Old 12-30-2013, 12:01 AM   #113
Panman
Panman's Avatar
Drives: 86 GTS
Hmm, @Fizz is saying his arrived without any bumpstops - Would Bilstein be able to confirm?
Panman is offline
Old 12-30-2013, 12:06 AM   #114
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
really interested in these, FA500 and ST's. So will doing max drop on any of these coil overs compromise comfort/performance? (I believe they are all 50mm max drop). @FT-86 SpeedFactory , in your opinion, with 90% street, 9% Auto-X, 1% Track, which coils would you recommend? I do want a slightly lower ride than my Eibach Sportlines. Will it be worth more if I just go with KW-V3's and spend a little more extra $$?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline
Old 12-30-2013, 12:49 AM   #115
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by Blood View Post
Is there any confirmation on the bump stops? Reuse OEM? Reuse OEM but cut them? Order shorter bump stops from another company?
Originally Posted by Panman View Post
No update from @FT-86 SpeedFactory on this?
This is a perfect question to ask Bilstein USA over the phone.
AFTERMARKET & MOTORSPORTS HEADQUARTERS - WEST
ThyssenKrupp Bilstein of America
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
AFTERMARKET & MOTORSPORTS – EAST
293 Timber Road
Mooresville, NC. 28115-7868
1-704-663-7563
They were helpful a few years ago when I was installing their products on my MR2.
switchlanez is offline
Old 12-30-2013, 01:14 AM   #116
Panman
Panman's Avatar
Drives: 86 GTS
Good point, however, I'm in Australia - I've left a message for Bilstein Australia, just thought that FT-86 Speedfactory as a seller may be able to get an answer sooner.
I'm looking at potentially buying @Fizz set off him.
Panman is offline
Old 12-30-2013, 05:11 AM   #117
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by switchlanez View Post
Thought I read somewhere that Bilstein coilovers have internal bumpstops?
Only the fronts have internal bump stops because they're inverted struts.
Originally Posted by FT-86 SpeedFactory View Post
We don't have any on hand right now so instructions are scarce. The rears appear to be there already and fronts are hard to say. We'll have more in a couple weeks.
The rears do not come with bump stops. My previous set of Bilstein B14 for a different car was also the same....no bump stops were included for rear shocks. Anyway just to clarify, the instructions mention using "original" bump stops but does not mention about cutting them. Which now actually has me thinking they were designed to be used with full length bump stops. If it needed shorted ones I'm pretty sure a company like Bilstein would have provided with the set.
Fizz is offline
Old 12-30-2013, 06:49 AM   #118
Panman
Panman's Avatar
Drives: 86 GTS
Thanks for that - Need to clear with the financial controller now:-)
Panman is offline
Old 12-30-2013, 07:52 AM   #119
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No worries mate....I know what it's like
Fizz is offline
Old 12-30-2013, 10:09 AM   #120
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The KW V3's are awesome for street use, rides better than stock IMHO. ST's are good as well, even the Bilsteins rock but are out of stock in the USA right now.
FT-86 SpeedFactory is offline
Old 12-30-2013, 10:25 AM   #121
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Maybe I'm reading into this too much, but I find it interesting @BRZPDX asked about FA500, ST, and Bilstein, but your response was regarding KW V3, ST, and Bilstein.
Being that I'm running FA500's and love them, and that you said "In our honest opinion for under $1200 these are the best coilover out there" (Jeremy in Product Reviews-25 Mar, 2013), regarding the FA500's on your car. I'm wondering do you still stand by that statement, or has the sub $1200 offerings from other manufacturers changed this?
Thank you.
mwjcyber is offline
Old 12-30-2013, 10:40 AM   #122
FT-86 SpeedFactory
Thank you.
Sorry I didn't see the FA500 in his post. I read through it too quickly.
I still stand behind the FA500 and we still run fortunes on our car. Fortunes are great for the value, even better if you add the Swift upgrade.
If you don't want or need camber plates, don't want or need adjustment on the shock, then ST, and B14 are very good options. Kind of the install it and forget it type of option for a daily driver.
Old 01-01-2014, 06:16 PM   #123
Panman
Panman's Avatar
Drives: 86 GTS
Had a response from Bilstein Australia:
"Keith,
If you are talking about the front struts, you don’t reuse the original equipment; the struts have internal bump stops. On the rear, if there is no bump stop supplied you need to reuse it, generally it is not recommended to trim oe bump stops.
Regards,
Tony"
Panman is offline
Old 01-14-2014, 12:02 AM   #124
jonbatz01
jonbatz01's Avatar
Drives: ZD8
I am running BC Coilovers at the moment....i have no idea how to "Tune" a suspension thus although wanting KW, it might be an overkill.
I want this for better Track.
Will this be a good tuned Suspension compared to the BCs?
EOJ | PERTH | ZD8
jonbatz01 is offline
Old 01-14-2014, 07:58 AM   #125
FT-86 SpeedFactory
It would be better than BC's IMHO.
Old 01-21-2014, 06:36 AM   #126
Victor Draken
Drives: Toyota Gt86
Any direct comparison between this and the Tarmac 0 with 350spring?
What other piece of equipment would I need if I get B14?
I mean would I need camber bolts for the front and lca arms for the rear for a proper alignment?
Victor Draken is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
