Old 12-30-2013, 12:02 PM   #113
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Will be interesting to see the effect of the extra power when it gets put to the ground around the track.
Hopefully they'll add a set of their Tein SRC coilovers and some sticky RS3s, then we'll know.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 12-30-2013, 12:47 PM   #114
CSG Mike
CSG Mike's Avatar
We did confirm what we originally suspected this weekend.... an oil cooler is a must with FI.
We kept a careful eye on temps, and did some easy laps.
OjiGeorge (12-30-2013), ultra (12-30-2013)
Old 12-30-2013, 03:41 PM   #115
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
So a high reccomend even if a street machine and in cooler ambient locations?
Old 12-30-2013, 03:51 PM   #116
CSG Mike
CSG Mike's Avatar
Yes. While you can get away without, you won't get full enjoyment of the kit if you don't have one.
Compared to $4995 for the CARB legal kit, a few hundred more for an oil cooler is not much, and we would recommend that everyone get an oil cooler with the kit.
Disclosure: The Jackson Racing Supercharger installation manual does say that an oil cooler is high recommended. We just do things the hard way sometimes for the sake of completeness in our testing.
Old 12-30-2013, 04:14 PM   #117
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I thought the JRSC kit comes with a Setrab oil cooler (as seen in your install pics)...?
enjoyminutemaid is offline   Reply With Quote
Old 12-30-2013, 04:19 PM   #118
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
That's the cooler for the Supercharger oil AKA traction fluid AKA unicorn blood, not the engine oil. The kit does not include an engine oil cooler.
From the JR manual
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
CSG Mike (12-30-2013), enjoyminutemaid (12-30-2013)
Old 12-30-2013, 04:19 PM   #119
OICU812
Just a dude
OICU812's Avatar
Csg is speaking about engine oil cooler not the blower cooler.
The Following 2 Users Say Thank You to OICU812 For This Useful Post:
Old 12-30-2013, 05:09 PM   #120
CSG Mike
CSG Mike's Avatar
Originally Posted by Ralph Spoilsport View Post
Interested in belt routing & access, ease of inspection, adjustment & replacement.
Separate question for you: are you going to be running an accessory AOS/catch can?
The kit uses factory routing, except where the idler is added for additional belt wrap around the supercharger.
As you can see, it's SUPER easy to inspect the belt. The factory tensioner holds the belt in place, and the belt itself can be replaced by just lowering the tensioner, same as stock.
Big pulley is the crank pulley
Silver = alternator. Down/right from silver = pulley added by the Supercharger. Right of that is the supercharger itself and its pulley
Top pulley is the AC pulley. Left of it is the supercharger.
Ralph Spoilsport (12-30-2013), ramiram1984 (12-30-2013)
Old 12-30-2013, 06:24 PM   #121
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Originally Posted by cjsporl1996 View Post
How do you like this supercharger compared to the vortech?
In what regard? Both kits have their pros and cons, but it really depends on what your priorities are.
So what are the pros and cons of both? I have seen the Jackson is better for low/mid range and the vortek is better for High....but that is about it.
On a side note the instal of the Jackson kit looks a LOT easier.
kurbkilla is offline   Reply With Quote
Old 12-30-2013, 06:30 PM   #122
CSG Mike
CSG Mike's Avatar
Not everyone is looking for the same things.
The Rotrex is quieter, runs more efficiently (lower IAT), and has linear boost growth (the Vortech is slightly exponential).
The Vortech has more overhead for big power if you want to upgrade later with injectors, fuel pump, possibly clutch, and a smaller pulley.
kurbkilla (12-30-2013)
Old 12-31-2013, 07:25 AM   #123
kurbkilla
kurbkilla's Avatar
Can you use open flash for the CARB tune or do you have to use ecutech for ether the vortech or Jackson kit?
Old 12-31-2013, 07:37 AM   #124
Kodename47
Kodename47's Avatar
Drives: UK GT86
Does the CARB tune not have to be locked for it's regulation, therefore I doubt that any open platforms would be supported.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-31-2013, 08:16 AM   #125
s2d4
s2d4's Avatar
It can be locked on open flash by using the .dev method.
Old 12-31-2013, 10:25 AM   #126
CSG Mike
CSG Mike's Avatar
Only the EcuTek CARB tune is certified by CARB.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) Drift-Office Forced Induction 164 06-20-2014 12:43 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
