Old 12-29-2013, 05:24 AM   #85
diss7
Drives: AE86, 2x GT86, TE27
I call BS at that claim. I raised my rev limit at it didn't like going past 7400, but once I replaced the front pipe that hesitation disappeared. Now it revs to 8000 quite happily.
diss7 is offline   Reply With Quote
Old 12-29-2013, 05:28 AM   #86
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Several guys doing 8k rev limits for autoX.....only thing I noticed via the dyno plots is nothing past 75/7600 made more power. Seemed to really fall on it's face.
I'm guessing that is cam profile and headers but honestly not sure.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 12-29-2013, 05:45 AM   #87
StormTrooper
Originally Posted by Jason@DSG View Post
I work closely with all the manufacturers. There isn't much going on for N/A
Since the tuning has barely been worked out and companies are still getting development costs paid for on the bolt on parts they made i think that internals will be coming in a few years.
I mean headers designed with any kind of engineering input have just started to come out.
GR86 MT premium
Old 12-29-2013, 06:13 AM   #88
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
E85 in a nutshell..
Edit: personally not a fan of E85. Sure its good for easy HP gains, but for long term? I wouldn't risk it on my engine just for a few extra hp..
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
diss7 (12-29-2013), Mr. (01-02-2014)
Old 12-29-2013, 06:29 AM   #89
diss7
You don't need to run e85; water it down to e50 or e30. Most of the guys I know locally running ethanol in their track/drift cars run e30; there just isn't much gain to go further than that, from what I've seen anyway, I'm not a tuner.
Old 12-29-2013, 06:37 AM   #90
diss7
I does feel to me on mine going to 8k is passing peak power, but I have it there to use as there is two comers at my local track that I'd hit 3rd limiter before the corner, now I don't. Also, I chop into 2nd on the hairpin, taking 2nd to redline then puts me at better power in 3rd. However back straight I don't take 4th to redline, I shift at 7700 or so, maybe sooner (not sure exactly I'm not looking at the tacho.) But my butt dyno says that it's better to shift before 8000 redline into 5th
Old 12-29-2013, 06:39 AM   #91
brn12345
brn12345's Avatar
I would also include intake manifold runner length and chamber size. Always seems to be overlooked when NA performance is discussed. I have a feeling a proper top end tuned header with a proper intake manifold designed for higher revs would make significant improvements beyond 7600rpm.
brn12345 is offline   Reply With Quote
Old 12-29-2013, 07:00 AM   #92
StormTrooper
Anything besides valve springs need to be swapped for reliability at 8k?
GR86 MT premium
Old 12-29-2013, 07:47 AM   #93
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Cams and springs too
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 12-29-2013, 10:54 AM   #94
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Originally Posted by stevo_12v View Post
E85 in a nutshell..
I have a customer going through a 15k engine build with me because he detonated due to e85 mix being off...
It needs to constantly be retuned and check. The blend changes throughout the season. I always stick to 93oct or race fuel
Jason@DSG is offline   Reply With Quote
Old 12-29-2013, 01:02 PM   #95
Dephective
Drives: '13 Whiteout FRS
that's why if you run e85 you run flex fuel for the safety. Also the B series heads vs ours, nobody knows what the head will flow. it's never been bench flowed as far as I know. and if guys are making 600hp without any head work, I'd say it's safe to say that that's not the case. sure it's a great motor, but to make that power you need at least cams. that's already comparing stock to modified. Nobody has done anything on these motors yet so don't say it can't be done. you are basing your info off nothing.
yes vtec has different cam profiles that also effects exhaust, but you can still make decent power with mild cam upgrades. it's obvious that you can't be convinced, so I'll let the market do that when it's ready for it.
and as far as what's needed to do cams, there's no point in drop in cams. if you do it, full valve train needs to be done. titanium springs, retainers, valves, and probably replace the buckets too.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 12-29-2013, 01:38 PM   #96
Dipstik-sportech
Dipstik-sportech's Avatar
I'm only going of what has been shown so far. Na at this point isn't there in terms of parts availability.
You can over come poor head design by cramming more boost at it.
Sent from, The Frozen North
Old 12-29-2013, 02:02 PM   #97
stevo_12v
Titanium valve springs!!
And probably a fair bit of ceramic coating on those engine bay goodies
Old 01-01-2014, 11:10 PM   #98
Ice
Drives: 323
The problem with this engine is that you only have control of one aspect of the cams, you cant use varying lifts, duration, ramp angles etc like the Honda guys have access too. (At least AFAIK, I come from static heads)
Which means that to maintain downlow you have to compromise.
Hopefully by the time I have the coin together for BRZ theres some better gear out and about
Ice is offline   Reply With Quote
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Agency Power Intake?? "FT86 website" ScionFrsFan Engine, Exhaust, Transmission 14 12-03-2012 06:25 AM
