Old 01-03-2014, 12:38 AM   #1107
Dezoris
Dezoris's Avatar
Originally Posted by DJCarbine View Post
Its going to be -10F in a few days, time to find the limits of the cold weather starting
You got balls, I parked mine. Sounds horrible, can't even tell if its the blower, pulleys or a combo at this point and its too cold to be sitting there troubleshooting.
Old 01-03-2014, 08:17 AM   #1108
DJCarbine
Thupercharged
DJCarbine's Avatar
I can't tell a huge eifference in sound on a cold start, slight whine but thats it
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 01-03-2014, 04:23 PM   #1109
Foobar
SLO NO MO
Foobar's Avatar
Same here. It was 11 degrees here today and no problems at all.
Old 01-05-2014, 09:16 PM   #1110
Cal3000
Drives: Panda FR-S
I've been on a few spirited, full throttle drives in 100 degree weather. Heat has never been an issue. I don't have an oil cooler and I monitor oil temps and they peak at about 119 Celsius on these hot days and quickly lowers back down to about 109 Celsius when you begin to drive normal again. The cooling system on this car is great and I probably don't see a need for an oil cooler if you are not going to track your car and do a few pulls here and there.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 01-05-2014, 10:16 PM   #1111
VroomVroom86
VroomVroom86's Avatar
Drives: 2013 Firestorm FRS MT
Just wondering if the zeek snorkel would be compatible with the vortech airbox?
VroomVroom86 is offline   Reply With Quote
Old 01-05-2014, 11:49 PM   #1112
DJCarbine
Thupercharged
DJCarbine's Avatar
While I don't have my snorkel installed, I'm pretty sure the vortech airbox hooks up to the factory one... it should be compatible but might require minor modifying
2013 FRS
Vortech V3 11psi
Old 01-06-2014, 09:48 AM   #1113
Foobar
SLO NO MO
Foobar's Avatar
Should be a direct fit.
Old 01-06-2014, 10:37 PM   #1114
DJCarbine
Thupercharged
DJCarbine's Avatar
So far so good
2013 FRS
Vortech V3 11psi
Old 01-13-2014, 10:56 AM   #1115
Philly758
Drives: GMC
I'm in the process of installing my Vortech Supercharger, by myself, which is kind of a pain. I attempted to install the intercooler yesterday and I’m not happy with the outcome. I was hoping to get some feedback or pointers from those with experience. So, any advice on getting this mounted up correctly?
The issue I am having is that I cannot move the intercooler supports as far back as they are shown in the instructions, as it conflicts with the lower A/C condensor connection/bolt on the driver side and the horn mount on the passenger side (I already bent the tab out of the way on the passenger side, whether that was really required or not). The instructions also say that the intercooler should be mounted parallel to the A/C condenser, where I have it now is pretty damn parallel, if I mounted it where the instructions show it then it would not be parallel. As a result, I decided to mount the intercooler farther forward... Is there any issue with having it this way? I really don’t feel like drilling again and making my bumper beam swiss cheese (it would be lighter though).
Thanks in advance!
Working by yourself sucks:
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 184KB. This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 184KB.
This is where I ended up drilling my holes (driver's side, front of car is to the left)::
Picture from Vortech's instruction manual for reference (driver's side, front of car is to the left):
This image has been resized. Click this bar to view the full image. The original image is sized 1500x2000 and weights 1675KB. This image has been resized. Click this bar to view the full image. The original image is sized 1500x2000 and weights 1675KB.
Philly758 is offline   Reply With Quote
Old 01-13-2014, 11:27 AM   #1116
nelsmar
I'm on my phone but from the looks of it you mounted the intercooler too far back at the too. It should be parallel and that picture looks like it is a good 5-10 degrees off. Also you could take a file and slot the top of the bracket a bit that may help get some angle. If I recall I also relocated my horn to the area behind the passenger side turn signal. But it's been a long while since I have looked at it!
My flickr - Canibeat
Local magazine scout
Old 01-13-2014, 12:13 PM   #1117
Philly758
Drives: GMC
Thanks for the response. The picture showing the intercooler NOT parallel to the A/C condensor is from Vortech's instructions... However, the instructions tell me to mount the intercooler parallel to the A/C condensor. I think I did it correctly, but all of the pictures show it further back, including Vortech's instructions and RallySportDirect's DIY.
Page 23 from Vortech's instructions:
On the top, outboard corners of the charge-cooler are the upper mounting brackets. Carefully position the cooler so as to be centered, and parallel with the A/C condenser, then adjust the upper mounting brackets (they are slotted for adjustment).
The horn has been relocated, but the tab that some sensor clicked into was in the way, you can see it in this picture from Vortech's instructions. It's the tab perpendicular to the A/C condenser, you can see that Vortech also unclipped it, I was just going to zip tie it to the side of the bracket when done:
Old 01-13-2014, 12:22 PM   #1118
Philly758
Drives: GMC
Maybe this MS Paint picture will better explain what I am talking about.
Old 01-13-2014, 12:30 PM   #1119
nelsmar
Ignore where vortech may or may not have drilled holes and just go by what fits. The docs I used when I installed mine had a lot of issues but I think they revised it since then. Now that I am at a computer it looks like you have far too much lean on that intercooler and its crushing against the ac condensor. I would re-drill as needed and push it further away. Just make it fit thats all that really matters. Don't wory about trying to do 100% to the doc. Just get it to fit within reason. Not every kit for a car is going to fit perfect. Anything that requires drilling has a bit of "room" for error. If it was extremely important for the exact angle to be made I am sure vortech would have supplied a template for drilling or at least measurements. So really dont sweat it just line the intercooler up to where it fits, and then drill. I personally had re-slotted my mounts and modified them (or maybe I made new ones I don't even remember). But I also mounted mine a little different. I put "studs" in my crash beam to mount my intercooler to.
Old 01-13-2014, 01:07 PM   #1120
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
What I did:
-Slide intercooler onto lower tab (the one that runs beneath the radiator towards the front of the car)
-Loosely attach mounting brackets to intercooler
-Push radiator up to the bumper beam as tight as possible
-Mark and drill holes in bumper beam
All was a major pain in the ass for one person, but it is possible. The only interference was the temp sensor, but that was easily pushed out of the way. Mine had a very slight angle to it when mounted.
Parting out HERE
civicdrivr is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
