Old 12-27-2013, 05:20 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Ecutek Redline adjust
So just curious, who is raising the redline and to where? Kind of curious what it would need to get to 60mph in 2nd?
Ryan.
gdrider77 is offline   Reply With Quote
Old 12-27-2013, 05:24 PM   #2
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Well, I don't have ECUTek, but I believe the redline is upped to 7600 with the OFT... at least I hope that it has, because my dash showed me above 60 mph in 2nd gear before I upshifted to 3rd the other day...
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
Old 12-27-2013, 05:27 PM   #3
jamesm
i use per-gear rev limits, 8000 in 1st and second and 7600 in all other gears. allows you to hit 60 in 2nd.
Old 12-27-2013, 05:48 PM   #4
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
I believe 7700 will hit 60 in 2cnd. James, 8000 is a lot of stress on pistons, pins, and rods, although the engine will do it. I would only recommend it if you are still making power up that high.
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 12-27-2013, 06:14 PM   #5
jamesm
- Bob
oh yeah i'm not... maybe i'll drop that down a bit
Old 12-27-2013, 07:05 PM   #6
FA20Club.com
Drives: 2013 White Out FR-S
Some require the higher limit for road racing to avoid bumping the limiter. We use a combination of a higher rev limit coupled with a tq reduction via throttle control.
FA20Club.com is offline   Reply With Quote
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
feldy (12-27-2013), gdrider77 (12-27-2013)
Old 12-28-2013, 03:00 AM   #7
350matt
Drives: toyota mr2/ Toyota GT86
Bigger issue is I believe the valve springs go into float / lose control at 7650rpm, so i'd keep it at a 7600rpm rev limit
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
DAMotorsports (12-29-2013)
Old 12-28-2013, 05:45 AM   #8
nelsmar
I know @Ninjin has been doing this for a number of months for track use. Ideally he is using it for the reason of not having to shift for a short duration during a track session. Not so much for power gain etc. I have been working with his car and seen little reason power wise to go beyond 7600. With the exception of "saving a shift" when you just simply need a few hundred RPM more on a tight course. I am sure he will be able to chime in with longer term results for reliability in the coming months.
I personally am doing minor valve train upgrades in my new engine in hopes to handle upwards of 8,500RPM. I don't plan on going anywhere past stock but am building over what I need in the case my turbo spools too slow so i can have a longer usable powerband. I plan on setting the rev limit to 7,800-8,000 regardless of powerband for the same reason as @Ninjin, but have no reason to otherwise shift anywhere above 7,200-7,500.
I am curious to know about others long term reliability as I know a number of tuners have been raising this rev limit for a while now.
My flickr - Canibeat
Local magazine scout
Old 12-29-2013, 02:56 AM   #9
DAMotorsports
Drives: 2013 Scion FRS "Raven"
You hit the nail on the head. In fact the stock valve train is so soft that i heard that in some cases a detonation has caused the valve to open and throw a rocker arm. Which wipes out the head and cams. We have taken the time to inspect the motor and see how soft the stock springs are along with how tight the clearances really are.
Top that off with the stock cams don't make much power on the top end.
DAMotorsports is offline   Reply With Quote
Old 12-29-2013, 03:39 AM   #10
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Even boosted I run out of steam at 7300
Deadspool is offline   Reply With Quote
Old 12-29-2013, 10:47 AM   #11
jamesm
I use the higher limit in first and second mainly because there is no traction until third, and it keeps me from banging off the rev limiter. Ill probably drop it down to 7600 and just learn how to shift fast lol.
Old 12-29-2013, 09:35 PM   #12
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
What needs to be changed to stop this from happening so you can increase the limit higher?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-01-2014, 08:45 AM   #13
350matt
stronger valve springs and or lighter valves or a cam with better control over the opening ramps
ecutek ability to adjust to different % of E85 Mars2 Software Tuning 2 12-15-2013 01:04 PM
Any Place to adjust Coilovers in Central NJ? Figo NY / NJ / CT / PA 14 09-23-2013 02:54 PM
Passenger Seat adjust ? rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2013 10:37 PM
Anyone know how to adjust bass/treble on the Brz? ysr50guy Electronics | Audio | NAV | Infotainment 2 02-25-2013 05:45 PM
