Old 12-26-2013, 04:12 PM   #57
OrbitalEllipses
Drives: Attitude
~330whp. Makes almost no difference for us, since we tune for reliability, not outright power.
~3.5% difference between E85 and 91??? That's what I call leaving some power on the table.
Old 12-26-2013, 04:50 PM   #58
CSG Mike
CSG Mike's Avatar
E85 doesn't get you the same benefit on a supercharger as with a turbocharger. While you can use the full benefits by getting a smaller pulley to get more boost, it's not as simple as just adjusting a boost controller and/or calibrations on a turbocharged car.
Typically with a turbo car, you simultaneously increase boost while adding timing with E85. With the supercharged car, you're not increasing boost, only adding timing.
Old 12-26-2013, 08:04 PM   #59
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Which engine oil cooler kit are you guys going with for track usage? I'm still weary of my Perrin OC kit fitting without modification. I also want to see pics of an engine OC and Rotrex OC mounted side by side behind the IC
Old 12-26-2013, 09:13 PM   #60
CSG Mike
CSG Mike's Avatar
We have something in development, coming soon
It'll be a all-in-one radiator oil-to-water oil cooler combo. We believe a space-efficient solution will be key with many FI setups out there.
ATL BRZ (12-27-2013)
Old 12-27-2013, 03:28 PM   #61
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Does Robi know what you're up to?
The kit looks good. Are any of the other Rotrex kits going to be CARB legal? In looking at the centrifugal kits the Rotrex variety definitely has the most appeal to me.
Cheers
Nathan
SubieNate is offline   Reply With Quote
Old 12-27-2013, 04:01 PM   #62
CSG Mike
CSG Mike's Avatar
Cheers
Nathan
I'm sure he does; we've discussed it with him before.
Kraftwerks says they are seeking CARB approval, but as of now, Jackson Racing is the only CARB legal Rotrex kit.
Old 12-27-2013, 05:27 PM   #63
CSG David
CSG David's Avatar
Cheers
Nathan
You're alive Nathan!
Old 12-27-2013, 05:45 PM   #64
ATL BRZ
ATL BRZ's Avatar
Does the kit come with the correct bracketry to make the side-by-side coolers work?
I want to see @Jackson Racing 's official engine oil cooling solution for their car.
They say in the instructions that an engine oil cooler is needed before tracking the car, and they tracked theirs extensively in development, yet I still haven't seen a single JRSC FA20 pictured running an engine oil cooler yet...
I still have hope that I could adapt my Perrin OC kit without modification to the sandwich plate/adapter/lines should I get this SC kit in the future.
If not, I'd like to know what my options are before installing.
Old 12-27-2013, 05:49 PM   #65
CSG Mike
CSG Mike's Avatar
They say in the instructions that an engine oil cooler is needed before tracking the car, and they tracked theirs extensively in development, yet I still haven't seen a single JR kitted FA20 pictured running an engine oil cooler yet...
All I can say is that Jackson Racing will be releasing their oil cooler soon. The development is done, and they're just waiting for everything to arrive so that they can assemble the kits.
Old 12-27-2013, 05:55 PM   #66
ATL BRZ
ATL BRZ's Avatar
Do you feel in your educated opinion that the Perrin OC kit will work without modification?
I understand you can't give details on the JR OC kit before it's released.
Old 12-27-2013, 06:00 PM   #67
CSG Mike
CSG Mike's Avatar
It will not. It's in the same location (or very close to) the FMIC. However, it should be pretty easy to redrill the brackets to sit the oil cooler just a little bit further back.
Old 12-27-2013, 06:03 PM   #68
ATL BRZ
ATL BRZ's Avatar
Gotcha. I knew it wouldn't work with the FMIC in the intended mounting location with the Perrin supplied "feet" in the front & center of the under tray.
I was wondering if I could just get the JR side-by-side bracket and mount the Perrin cooler (generic 10 row Mocal) behind the FMIC beside the Rotrex cooler without having to un-install everything and sell it and buy a whole other kit that will presumably be very similar.
Old 12-27-2013, 06:04 PM   #69
CSG Mike
CSG Mike's Avatar
I was wondering if I could just get the JR side-by-side bracket and mount the Perrin cooler (generic 10 row Mocal) behind the FMIC beside the Rotrex cooler without having to un-install everything and sell it and buy a whole other kit.
I don't have too many details on the actual cooler, but I'll let you know when I have more solid info
Old 12-27-2013, 10:19 PM   #70
matchamochi
matchamochi's Avatar
Drives: swp brz
Hopefully this isn't too dumb of a question - From a dead stop if you gun it do you feel glued to your seat?
I noticed in the first post you said everything is very linear, but in another post you said you can definitely feel it above 6k rpms.
I came from a mazdaspeed 3 w/ minor upgrades and an ecu and obv turbo and sc feeling are different, but the stock engine has really left me a little lacking.
I'm in Cali and this is my daily driver in a police infested zone so I'd like to keep things on the up in up...
matchamochi is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) Drift-Office Forced Induction 164 06-20-2014 12:43 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
