Old 10-17-2013, 05:48 PM   #99
kuhlka
Drives: 2013 BRZ Limited AT
Originally Posted by Dsmith1992 View Post
K well i am getting my car back finally hopefully end of next week, but will be installing it in two weeks. i saw your amp had a different set of wire than mine for the wiring, if i take my Line out converter from PAC its the PAC LP7-2 LOC Pro, and just use the positaps i have ordered. Then just connect them to to appropriate wires on the amp it should work? I am just wanting to have a good idea of doin this, b4 i do it, better than goin in blind and blowin something up. As well do you think a 2 or 0 gauge power wire will fit along the side panels to run, cause i got a big amp (Kicker zx1500.1) and powering two subs (10" alpine Type r)
Yeah, that converter should work. Just make sure the polarities are right because the colors are a jumble. The wiring diagrams people posted earlier in the thread are great for sorting them out.
I ran 10 gauge for the RF 300x1. The panel along the door definitely won't fit gauge that huge. My 10 gauge just barely tucked under. There is a hole on the right side of the engine bay that you could use for that. I think I saw in another walkthrough or photos that it's an unused cover intended for aftermarket wiring or later factory accessories. I think it's actually that the chassis as built to be interchangeable for right or left side drive and that hole is probably for the main harness when the battery is on the right.
1500 is going to be massive overkill for this car and might blow those 10" woofers if you're not careful. I assume you've done car audio stuff in the past to go for that setup. Bass head?
[ame]http://youtu.be/fnqtkcgGa78[/ame]
kuhlka is offline   Reply With Quote
Old 10-17-2013, 10:30 PM   #100
Dsmith1992
10 Series Colorado
Drives: Scion FR-S 10 Series
haha yeah i love the bass, ill have the amp turned down a long ways, ya ill look at the diagram and see whats goin on on what ill need, the big a power wire is always the issue. ill post a vid up once i get it installed
Dsmith1992 is offline   Reply With Quote
Old 11-07-2013, 09:45 PM   #101
Sgtmogunz
Sgtmogunz's Avatar
Drives: 2013 Subaru BRZ
Infinity Basslink is an incredible addition to the factory stereo, I guess all it needed was a little bass after all.
Sgtmogunz is offline   Reply With Quote
Old 12-11-2013, 04:19 PM   #102
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
I'm going to do a better video later (recently moved, better lighting), but this should help for now. All of my wiring except the positive lead for the battery are coming from he amp in the trunk.
i tryed it this way and everything gets distorted when i turn up the volume....
should i wire it to the head unit? idk what to do
NYCsubaruBRZ is offline   Reply With Quote
Old 12-11-2013, 04:36 PM   #103
NYCsubaruBRZ
is there a harness i can buy for the factory radio so i can plug in rca's?
Old 12-12-2013, 01:13 PM   #104
kuhlka
Volume on the head unit? I'm able to crank mine and it sounds fine. I'd double check the wires and make sure you don't have anything reversed.
From a previous post above with image. I'm pretty sure I used the signal +/- for my Rockford Fosgate RCA adapter. Don't use the speaker +/-. That may be your problem as the amp will be trying to send varying signals to the different speakers for stereo or surround sound.
(1 is at the bottom left of the connector in the photo, 10 is the top right)
1 - Pink (looks orange?) - Left speaker +
2 - Blue - Right speaker +
3 - Light Green - Left signal +
4 - White - Right signal +
5 - Violet - Left speaker -
6 - Red - Right speaker -
8 - Green - remote signal (use for amp on/off wire)
9 - Yellow - Left Signal -
10 - Sky Blue - Right signal -
Old 12-12-2013, 06:11 PM   #105
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
As Kujlka said, you'll want to use #3, 4, 9, & 10 for audio.
Which amp are you using? Some amps may not like balanced signals, or may not have a sufficient range of sensitivity.
If your amp is unhappy, there's a ghetto solution and a proper solution.
Ghetto solution: Not every source (headunit) will let you do it... but you can ground pins # 9 & 10. This changes the reference from a "float" to a "ground" and you wire pins #3 & 4 to the center pin of the RCAs. This will induce some noise (may or may not be a significant amount). Most automotive amplifier suppliers have to run validation testing to prove that their product will not only continue running, but will send a sufficiently clean signal on the un-grounded line.
Proper solution: Transformers! You can convert between balanced and unbalanced signals using inductive coupling. Plenty of products will do that (each with varying degrees of ground isolation). The Audiocontrol unit mentioned above should do well or something like the EDCOR S2S150t/150 (LINK). Just make sure that the input and output impedance are appropriate so that you deliver the proper signal level. I don't know the proper impedances, but I'm sure that we're not the first people on the internet to tackle this issue.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 12-13-2013, 07:07 AM   #106
NYCsubaruBRZ
yea i checked the connections and cant find a problem...
i guess i will have an audio shop do it.....
how much should it be just to run rca from the headunit?
im not trying to spend 100 on just that
Old 12-30-2013, 01:44 AM   #107
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
I haven't tried it but it would seem to fit: http://www.crutchfield.com/p_1207017...r#overview-tab
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 01-21-2014, 05:10 PM   #108
Dsmith1992
10 Series Colorado
anyone got an idea on running a 0 gauge thru the fire wall on the frs?
Old 01-21-2014, 05:40 PM   #109
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
All I can say is my 6 gauge barely fit through that nipple in the grommet with Vaseline.
oldpueblo is offline   Reply With Quote
Old 01-21-2014, 05:52 PM   #110
labskaus
labskaus's Avatar
Drives: Toyota GT86
It is a AWG4 but there is still some room for more. Just a small cut and afterwards sealed it with some butyl
labskaus is offline   Reply With Quote
Old 01-21-2014, 06:22 PM   #111
oldpueblo
oldpueblo's Avatar
I forgot there are two grommets, there's another one on the right side as well.
Old 01-21-2014, 10:04 PM   #112
mid_life_crisis
Drives: FR-S 10 #103 AT
A 4 gauge fits quite nicely through the otherwise useless sound tube hole if anyone wants another path.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Subwoofer prewiring Nate219BRZ Electronics | Audio | NAV | Infotainment 3 09-09-2013 05:56 PM
Adding a sub enclosure yet ? rikdrt1 Electronics | Audio | NAV | Infotainment 10 06-08-2012 09:28 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
