#114 |
Boosted Member
Drives: 2013 SWP BRZ Limited
really interested in these, FA500 and ST's. So will doing max drop on any of these coil overs compromise comfort/performance? (I believe they are all 50mm max drop). @FT-86 SpeedFactory , in your opinion, with 90% street, 9% Auto-X, 1% Track, which coils would you recommend? I do want a slightly lower ride than my Eibach Sportlines. Will it be worth more if I just go with KW-V3's and spend a little more extra $$?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#115 | ||
Glorious BRZ Master Race
Drives: Subaru Libird
AFTERMARKET & MOTORSPORTS HEADQUARTERS - WEST ThyssenKrupp Bilstein of America 14102 Stowe Drive Poway, CA. 92064 1-858-386-5900 AFTERMARKET & MOTORSPORTS – EAST ThyssenKrupp Bilstein of America 293 Timber Road Mooresville, NC. 28115-7868 1-704-663-7563 They were helpful a few years ago when I was installing their products on my MR2.
#116 |
Drives: 86 GTS
Good point, however, I'm in Australia - I've left a message for Bilstein Australia, just thought that FT-86 Speedfactory as a seller may be able to get an answer sooner.
I'm looking at potentially buying @Fizz set off him. |
#117 | |
Senior Addict
Drives: 86 GT
The rears do not come with bump stops. My previous set of Bilstein B14 for a different car was also the same....no bump stops were included for rear shocks. Anyway just to clarify, the instructions mention using "original" bump stops but does not mention about cutting them. Which now actually has me thinking they were designed to be used with full length bump stops. If it needed shorted ones I'm pretty sure a company like Bilstein would have provided with the set. |
#118 |
Drives: 86 GTS
Thanks for that - Need to clear with the financial controller now:-)
#119 |
Senior Addict
Drives: 86 GT
No worries mate....I know what it's like
#120 | |
#121 | |
Drives: 13' Subaru BRZ Limited SWP 6MT
Being that I'm running FA500's and love them, and that you said "In our honest opinion for under $1200 these are the best coilover out there" (Jeremy in Product Reviews-25 Mar, 2013), regarding the FA500's on your car. I'm wondering do you still stand by that statement, or has the sub $1200 offerings from other manufacturers changed this? Thank you. |
#122 | |
I still stand behind the FA500 and we still run fortunes on our car. Fortunes are great for the value, even better if you add the Swift upgrade. If you don't want or need camber plates, don't want or need adjustment on the shock, then ST, and B14 are very good options. Kind of the install it and forget it type of option for a daily driver. |
#123 |
Drives: 86 GTS
Had a response from Bilstein Australia:
"Keith, If you are talking about the front struts, you don’t reuse the original equipment; the struts have internal bump stops. On the rear, if there is no bump stop supplied you need to reuse it, generally it is not recommended to trim oe bump stops. Regards, Tony" |
#124 |
Drives: ZD8
I am running BC Coilovers at the moment....i have no idea how to "Tune" a suspension thus although wanting KW, it might be an overkill.
I want this for better Track. Will this be a good tuned Suspension compared to the BCs?
EOJ | PERTH | ZD8
#125 |
#126 |
Drives: Toyota Gt86
Any direct comparison between this and the Tarmac 0 with 350spring?
What other piece of equipment would I need if I get B14? I mean would I need camber bolts for the front and lca arms for the rear for a proper alignment? |
| Bilstein Damptronic pics. | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 202 | 10-08-2014 08:13 PM |
| Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
| Bilstein Damptronic on an FRS | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-10-2013 12:15 AM |
| All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Brakes, Suspension, Chassis | 24 | 07-31-2013 01:52 PM |
| Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 03:12 PM |
