Old 12-29-2013, 06:05 PM   #239
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Very interesting. Were EGTs low enough that you weren't concerned with the cat life expectancy?
I just don't want my only cat to be the downstream. I live in MA and they are very stringent on removing cats leading to inspection failures.
shaunsweeney is offline
Old 12-29-2013, 06:39 PM   #240
FA20Club.com
Drives: 2013 White Out FR-S
they were within reason. Honestly unless you retard the timing too much or over fuel the motor with a conservative tune you wont damage the CAT. These are the same CATs use in most catted aftermarket downpipes from Subaru, BRW Mercedes etc applications.
FA20Club.com is offline
Old 12-29-2013, 07:00 PM   #241
shaunsweeney
You don't happen to. Have any pics of the cat location on the turbo setup do you?
Old 12-29-2013, 07:04 PM   #242
FA20Club.com
Nope, but if you see any of the pics of our kit its about 6" down stream from the turbine housing.
Old 12-29-2013, 07:10 PM   #243
shaunsweeney
I'll take a look. Thanks for the fast responses on a Sunday.
Old 12-29-2013, 07:18 PM   #244
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
You might want to cut down on your obnoxious ads there. It's bigger than most posts.
mike_ekim1024 is offline
Old 12-29-2013, 08:03 PM   #245
shaunsweeney
PM sent @FA20Club.com
Old 01-10-2014, 01:39 PM   #246
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Here's how it sounds on the dyno
[ame="http://www.youtube.com/watch?v=sMf0PXaf7dY&feature=share&list=FLKMCLVjjCR DV5CTy93bU2sA"]FA20club 57 trim UEL dyno - YouTube[/ame]
Ny Brz is offline
Old 01-10-2014, 04:04 PM   #247
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
That place looks familiar
PrimeMotoring is offline
Old 01-10-2014, 04:08 PM   #248
Ny Brz
Hella Flush
Ny Brz's Avatar
That guy on the right looks familiar too...Great work from Prime Motoring and JR as usual.
Ny Brz is offline
fa20crud.com, header, unequal length
Borla Unequal Length Header Review and DIY F1point4 DIY (Do-It-Yourself) Guides 92 05-10-2021 04:06 PM
>>>>Rev Works UEL (Unequal Length) Header - Specs, information, & Customer Review<<<< Rev Works Engine, Exhaust, Bolt-Ons 917 08-04-2014 11:52 PM
****Rev Works 4-1 UEL (Unequal Length) Header - $699!**** Rev Works Engine, Exhaust, Bolt-Ons 206 08-01-2014 05:10 PM
BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! NJA Announcements, Contests, Giveaways 6 04-03-2013 05:47 PM
