Old 12-31-2013, 12:34 PM   #2451
TemeCal
Drives: 86
For those of you running an intercooler, how did you bleed the system? I have the FA20Club/Sprintex kit. My pump is definitely running, reservoir is completely full, but I don't think it's fully bled.
I've been squeezing the hoses while the pump has been running, squeezing them while the car is running, but my reservoir fluid level doesn't seem to be dropping. This is making me suspicious that I don't have any fluid in the hoses, pump, heat exchanger and intercooler.
So, how are you guys bleeding the system???? Thanks!
TemeCal is offline   Reply With Quote
Old 12-31-2013, 02:26 PM   #2452
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'll be doing the same thing tomorrow, but seeing as the bottle is at the top of the system, it should pretty much do itself so long as the pump is able to move water round the system. How much fluid have you put in the system? The standard I/C kit should take 2.2l IIRC.
.: Stealth 86 :.
Kodename 47 DJ:
TemeCal (12-31-2013)
Old 12-31-2013, 02:41 PM   #2453
phloozy
phloozy's Avatar
Drives: Scion FR-S
I started thinking of an oil cooler and radiator. Would you guys say they are necessary for track use? Any recommendations?
phloozy is offline   Reply With Quote
Old 12-31-2013, 03:13 PM   #2454
sw20kosh
Drives: 2013 Black FR-S
Verify the pump is actually pushing water around. You can do this by disconnecting a clamp/hose post-pump. If significant water flow is seen while the pump is on then it is flowing.
Also as a test, try to reduce the water level in the reservoir to about 1/5 full. Turn the pump on and see if you see water swishing around / flowing in the reservoir. It should be very obvious if it is.
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 12-31-2013, 03:18 PM   #2455
TemeCal
Drives: 86
Thanks - I was actually in the process of doing this, as well as modifying the pump location. I read that it's much easier to bleed, if the inlet of the pump is below the outlet. So, we'll see how that goes.
I'll siphon out some of the coolant in the reservoir as well. Thanks for the tips.
Old 01-01-2014, 01:33 PM   #2456
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Does anyone know of any retailers selling this kit for better than the usual $3195.00 plus free shipping? Thanks!
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 01-01-2014, 03:37 PM   #2457
ntaphse
Drives: beater
I might be installing a CSF radiator soon. Also working with them to integrate na oil cooler. Stay tuned.
ntaphse is offline   Reply With Quote
Old 01-01-2014, 04:26 PM   #2458
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Just contact some of them and ask for their best shipped price. Better yet, if one is local, buy local.
Old 01-01-2014, 04:29 PM   #2459
xjohnx
Grip>Slip
xjohnx's Avatar
Robispec also has a radiator/oil cooler combo
Old 01-01-2014, 05:53 PM   #2460
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Speaking of @robispec, havent heard from him in a little while and it appears his vendor status has run out for the time being...
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 01-01-2014, 11:07 PM   #2461
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I have a write up on oil temperatures and coolers in my build thread linked in my signature if anyone is interested. It's too long to repost.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-02-2014, 12:30 AM   #2462
EAGLE5
Dismember
EAGLE5's Avatar
Anybody got a 0-60 or 1/4 mile time for the Innovate?
Old 01-02-2014, 12:40 AM   #2463
DriftEm
DriftEm's Avatar
Using torque app (I'm not sure how accurate it is), I'm getting around low 5 second (5.1 my best) very hard to launch the car without spinning wheels through 1st gear and half of 2nd gear. No 1/4 yet.
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
whataboutbob (01-02-2014)
Old 01-02-2014, 08:41 AM   #2464
whataboutbob
AutoX-10/10ths every run
Just spoke to Steve @ egertonhydraulics.com
Going to order 6 each of the following:
1) N-WES8R 1/4
2) N-WES10R1/4
3) N-GES8R 1/4
4) N-GES10R1/4
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
kster1 (01-02-2014), Pitman (01-03-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
