Old 01-01-2014, 03:00 PM   #57
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
random question, how would powdercoating this piece affect the performance? If I shouldn't I won't, but I would like it to either match my purple rims or blue te37s..lol
Would fitment be an issue because of powdercoating? It was with pulleys, which is why I had some anodized. I doubt it, but would you guys be offering anodized pieces as well?
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 01-01-2014, 03:45 PM   #58
MAPerformance
Drives: Asphalt FRS
Powder coating won't affect performance much. It will just be more for looks. We are still working out some bugs with these right now. We have tried three different throttle plates, but we are still getting a high idle (around 1400rpm's) and a CEL. Hopefully we can work out the kinks soon and get these out to some people for testing.
MAPerformance is offline   Reply With Quote
Old 01-02-2014, 05:11 PM   #59
ShutterSpeed
Drives: Olive Drab/Army FRS
This should work similarly to what Hybrid Racing is able to accomplish on the 8th Gen Civic's. J35/37 throttle body plus their 3" intake yielded incredible gains.
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
Old 01-02-2014, 06:27 PM   #60
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
SUB ED I would love to see developments ^.^
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 01-02-2014, 07:06 PM   #61
Calum
That Guy
Drives: 2013 asphalt FRS MT
Could it be a problem with the idle air control valve? Or is there an iac on these cars?
Old 01-02-2014, 09:02 PM   #62
MAPerformance
Drives: Asphalt FRS
There is a very small screw that limits the physical throttle plate gear inside the black cover that limits its angle at idle. But it still didn't seem to make any kind of a difference.
Old 01-08-2014, 10:40 PM   #63
cslntuee
Drives: Subaru BRZ Limited
Yes, soon! We actually received the throttle body that a tuning shop sent us yesterday. I believe my machinist has began the process today so we can ship it back out the them as soon as possible.
Update??
Thanks.
cslntuee is offline   Reply With Quote
Old 01-09-2014, 09:55 AM   #64
MAPerformance
Drives: Asphalt FRS
Originally Posted by cslntuee View Post
Update??
Thanks.
Not yet...we really need to get this turbo kit completed, as well as the oil pan. but its still next on the list.
Old 01-09-2014, 11:36 AM   #65
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Turbo kit and oil pan look nice so far from the posts I have seen, though .. . about this.... I look forward to seeing more on both threads
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 01-09-2014, 11:40 AM   #66
w00t692
Drives: 2008 Civic Si
All Honda throttlebodies are tapered. Good reason. Venturi ftw.
w00t692 is offline   Reply With Quote
Old 01-09-2014, 11:40 AM   #67
MAPerformance
Drives: Asphalt FRS
I know, I wish I could waive a magic wand and everything would just be completed! But, one thing at a time. We should be able to get back on this throttle body very soon though.
Old 01-09-2014, 11:42 AM   #68
w00t692
haha, you're having the same issues we had on 06-11 civic si's with aftermarket throttle bodies.
What kind of sensor measures the throttle position in these? Is it a hall sensor? or something else?
If it is, then the proximity to that black cover from the motorized drive shaft is EXTREMELY important.
Are you getting throttle position errors?
Old 01-09-2014, 12:00 PM   #69
MAPerformance
Drives: Asphalt FRS
We also had this same issue with the Evo X TB's when we were porting them. I believe the CEL was just a "high idle" code. I don't know what sensor it is to be honest, I will have to ask my R&D guy who has been working on it. I will let you know what I find out.
Old 01-09-2014, 12:13 PM   #70
w00t692
Ok if it's just high idle it might just need some graphite stuff around the edge where the throttle plate contacts the body to seal a little better.
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
