Old 12-30-2013, 05:49 PM   #15
Vten
Drives: Too heavy
Originally Posted by Figo View Post
When you guys say swap bleeders, do you mean do it like this (please see attachment)? Only the front need it right?
I just got a set of 08 sti caliper front and rear, and I am thinking to swap bleeder before powder coating them.
Since your 08+ caliper is black already , don't hesitate to use the torch to take those hex bolts out
Vten is offline   Reply With Quote
Old 12-30-2013, 07:03 PM   #16
brz_star21
Drives: DGM BRZ
Originally Posted by No Limit Motorsport View Post
I had to drill the allen heads out, and re-tap the threads. Mine wouldn't come out with no matter how much heat and PB blaster I applied.
Take the time and do it right.
This ^^
No matter how much I tried, too, it just wouldn't budge on the passenger side hex key set screw. Definitely take your time.
It won't brown but it sure will leave a noticeably ugly discoloration. Mine didn't matter since I was planning to powder coat it anyway.
brz_star21 is offline   Reply With Quote
Old 12-30-2013, 07:36 PM   #17
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
thank you.
can u tell me whats "take those hex bolts out"?
swap bleeder and the bolt on the other side right?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-30-2013, 07:37 PM   #18
Figo
Figo's Avatar
Yes. Fronts only.
^Yes.
thank you! is thats it? the i can powder coat and rebuilt right?
Old 12-30-2013, 07:47 PM   #19
Vten
Drives: Too heavy
thank you.
Yup correct
The Following User Says Thank You to Vten For This Useful Post:
Figo (12-30-2013)
Old 12-30-2013, 08:25 PM   #20
Figo
Figo's Avatar
just took off the bleeder。 but cant take off the hex bolt.
can i used torch as well as wd40?
Old 12-30-2013, 08:38 PM   #21
OrbitalEllipses
Drives: Attitude
Doubt any penetrating oil will help, but if you WERE going to try some I'd try something more serious. You definitely want the torch.
Old 12-30-2013, 09:06 PM   #22
Figo
Figo's Avatar
all i got was a lighter...
The Following User Says Thank You to Figo For This Useful Post:
WhiteFRS69 (07-09-2014)
Old 12-31-2013, 12:37 AM   #23
OrbitalEllipses
Drives: Attitude
Home Depot or any auto parts store - buy a propane torch, they're not expensive. Maybe take it to a shop and have them oxy torch it.
Old 01-11-2014, 04:47 PM   #24
Figo
Figo's Avatar
I brought them to a local shop last week. They messed up one of the hex bolt.
I think they might used wrong size hex or did not heat the bolt well.
I should have done it by myself, but it is too late now. Now its a hard time. I dont know whether it will be possible to take of the hex bolt with a stripped hex fitting hole. I brought them to a shop that focus on subaru race car build, and they dont want to do it.
So finally I left the part at another local body shop and they will take a look on Monday.
so sad.
Old 01-13-2014, 05:26 PM   #25
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Damn, Subaru really knows how to install a bolt...
- The Ancient BRZ Sacrament
by Zaku
Old 01-13-2014, 06:09 PM   #26
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
so sad.
Looks like we're in the same boat! I used a torch on the bolt for a good two minutes and it still didn't go. I don't plan on tracking my car so having it upside down doesn't seem like such a bad idea to me. I have given it my best effort to switch the bleeders aside from drilling and retapping. I feel like anything more than I what I've already done is gonna end badly for me.
mrha is offline   Reply With Quote
Old 01-13-2014, 06:37 PM   #27
Figo
Figo's Avatar
did you try to bring them to a local mechanical shop?
Old 01-13-2014, 07:33 PM   #28
d1ck
Drives: Black 2013 FRS
Have you tried an impactor of any type? Even one of those hand powered ones, or a 1/4" cordless one might do the job. I've got lots of experience with seized bolts (I live on an island in the North Atlantic) and I find stuff breaks much less often when using an impactor.
d1ck is offline   Reply With Quote
Custom BBK using Project Mu parts and EvoX brembo calipers jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-03-2014 05:15 PM
Complete Brembo Front BBK packages! Starting at $881 delivered!!! Infamous Performance Brakes, Suspension, Chassis 86 02-03-2014 09:40 PM
Green Brembo Brake Calipers, and Stock Springs Sivtec Brakes, Suspension, Chassis 23 11-25-2013 10:20 AM
Good deal on brembo calipers or not? red1993sol Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-07-2013 02:26 AM
Noise from front calipers after pad/rotor install BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2013 12:48 PM
