Old 12-23-2013, 03:45 PM   #57
Visconti
Drives: 05 STi
Here is some useful info
Ignition Correction Coarse is the output of the Ignition Advance Map
(multiplier by AM so in this case the AM is 1)
Ignition Correction Fine is the amount of Learned Ignition Retard, this is added to the Ignition Correction Coarse and the result is shown as ‘Knock Correction Learned Value’
Knock Correction only seems to show real hard knock events.
The Fine Learning will show learning stored from previous knock events but currently EcuTek doesn't have access to that parameter.
Visconti is offline   Reply With Quote
Old 12-23-2013, 05:19 PM   #58
jamesm
i was wondering where the button to pull the flkc table was... that explains it.
so the fine learning is showing you the currently applied flkc value, basically?
Old 12-24-2013, 01:27 AM   #59
Visconti
Drives: 05 STi
That's what it seems like.
I'm going to have a call with Phil and try and get more detailed info
John
Old 12-25-2013, 03:00 AM   #60
Kodename47
Kodename47's Avatar
Drives: UK GT86
Merry Christmas all!
A quick question for you.... PI/DI ratio, I've now seen 3 setups (including stock) all with different ratios. Is there any benefits or downsides to having both run all the time? What are peoples ideas for a good PI/DI table? I know on larger boost its needed to fulfill the fueling requirements, but how about on a NA or lower boosted applications?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-25-2013, 11:06 AM   #61
jamesm
i decided to stay as close to stock as possible, as toyobaru engineers are much, much smarter than i am in this area. i did have to modify it to flow enough fuel under boost, basically everything above 0.9 load is 50/50 across the board. this seems to work well for me at this stage.
one thing i noticed when testing running 100% port or 100% direct is that running direct injection results in noticeably lower egts. like a lot.
Old 12-27-2013, 12:11 PM   #62
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Another useful custom map for FI is for per gear boost control. The boost will tend to overshoot a bit in the higher gears when the engine sees more load.
You can use custom maps to build a wastegate duty compensation map to lower the duty cycles in the higher gears (rpm x gear) to keep boost in check if you see over boosting in say 5th and 6th gear and your normal duty cycle tables are not dealing with it quick enough.
You could also create a compensation table to adjust boost targets as well. You just need to keep in mind that the custom maps process in alphabetical order, so placement is important!
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 12-28-2013, 05:54 AM   #63
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I'm wondering guys, did anybody try and apply ignition or fuel cut @ the limiter I ask because I'd like to enjoy shooting flames @ redline ( seriously)
Old 12-28-2013, 10:02 AM   #64
FA20Club.com
Drives: 2013 White Out FR-S
the factory limiter is already a fuel cut that why its reacts the way it does. The car does shoot flames depending on the fuel type and target fueling. Its allot less likely to do that on pump 91.
FA20Club.com is offline   Reply With Quote
Old 12-30-2013, 03:05 AM   #65
Kodename47
Kodename47's Avatar
Drives: UK GT86
Does anyone know where you can get something to view logs in a format like this:
(shamelessly stolen from @brn12345 )
I figured it would be useful for longer logs, I'm used to using the ECUtek log viewer but I like the idea of having details for load vs RPM on the different variables.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-30-2013, 03:46 AM   #66
SmsAlSuwaidi
Boosted
Thanks! I was wondering is it possible to change the aggression of it? Maybe add an ignition cut?
I'd like something that would really provide cuts, something like. Bee*r or, what a motec/any standalone could provide
Ps: I'll be on e85 most likely or a high E% percentage
Old 12-30-2013, 04:51 AM   #67
brn12345
brn12345's Avatar
Would BRZedit work as a logger with a ECUtek flashed ecu? If so I would highly recommend it, as it is a very very good piece of software and cost effective too.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 12-30-2013, 11:30 AM   #68
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Sigh. why is Visconti banned again? Everything I have read of his lately has been helpful and not ****ish
Old 12-30-2013, 12:10 PM   #69
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Some more mod bullshit going on in this thread http://www.ft86club.com/forums/showt...t=54240&page=2
They deleted a post it looks like and then banned Visconti and some other guy.
post_break is offline   Reply With Quote
Old 12-30-2013, 12:12 PM   #70
jamesm
I'm not sure if that will work or not, I'll try later. I agree brzedit's logger functionality is better than that of ecutek, however I usually use ruby rake tasks to work with the information so the interface don't mean so much to me.
Gas tank laley81 Issues | Warranty | Recalls / TSB 1 07-31-2013 01:45 AM
TANK Vs. FRS chae FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 06-05-2013 04:23 PM
The need of a oil catch tank... davey90 AUSTRALIA 17 12-23-2012 05:01 AM
gas tank lid htdonato Issues | Warranty | Recalls / TSB 1 11-30-2012 02:43 AM
How many miles per tank on E85 Innova Engine, Exhaust, Transmission 2 09-21-2012 10:02 PM
