Old 05-10-2013, 03:42 PM   #71
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by enjoyminutemaid View Post
I sprayed WD-40 through the tops of the bearings and the squeak/creak immediately went away, however, i'm still getting quite a bit of popping when turning the wheel from lock to lock.
Ok after the first pop in the am. I never get any noise turning the wheel lock to lock. we checked the bearing and everything is turning freely.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-30-2013, 03:39 AM   #72
OrbitalEllipses
Drives: Attitude
I hate to necro, but do these lower the rear more than the front? Never really thought about it, but the gap up front is about twice as large as the gap at the rear per my measurements the other day.
Input, @Grimlock?
Old 12-30-2013, 08:14 AM   #73
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Input, @Grimlock?
On my car the rear does look a little lower than the front, but I just did a hub-to-fender measurement.
13" and 14/16ths rear and 14" front, so it is only about an 1/8th inch difference for me. Although it does look a little bigger than that. Maybe because I have more camber in the back? (-1.90º versus -1.20º)
Are your measurements a lot different than mine?
Grimlock is offline   Reply With Quote
Old 12-30-2013, 12:51 PM   #74
OrbitalEllipses
Drives: Attitude
The wheel gap looks pretty disparate - about 1 finger difference front and rear. I didn't measure hub to fender, but I can do that sometime this week. Basically a half-inch difference in wheel gap - which should translate into a half inch difference hub to fender.
Old 12-30-2013, 04:04 PM   #75
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
How many miles are on your springs? I have 4,600 on mine. Also, I'll pull the car out and snap a picture for you.
Old 12-30-2013, 04:06 PM   #76
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Here's the way my car looks dead on from slightly kneeling.
Old 12-30-2013, 04:21 PM   #77
OrbitalEllipses
Drives: Attitude
Several thousand more. I'll snap a pic of mine around 6PM.
EDIT: Just realized I have salt in the trunk and that's probably most of my problem.
Old 12-30-2013, 08:32 PM   #78
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Doh!
The Following User Says Thank You to Grimlock For This Useful Post:
Racecomp Engineering (12-31-2013)
Old 03-26-2014, 11:29 AM   #79
sobrz
sobrz's Avatar
Quick note for folks who want to know how springs will affect your alignment:
I have RCE Yellows and I absolutely love them. Goal was to reduce the wheel gap with as little impact as possible on the ride, and the yellows accomplish that goal wonderfully.
I haven't taken alignment measurements before putting the springs on, after springs and alignment I'm at:
Camber: -1.5 front (with SPC camber bolts), -2.0 and -2.1 rear
Toe: 0 all around
Caster (front): 6.0, 6.1
Keep in mind that rear camber is not adjustable stock (neither is front, but the camber bolts are an easy fix). Negative 2.0/2.1 feels great even for daily driving, but I worry a bit about uneven tire wear. I'm going to watch it closely and if I notice uneven wear I'll get SPC lower control arms to reduce rear camber to -1.5. The rear bushings seem to be too much of a pain to install.
BTW: My previous daily driver was a Miata NC with rear camber set to -2.0 and perfectly even tire wear. Hopefully the same will be true here.
sobrz is offline   Reply With Quote
The Following User Says Thank You to sobrz For This Useful Post:
Racecomp Engineering (03-26-2014)
Old 03-27-2014, 03:36 AM   #80
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Input, @Grimlock?
This was bumped and I saw this so fogured I would post.
Front fender arches tend to be cut higher than rears giving this appearence. They lower equal all around.
They even used to sell "saggy butt spacers" for imprezas to fix this wierd look as on those cars it is really bad.
Sent from my LT30at using Tapatalk
Old 03-27-2014, 09:39 AM   #81
OrbitalEllipses
Drives: Attitude
^My issue is due to ballast in the trunk. We'll see what it's like once the temps get up to 50*F regularly and I can get rid of snow tires.
Old 03-27-2014, 10:58 AM   #82
edit your posts Orbital....and take the salt outta yo trunk!
- andy
Suspension Review: Race Comp Yellow Springs mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 313 07-23-2017 03:05 PM
Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-28-2013 12:22 AM
Springs & Shocks: Which to Buy? GhostofAkina Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-11-2013 01:16 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 09:43 AM
