#281 | |
| The Following User Says Thank You to wparsons For This Useful Post: | 7thgear (12-24-2013) |
#282 |
Drives: Subaru BRZ Sport Tech Satin White
#283 | |
Disabling Window Auto Up/Down
http://www.ft86club.com/forums/showthread.php?t=25229 Side Notes: Do this adjustment at your own risk though, be careful closing your doors after making this adjustment because it makes the top of your glass the first point of contact when closing your doors which means it could shatter easier if you close the door too hard. When adjusting the screw back in place, toy with it a bit so that the default position when the door is open is the window in its highest position. This will change a few settings: 1. The car will now be unable to detect if the doors are open or closed. 2. Normally after unlocking the car via the keyless fob, you would have about a minute or so to open a door before the car locks itself. This feature will now only realize you are in the car after you put the key in the ignition and turn it one notch. The danger of this is opening your door and putting your keys inside for whatever reason and closing the doors again. It hasn't happened to me but just something i noticed and thought I should share. Even aside from those cons, I think this was the best thing i did for winter, I got very annoyed at how much these windows struggled with frost and find that this works well for me. |
| The Following User Says Thank You to aghuman For This Useful Post: | Kfresh23 (12-26-2013) |
#284 |
Drives: 2010 civic Si
My g35 coupe with me in it is ideal 50/50 weight and I am in Edmonton and I drove this car through hell and back on this winter lol never got stuck once I actually feel a lot safer in it than any car I have owned. One thing is the VDC is weird it doesn't work at all on Ice. So it's usually off, car gribs and go it might gotta be with it being almost 3700lbs lol and I have 215-55-17 since my stock wheels are 19s I think the brz/frs will do better with a 205-55-16 tire!
#285 |
Is anyone driving in a lowered FRS this winter? I've got mine lowered to about 1 1/2 hand widths and while the ride has been okay, there has been mild to medium scrapage (cringe) in some icy areas, as to expected.
Comments? Concerns? I'd love to hear them. |
#286 | |
Lowering a car will increase your chances of getting stuck and there are quite a few plastic underbody panels which may be damaged on ice rutting. The front and rear plastic body panels are also vulnerable to "hooking" damage on heavy frozen stuff, just as for parking blocks and curbs. If you hook a bumper valance you can easily tear it or crack it. Subaru create a nice illusion of a low slung car but these cars are pretty normal in ride height and make good daily drivers as a result. |
#287 |
Mine's lowered almost 2 inches no problems driving around this winter. You just have to exercise common sense, if it looks like you'll get stuck/scrape, don't drive over it. Helps to have a second car for those really shitty days, but that's rare in Toronto. Thank God I don't live in Calgary though ;p
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
#288 |
Drives: '13 FR-S Raven 6MT
#289 | |
I think my memory rounded it up to 5 inches. Then mistakenly "remembered" the 5.9 number instead of the 4.9 number. Last edited by Suberman; 01-01-2014 at 07:14 PM. |
| The Following User Says Thank You to Suberman For This Useful Post: | Evil Jesus (01-01-2014) |
#290 | ||
Power Ranger Elite
Drives: '13 WRB Sport-tech
sorry for the late reply, but I'm back now!
| The Following User Says Thank You to jimmillion For This Useful Post: | daiheadjai (01-06-2014) |
#291 |
Drives: SSM BRZ
Does anyone here garage their brz/frs?
I usually park my car in a non-heated garage but found out today that garaging your car in a heated garage could speed up corrosion. The garage is usually 5-6 degrees above the outside temperature. Should I start parking outside now? |
#292 | |
Drives: Black Subaru BRZ
#293 |
My wife's car has been garaged for the last 6 years, with no rust proofing and very infrequent washing in the winter and is 100% rust free underneath. The only rust on it is in a small scratch (condo parking has it's disadvantages, like neighbours that can't drive). My MKIII jetta was parked in the same conditions and the floors started to get soft, but anyone that knows VW's knows that's what all MKIII's do.
#294 |
Drives: WRB BRZ
Oh boy...-24 this morning.
Windows frozen, car cranked slow, clutch pedal sticky, radio not turning on. Fun drive into work. |
| Tags |
| 7thgear rulz, kryptonite allergy, suberman cant drive |
| winter driving | jmaryt | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 11-11-2013 12:15 PM |
| Winter Driving Tip. | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2013 06:38 PM |
| Practice winter driving | 4U-GSE | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-26-2013 11:29 AM |
| How many are planning on winter driving? | NV Auto | CANADA | 109 | 01-11-2013 10:30 PM |
| winter driving | paraguin | BRZ First-Gen (2012+) — General Topics | 25 | 08-03-2012 06:26 PM |
