Old 12-11-2013, 08:00 PM   #701
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
stock header just trd exhaust
on website video it showed checksum box window when uploading and to make sure that pops up. i just didn't get that window but everything uploaded fine
Liquid6 is offline   Reply With Quote
Old 12-11-2013, 08:02 PM   #702
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Liquid6 View Post
stock header just ted exhaust
That should be fine since I suspect RomRaider corrected the checksum when the file was saved. Just make sure you are using v1.04 of OFT Manager as it has the checksum update for 2014 ROMs.
Shiv@Openflash is offline   Reply With Quote
Old 12-11-2013, 08:03 PM   #703
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
oh ok I'm on 1.03 does it update automatically if so it didn't
Old 12-11-2013, 08:04 PM   #704
Shiv@Openflash
Drives: 2013 FRS
Yes, it should update automatically once you run the executable for OFT Manager v1.04 (download from our website HERE). You'll know it's good when you launch the OFT Manager application and it says OpenFlash Manager 1.04 in the top of the window.
Shiv
Old 12-11-2013, 08:05 PM   #705
cnk
Drives: '13 DGM BRZ Limited
You need to download it from the www.openflashtablet.com site.
Old 12-11-2013, 08:05 PM   #706
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
ok cool thanks guys.
Old 12-11-2013, 10:58 PM   #707
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Just out of curiosity...
Does anyone know which tuners are willing/capable of tuning with OFT?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-17-2013, 02:14 AM   #708
Tiremonkey0824
Drives: 2013 Argento 6mt
Im having trouble finding the "launch control Delta table" in RomRaider. Can anybody shed some light on this situation for me?
Tiremonkey0824 is offline   Reply With Quote
Old 12-17-2013, 02:16 AM   #709
Shiv@Openflash
Drives: 2013 FRS
OFT Launch Control and FFS tables aren't defined in RomRaider (yet) because they aren't factory parameters. To adjust those parameter, you will have to use Tuner Pro.
Old 12-18-2013, 11:34 PM   #710
vgi
Drives: frs
i am not an RR dev but since it's XML based it's easy to poke around. I have made these changes to define the tables and it seems to work:
tables definition:
<table name="Launch Control Disable Speed" storageaddress="D1080" />
<table name="Launch Control RPM Delta" storageaddress="D1084" />
<table name="FFS RPM Delta" storageaddress="D1088" />
tables descriptions:
<table type="2D" name="Launch Control Disable Speed" category="Alpha - BRZ" storagetype="float" endian="big" sizey="1" userlevel="4">
<scaling units="Vehicle Speed (MPH)" expression="x" to_byte="x" format="0.00" fineincrement=".02" coarseincrement="1" />
<table type="Static Y Axis" name="" sizey="1">
<data>Disable above</data>
</table>
<description>Launch Control will be disabled above this speed</description>
</table>
<table type="2D" name="Launch Control RPM Delta" category="Alpha - BRZ" storagetype="float" endian="big" sizey="1" userlevel="4">
<scaling units="Engine Speed Delta" expression="x" to_byte="x" format="0" fineincrement="1" coarseincrement="100" />
<table type="Static Y Axis" name="RPM Delta" sizey="1">
<data></data>
</table>
<description>This table sets the required RPM delta for launch control to activate: redline (7600) - delta = launch control RPM</description>
</table>
<table type="2D" name="FFS RPM Delta" category="Alpha - BRZ" storagetype="float" endian="big" sizey="1" userlevel="4">
<data></data>
</table>
<description>This table sets the required RPM delta for launch control to activate.</description>
</table>
If someone double checks and confirms - that'd be awesome
vgi is offline   Reply With Quote
Old 12-19-2013, 02:50 AM   #711
vynervt
Drives: GT-86
tables definition:
</table>
</table>
<data></data>
</table>
</table>
<data></data>
</table>
</table>
Those xml is for JA1J___C Model only right?
vynervt is offline   Reply With Quote
Old 12-19-2013, 06:37 AM   #712
vgi
Drives: frs
Sorry, I modded RR_ZA1JA01C and pulled addresses from JA1J___C xdf file.
The Following User Says Thank You to vgi For This Useful Post:
Shiv@Openflash (12-19-2013)
Old 12-19-2013, 01:58 PM   #713
Shiv@Openflash
Drives: 2013 FRS
Looks great vgi…. you saved me some work! I'll give it shot and then make that change to all the other C family XMLs.
Old 01-02-2014, 09:32 PM   #714
BIGBUCKIT
Is this compatible with Mac?
BIGBUCKIT is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
