone.
Old 01-04-2014, 03:02 PM   #19862
captain_jack
[QUOTE=Jouki;1429879]I just went outside to double-check. The key fob buttons will unlock or lock the car like normal when pressed. The door handle on the outside when touched does not unlock the door like its supposed with keyless entry. The thumb "touch button or lines" on the outside handle also do not lock or unlock the door. When inside the car, the unlock and lock buttons next to the window up/down and side rear views does work either locking or unlocking the car.
Sent from my Nexus 5 using but the windows do roll up and down from the driver door right? It is feesable that the keyless actuator isnt plugged in inside the door.
sent from your mom
Old 01-04-2014, 03:04 PM   #19863
Jouki
I will have to open up the card door and make sure its all plugged in or something because the windows do go up or down and side rears adjust. Do you know if that keyless actuator is easy to spot?
Old 01-04-2014, 03:05 PM   #19864
Reverted
Reverted's Avatar
Drives: 2014 BRZ Limited WRB MT
Attachment 62102
Which steering wheel is that again and how much do you want for it?
Reverted is offline   Reply With Quote
Old 01-04-2014, 03:09 PM   #19865
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Is anyone hitting the Pavs tonight?
Shad0ez is offline   Reply With Quote
Old 01-04-2014, 03:11 PM   #19866
Shad0ez
Shad0ez's Avatar
Originally Posted by Reverted View Post
I had it too. Buy a 7/8 inch plug from Home Depot and plug the sound tube hole in the passenger foot well see if it quiets or eliminates the noise. If it does then it was the sound tube resonator rattling against the engine cover. The mount for the stupid cylindrical resonator is so flimsy it wiggles really easily when you touch it.
There is also a little plug that's used for the 12v adapter inside your glove box. Perfect fit and best of all free
The Following User Says Thank You to Shad0ez For This Useful Post:
