Old 12-21-2013, 03:29 AM   #1
archer
Drives: 2001 jeep wrangler
max "potential" NA power.
So iv been searching around online for quite a while before joining the forum and from what iv gather the peak HP for a NA is around the 200 mark with bolt on's and a tune. I have seen some place's where people have even directly said the peak power is 200 ish with bolt on's and a tune. But i'm curious, once we have more part's on the market such as camshaft's, piston's, rod's, valve's, valve spring's, lifter's, throttle body's and so on. what do you think this engine is capable of. I understand there's no way of knowing anything until the parts are actually here, just curious about idea's on max power once there's more then just bolt on part's.
Also, i understand that the stock throttle body and camshaft are great to begin with but somewhere down the road better one's will be out there.
archer is offline   Reply With Quote
Old 12-21-2013, 03:31 AM   #2
archer
P.S. if you have personally had any part's custom fabricated would you mind letting us know what kind of number's your pushing?
Old 12-21-2013, 03:40 AM   #3
diss7
Drives: AE86, 2x GT86, TE27
I'm glad you started this thread. It's never been discussed. Not even recently. Like so recently that if you just scrolled down you'd see a thread.
diss7 is offline   Reply With Quote
Old 12-21-2013, 03:43 AM   #4
archer
Are you referring to the stroker thread? a stroker kit is not exactly what i'm speaking about.
Yes, that is internal work but not what i ment.
Old 12-21-2013, 03:49 AM   #5
diss7
2nd page of more than 100, there is a thread on NA dyno graphs, as well as a multi page thread discussing max NA hp for race applications.
Old 12-21-2013, 04:00 AM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Honda S2000 (1st gen) 119 hp/litre @ 8,300 rpm
Ferrari 458 Speciale 132 hp/litre @ 9000 rpm
Caparo T1 159.3 hp/litre @ 10,500 rpm
How much money do you want to spend?
Old 12-21-2013, 04:08 AM   #7
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I think THIS is the most power recorded for a NA FA20. Runs full bolt-ons with OFT on E85
Old 12-21-2013, 04:13 AM   #8
archer
Honda S2000 (1st gen) 119 hp/liter @ 8,300 rpm
Ferrari 458 Speciale 132 hp/liter @ 9000 rpm
In the end everything does come down to money, yep. But there is realistic number's and outlandish number. Easy bolt on's will get you to 200 HP. I highly doubt this engine will ever come ever close to 600 HP with just internal's. 300-350, possibly, MABY with highly built engine's. I'm just curious what's possible. I'm not trying to sound like i'm rich, i'm far from rich haha, but its not about how much money it will take to get high number's.
Old 12-21-2013, 04:17 AM   #9
archer
lol but i'm talking about going PAST bolt on's. Once theres a better camshaft on the market, once there's a throttle body that doesn't cost over $1,000.
lol internal's is my interest.
Old 12-21-2013, 05:08 AM   #10
350matt
Drives: toyota mr2/ Toyota GT86
its going to be a case of how many revs the engine can stand
with standard guts you'd be foolish to push the rev limit much higher than it is currently (approx 7500rpm) and as it currently peaks at 6900 to 7000 rpm then this will limit peak power
so to get 250ish brake you need to retune to about 8K with a rev limit of 8,500rpm
based on current level of knowledge this will need valve springs at least, possibly a set of rod bolts
then of course the new cams and shorter inlet tract to achieve the tune
and I wouldn't worry about the throttle until 330Bhp
350matt is offline   Reply With Quote
Old 12-21-2013, 05:54 AM   #11
Captain Snooze
Drives: Red Herring
"its going to be a case of how many revs the engine can stand" -->
*https://translate.google.com.au/* -->
"its going to be a case of of how many dollars your wallet can stand".
Old 12-21-2013, 05:58 AM   #12
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
F1 engines are currently producing about 300 hp/liter and they have to survive 4 race weekends each. If you want to license Koenigseggs and Cargines freevalve system you could probably get around 360/liter.
Max piston speed at stock redline is 21.23 meters per second so there's room to rev to around 8500 at stock stroke. Raising the redline any higher and you're going to have to shorten the stroke and ultimately end up sacrificing torque for peak HP and have shit for drivability. (Note, I've made the assumption that the proper modifications have been done to keep bad things from happening)
Tgionet is offline   Reply With Quote
Old 12-21-2013, 09:22 AM   #13
tennisfreak
Drives: 2018 BMW M240i
Max I have seen on a dyno was 275 whp.
Old 12-21-2013, 10:10 AM   #14
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
To answer your question. If our engine could breath well enough to produce 160lb-ft at 8500rpm, that would be 260hp. I don't see revving past 8500 as feasible and I don't see the motor producing more than 160lb-ft NA.
industrial is offline   Reply With Quote
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Agency Power Intake?? "FT86 website" ScionFrsFan Engine, Exhaust, Transmission 14 12-03-2012 06:25 AM
