Old 01-03-2014, 06:21 PM   #197
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by Jdogg88 View Post
I see what you're saying, and I agree that the 1jz would be the better investment. You planning on using a r154 or v160?
Keep up the good work dude, stoked to see this build continuing to grow and help me out for my future plans
R154. That trans will easily support the power I want.
I'm more than content with 350whp and could never see myself wanting anymore than that. If I did, I'd say 400-450whp MAX but that would be on E85 and as a strictly track only car.
Old 01-03-2014, 06:50 PM   #198
gk
Drives: 2013 Raven FR-S
Looking forward to the riser install. Also, may I ask where you ordered them from?
gk is offline   Reply With Quote
Old 01-03-2014, 06:55 PM   #199
TylerLieberman
Drives: '24 GR86
http://www.partsshopmax.com/page.php?17
The Following User Says Thank You to TylerLieberman For This Useful Post:
gk (01-03-2014)
Old 01-03-2014, 07:20 PM   #200
gk
Thanks and are you gonna get a shop to do the install or do it yourself?
Old 01-03-2014, 08:21 PM   #201
TylerLieberman
Drives: '24 GR86
Do it ourself. I have somebody who can weld. The rest is just a matter of dropping the subframe and putting it back in after everything is installed
Old 01-04-2014, 02:45 PM   #202
gk
Sweet, thinking about doing this mod too. Would you mind taking pictures of the steps you take during the install?
Old 01-04-2014, 06:35 PM   #203
TylerLieberman
Drives: '24 GR86
I'll be overseas. A good friend will be doing it for me here. I'll ask him to take some pictures though
Old 01-04-2014, 08:29 PM   #204
TylerLieberman
Drives: '24 GR86
Installed the Stance LCA's and got an alignment today.
I installed the control arms and dropped the car and was sitting at this height:
A bit too much for me seeing how the axle angle was extremely jacked up and there was still not much suspension travel. So, I raised the rears up by about half an inch and got to about the same ride height as before.
After that, I went and drove it around and could tell that it was definitely off alignment so I went and got it taken care of. Unfortunately, the stock toe links are maxed out so the best I could do is -1.8 camber in the rear while still maintaining zero toe.
So I'm going to get some SPL Titanium Rear Toe Links to help get the extra adjustment I need and I'll end up going back down to -1.5 camber with 0 toe again.
So now the car is all good for me to drive around on until I leave. I can't wait to start getting everything ordered for the car. It's going to be amazing when I come back.
In the meantime, I have a few parts that I'm going to be installing on my wife's car next weekend ('13 Focus ST). I'll post some pics of that I suppose
Old 01-09-2014, 11:11 PM   #205
TylerLieberman
Drives: '24 GR86
So this is how it sits now:
I leave in a few days to the middle east and won't be back until around the end of the year. The car is pretty much just going to sit the entire time and I'll accumulate some things for it while I'm gone.
That being said, this is gonna be the last update for this thread until around October time most likely. How much I post from here on out just depends on how much free time I have to **** around on the forums when I'm over there.
Until then guys..
Old 01-10-2014, 03:14 AM   #206
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Good luck over there Tyler, till then cheers.
The Following User Says Thank You to OICU812 For This Useful Post:
TylerLieberman (01-10-2014)
Old 01-10-2014, 12:12 PM   #207
kylefrs
kylefrs's Avatar
Drives: Scion FRS
Did you bypass the srs light when you installed the aftermarket steering wheel?
kylefrs is offline   Reply With Quote
Old 01-10-2014, 05:32 PM   #208
TylerLieberman
Drives: '24 GR86
Yeah. Just make sure everything is lined up within the steering hub/clockspring properly.
You can also check out the SRS light delete DIY here on the forums. It's just a matter of putting a resistor into one of the plugs under the driver seat. Super easy.
Old 01-10-2014, 08:46 PM   #209
kylefrs
kylefrs's Avatar
Drives: Scion FRS
Ok thanks. Super helpful
Old 02-17-2014, 01:50 AM   #210
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Nice build Tyler! Just sent you a message.
Drift&Drag is offline   Reply With Quote
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 03:09 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Five Axis Spoiler - Painted "RAVEN" Black that_guy Canada Classifieds 29 12-18-2012 09:34 AM
