Old 12-31-2013, 02:05 PM   #197
CSG Mike
CSG Mike's Avatar
Originally Posted by Gopherboy6956 View Post
What kind of impact would a UEL or EL header have over stock header using this S/C Kit?
I assume the factory tuned version would not support a header change?
(Also - please assume a aftermarket 3" catback is installed)
Thanks!
A huge impact (increase in power) with a catless header, but yes, you will absolutely need a custom tune. Basically, you can nearly double the gains.
Check out this post.
http://www.ft86club.com/forums/showp...1&postcount=59
Old 12-31-2013, 02:12 PM   #198
OrbitalEllipses
Drives: Attitude
A little disingenuous to attribute all of that to the header Mike, c'mon. The combination of a pro-tune and header resulted in the ~100hp gain over as assumed baseline of 175hp peak. The CARB tune gives you what, ~50-60hp? Assume 20hp for each the tune and header - though I would caution that the biggest changes the tune makes will be in the shape of the curve rather than the height of the curve.
Old 12-31-2013, 02:18 PM   #199
CSG Mike
CSG Mike's Avatar
I'm saying the combination of the header AND tune. You can't just throw on the header; the CARB tune will probably freak out and go into limp from the drastic change in VE.
The CARB tune was good for a 70whp gain. From 4500-6500 RPM, the HKS header + tune doubled the gains. After 6500, the gains plateau on the header + tune, and below 4500, the torque dip elimination overshadows the gains from the HKS header + tune.
Don't focus too much on peak numbers. You're only at the peak for an instant. Rather, focus on the overall power gain.
Old 12-31-2013, 02:29 PM   #200
OrbitalEllipses
Drives: Attitude
As I said, the shape of the curve is more important - people may misunderstand "double the gain omg 140hp w000t sttrippers and cooooke!" you know?
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Calum (12-31-2013), King Tut (01-02-2014)
Old 12-31-2013, 02:30 PM   #201
CSG Mike
CSG Mike's Avatar
I threw together a quick pic...
For those that aren't sure what they're looking at
Blue area = stock power
Green area = Gains from Jackson Racing SC + CARB tune, everything else stock
Red area = Gains beyond the CARB tune with a HKS EL header, catless front pipe, and custom tune.
Lonewolf (12-31-2013), raytrix (12-31-2013)
Old 12-31-2013, 02:43 PM   #202
raytrix
Drives: Series 10 FR-S
Do you have a bigger picture, hard to read the numbers.
raytrix is offline   Reply With Quote
Old 12-31-2013, 02:53 PM   #203
Calum
That Guy
Drives: 2013 asphalt FRS MT
I almost had tears in my eyes, thanks for that.
The Following 3 Users Say Thank You to Calum For This Useful Post:
CSG David (12-31-2013), CSG Mike (12-31-2013), OrbitalEllipses (12-31-2013)
Old 12-31-2013, 02:55 PM   #204
CSG Mike
CSG Mike's Avatar
How about the original without the colors?
Old 12-31-2013, 03:09 PM   #205
OrbitalEllipses
Drives: Attitude
Still terrible, sorry.
Old 12-31-2013, 03:10 PM   #206
CSG Mike
CSG Mike's Avatar
you guys are lazy!
Here's the JR original.
Old 12-31-2013, 03:23 PM   #207
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
You guys are hilarious.
Currently my BRZ is engine stock + Perrin Intake. Just recieved the Perrin 3" exhaust, to be installed when it's not winter in Fargo, ND - So August.
Looking forward to the S/C realm and want to get some planning in. Thanks for the Help!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
Old 12-31-2013, 04:32 PM   #208
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Sig worthy, and probably the best quote to ever grace this forum.
Sellout is offline   Reply With Quote
The Following 2 Users Say Thank You to Sellout For This Useful Post:
Old 12-31-2013, 05:28 PM   #209
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Mike that is great news and I really appreciate you guys doing the acid test with repeated track abuse forthcoming. I have been modifying my car in stages, intentionally to experience the difference on track as the progression moves along. Eventually I plan to be running a reliable supercharged setup tuned for E85 at the track and 93 on the street just I am in NA form. Other than the custom NA tunes, everything I have done so far is a means to that end.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-31-2013, 05:42 PM   #210
OrbitalEllipses
Drives: Attitude
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
