#43 |
Drives: Scion FRS
#44 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Will this affect header fitment?
#45 |
Drives: Scion FRS
We kept clearances in mind while designing this pan. The plan was to make sure it cleared most headers.
| The Following 2 Users Say Thank You to FullBlown For This Useful Post: | CARNZ (12-24-2013), Dipstik-sportech (12-24-2013) |
#46 |
Drives: 2013
you guys have a 3d printer in house? cool cool
#47 |
Drives: Scion FRS
| The Following User Says Thank You to FullBlown For This Useful Post: | Dipstik-sportech (12-26-2013) |
#49 |
Drives: Scion FRS
#51 |
Drives: Attitude
Not really, I'm struggling with this concept of a lower and upper pan. How do you make the pan wider at the bottom, but not increase oil system capacity? Am I just being dense, because there are several posts of "+1 quart capacity" in this thread.
#52 |
Drives: Scion FRS
Someone thought we meant 50% of the engine's total oil capacity. The FA20 holds 5.8-6 quarts from the upper and lower pan combined.
We meant that it holds 50% more than the oem lower pan. Since we are only upgrading the lower pan (which holds a little over 2 quarts) 50% of that would be roughly 1 quart extra. Sorry, it was confusing the way I answered that first question. |
| The Following 8 Users Say Thank You to FullBlown For This Useful Post: | Creole (09-26-2014), Dipstik-sportech (12-28-2013), DriftEightSix (12-26-2013), ftc~brz (03-31-2014), JackSmiley (12-30-2013), Joveen (10-24-2019), Mathewgzlz (12-27-2013), OrbitalEllipses (12-26-2013) |
#53 |
awesome! how is durability for street use compared to oem? would this hold up well to a dropped car and bad roads?
#54 |
Drives: 85 corolla gts
If it stays under the factory slash shield and you are not destroying that I would see no issue on lowered cars. If you a destroying the factory splash shield and denting the stock pan then I would not recommend it as a cast pan will crack faster in that situation. As well is you are low enough to be denting the factory pan I would recommend to raise your car anyways.
#55 |
Drives: Scion FRS
Yes it is higher than the splash shield and shouldnt have a problem bottoming out.
#56 |
Boosted Member
Drives: 2013 SWP BRZ Limited
can someone ELI5 this part for me? What are the overall benefits to changing in to this oil pan? My car is in the process of being FI'd right now, and this looks pretty cool. I want all the cooling possible for my oil.
Extra quart of oil, what is the benefit to it? A marginal cooling effect, if its negligible, then what is the point? Does this only work for FB turbo kit, or any FI in general that taps into the oil pan?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
| FRS Die-cast model | encity5 | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 02-24-2019 12:15 PM |
| Expensive, but cool Die Cast GT-86 | Kimsey47 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 11-26-2013 05:12 AM |
| FS: Die-cast EBBRO 1/43 frs 86 | blanco | Miscellaneous | 4 | 09-25-2013 10:42 PM |
| Durability of cast wheels | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-06-2012 05:10 PM |
| Any Disney Cast Members here? | MF_DEUCE | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-18-2011 01:48 AM |
