Old 12-31-2013, 01:22 PM   #141
Gen
Drives: Scion FR-S
New downpipe...look at all that room! Heatshields were integrated to protect the maf. I can fit my arm through there. I am hoping better fans will help, granted I've seen 220 degrees cruising at 70 mph on the freeway.
Anyone had any luck with removing the windshield wiper cowel?
Gen is offline   Reply With Quote
Old 12-31-2013, 03:16 PM   #142
pmccut
Drives: Blue Subarus
Who created the new downpipe? Mo pics!
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 12-31-2013, 04:12 PM   #143
mike the snake
What brand is your new downpipe?
My car has the FB kit, and with the thicker radiator, the fans are nearly touching the downtube, and I suspect the fans will melt almost for sure.
Old 12-31-2013, 04:24 PM   #144
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Originally Posted by FullBlown View Post
The fans that we provide flows 1150cfm
Spal fans depending on thickness will flow 1300cfm and up. We have a few on order to see which ones will work. We will also will be testings the fans that we provide with the shroud as well.
@FullBlown have you tested the larger fans with the shroud yet? I am still doing well under normal conditions but when pushing the engine hard over a minute or two of aggressive driving the water temp starts rising fast I am considering picking up the shroud but I might want to upgrade the fans at the same time. Another question, the price your website does that include the fans? The photo had them installed that's why I ask.
toekneehair is offline   Reply With Quote
Old 12-31-2013, 04:24 PM   #145
Gen
Drives: Scion FR-S
It was a custom piece done by a local shop, so no particular brand. It's pretty close to the MAF now, but should be okay.
Old 12-31-2013, 04:26 PM   #146
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We should have results soon
FullBlown is offline   Reply With Quote
Old 01-02-2014, 03:49 PM   #147
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by jamesm View Post
i'm going to try removing the plastic thing up by the windshield wipers. see if it makes any difference...
Did it make a difference?
Old 01-04-2014, 01:19 AM   #148
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I'm just an outside speculator but running the turbo upfront, to me, just doesn't seem like a good idea. Turbos are pure heat in the engine bay and placing it right up against the rad just isn't a good idea if you ask me. Our cars just weren't designed to take on that kind of heat. This is why I think Ptuning has the best kit as they mounted their turbo under, behind, and away from the engine.
hmong337 is offline   Reply With Quote
The Following 2 Users Say Thank You to hmong337 For This Useful Post:
glorydays (01-04-2014), PStaff716 (01-06-2014)
Old 01-04-2014, 01:39 AM   #149
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
At Pikes Peak front bumper had ducts for everything to keep the motor cool. We even had to add a water spray system for the car on the way up for the heat and thin air. From test at the track for stock and turbo cars we recommend getting a oil cooler and running motul 300v or eco engery for cooler temps and more volume. For the turbo guys you can coat your downpipe and wrap it to keep it cooler in the engine bay. Also for the turbo you can run a turbo blanket. The stock radiator is kinda a weak point being super plastic but I would upgrade to a Koyo. Also last a vented hood will also extract most of the heat out.
Oil cooler for motor
Oil cooler for supercharger
Brake duct cooler
Radiator vents with a slight v mount
Intercooler with water spray
Intake with duct
Vented hood
Evasive Motorsports is offline   Reply With Quote
The Following 3 Users Say Thank You to Evasive Motorsports For This Useful Post:
Kakawate (01-08-2014), mike_ekim1024 (01-08-2014), pmccut (01-04-2014)
Old 01-04-2014, 01:45 AM   #150
Dipstik-sportech
Dipstik-sportech's Avatar
Hmmmmm, now that Evasive just posted that throws your theory out the window.
Sent from, The Frozen North
Old 01-04-2014, 01:45 AM   #151
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
add an air restricting FMIC to an engine bay with a paper thin radiator and no ventilation and you get an easy bake oven. I dont know if the guys running the frontt turbo setups have many problems on the street or in traffic but i agree that it doesnt look like a good idea. ive noticed that many if not all of them have the intake crossing right over the hotside which cant be good either but again this is just speculation. personally i like the top mount like the D3P kit, but its next to the battery...
glorydays is offline   Reply With Quote
Old 01-04-2014, 02:23 AM   #152
pmccut
Same. I'm definitely going to try out the fans/shrouding once LJ has them ready. If mountain driving doesn't push the temps as much I'll take it back to the track and see if it can last more than 2 laps. Vented hood seems to be the next on the list.
I'd love to see evidence on this as well. I really like the ptuning kit + turbo placement. Has anyone tracked their kit yet ?
Old 01-04-2014, 03:32 AM   #153
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Finding a nice looking vented hood seems to be difficult to obtain however :---(
The Following 2 Users Say Thank You to OICU812 For This Useful Post:
Dinko (01-08-2014), mack4477 (01-04-2014)
Old 01-04-2014, 09:02 PM   #154
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
Here is the drawing of our shroud. It's design to helps pull the heat from the whole radiator surface.
I'll buy one of these too
SilverSkyline210 is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
